Like Tree23Likes
Old 07-13-2010, 05:42 AM   #12766
M03Racer's Avatar
Trader Rating: 32 (100%+)
Originally Posted by tony gray View Post
The 3000kv EZ-RUN system we use in the Minis is NOT a 540 sized motor. It looks like one, but it is in fact a 380 size.
So, direct kv comparisons between it and 'normal' brushless motors are virtually impossible and lots of people fall into that trap.
We have run a 17.5 and from memory (it was well oveer 12 months ago)there was no advantage to be had, the thing was wheelspinning everywhere due to the extra torque.
Its true the best speed for the Mini on an asphalt track is about a 18T brushless motor or about 2230KV motor, a 2400KV motor will give you a some tire spin if you come out of the corner full throttle. I have a 2400KV on order some of the guys ran these and didn't really like it, the car was harder to control on asphalt even with sugar water sparyed on track.
M03Racer is offline   Reply With Quote
Old 07-13-2010, 05:51 AM   #12767
AudiRacer;7643849 WILL THIS BODY FIT MY M03 ?? NEED IT TO MATCH MY 1/10 Rally and TC5
check my blog post here: diyminituner.blogspot.com/2009/08/tamiya-m03-fwd-with-hpi-honda-civic.html (I can't put direct links yet).
The civic body fits, I do have some issue occassionally with rear tire clearance but it works. The latest hpi civic body now has real light buckets if you are into a more scale appearance. I have no idea where I got the foam wheel tire combo but they work great even on asphalt. I don't race. If there was a track or club near me I would. I live in Atlanta, if anyone knows please PM me.
rcmizzi is offline   Reply With Quote
Old 07-13-2010, 06:21 AM   #12768
M03Racer,
As Tony gray said in a post up above the 3000kv 13t ezrun motor we run in Australia is the equivalent to a 380 size motor
Tony should know as it is my understanding that he was instrumental in getting the ezrun combo adopted for the mini class here.. Extensive comparison testing was conducted to ensure that the combo was not to diff to the black can
For the record I race at one of the grippiest asphalt tracks in Australia and we don't have a high level of tyre wear.. I have been running the same shimizu pit 35's on the front since beginning of February and I have raced every week and practiced atleast one other day in the week..
Wylie27 is offline   Reply With Quote
Old 07-13-2010, 11:47 AM   #12769
Ray k's Avatar
Trader Rating: 46 (98%+)
Originally Posted by MD View Post
I have some questions about the Sweep pre-mounted tires. What has been your experience in low grip parking lot situations? According to Sweep USA customer service they are 55mm in total diameter. It seems the Tamiya tires are closer to 59 or 60mm. Do the Sweep tires give you less top speed? Thanks.
Yes Sweep mini tires are 55mm and Tamiya tires are 60mm ,but really are 58 to 59mm . So Tamiya tires will have a little better roll out then the Sweeps . But overall traction and handling is better with the Sweeps. The Tamiya tires would shine on a open layout. Sweeps would shine on a technical track. Tamiya base setup would be S-grips in the rear and M-grips in the front . Sweeps base setup would be 25's in the rear and 33's in the front.
Ray k is offline   Reply With Quote
Old 07-13-2010, 12:00 PM   #12770
MD
MD's Avatar
Trader Rating: 106 (100%+)
Ray K - Thanks for the information. The set up you mentioned with the "S" grips in the front and "M's" in the back worked really well this past winter inside on carpet with my M03M. I recently purchased a M05. I put that same tire setup on the M05. This past Saturday at a parking lot race it didn't work well. I tried the "A" slicks in front and that didn't help. I went to "A" slicks all around and the car drove really well. My friend was running a M05 with the tires that come with the pro kit. He had very little grip. I gave him some old "S" grips for the front and "A" slicks in the back and his car drove really well.
MD is offline   Reply With Quote
Old 07-13-2010, 05:26 PM   #12771
Originally Posted by Toon View Post
Has anyone got experience of running a 17.5 brushless system in a mini, and how it compares to the performance of the EZrun 3000kv system?
I know the kv rating isn't the best way of comparing brushless motors, but the highest kv rated 17.5 motor I've seen is the Speed Passion V3.0 @2700kv. The reason I ask is that the mini class I run in has a motor limit of EZrun 3000kv or 17.5T (everyone currently runs the EZrun though). About 18 months ago I did try a Losi Xcelorin-S 17.5T system in the mini with a 20T pinion, but it was slower than even a black-can sport-tuned motor.
I just wondered that what with the boost/turbo features on many brushless ESC's nowadays, and the extra grunt of a true 540-sized motor compared to the EZrun motor, would a current 17.5T be any faster, given the very limited gearing options in the mini?
I've run side by side an EZRun 13t system with a Novak Havok 17.5t system. The EZRun can be faster than the 17.5t depending on the motor timing you set.
Sydewynder is offline   Reply With Quote
Old 07-13-2010, 06:31 PM   #12772
RevMaxx's Avatar
Send a message via MSN to RevMaxx
has anyone tried their mini with an 11.5T with supercharge boost?
RevMaxx is offline   Reply With Quote
Old 07-13-2010, 07:23 PM   #12773
Timbulb's Avatar
Has anyone tried their mini with an Novak 5.5 HV?
Timbulb is online now   Reply With Quote
Old 07-13-2010, 07:30 PM   #12774
RevMaxx's Avatar
seriously, i have one in mine... i had a blast. very funny to see mini reaching touring car speeds on the straight.
placed weights on the chassis floor and had little traction roll incidents.
Old 07-14-2010, 05:21 AM   #12775
RossoTorro's Avatar
I'm going to test my M05 with Xerun 60A and Team Powers 13.5T motor tonight.
Test with supercharge and so on... Should be fun.
RossoTorro is offline   Reply With Quote
Old 07-14-2010, 11:42 AM   #12776
academygaz's Avatar
I've finished my Ken Block replica. Remember, its a Colt Skoda Fabia 210mm. Its not 100% the same as the Subaru because the decal sheet was 1/10th, the body 1/12th so some bits had to go (the 43 on the roof for example), but I'm happy enough. It looks decent and no-one's done a KB replica on the forum for a Tamiya Mini!
Oh, we've got a Ken Block Subaru DC Monster hat, so have a couple of obligatory posey pics.
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 07-14-2010, 06:19 PM   #12777
M03Racer's Avatar
[QUOTE=academygaz;7670050]I've finished my Ken Block replica. Remember, its a Colt Skoda Fabia 210mm. Its not 100% the same as the Subaru because the decal sheet was 1/10th, the body 1/12th so some bits had to go (the 43 on the roof for example), but I'm happy enough. It looks decent and no-one's done a KB replica on the forum for a Tamiya Mini!
I wouldn't put the Subaru logo on it but otherwise it looks cool.
Old 07-14-2010, 06:24 PM   #12778
M03Racer's Avatar
Here a 04' Civic SI body it fits the M03M, its 225mm body, I wanted something different then the Fiat or Suzuki that fits the M03M. I like the way it came out although the lime green on the cap was a little less metallic but oh well. Now I wanna see how it performs. This body style for the Civic is also not as popular as the older style cause I haven't seen any yet. I kinda butchered it a little with the double holes on top in the back of the body cause it didn't have any markers but I can live with it.
Old 07-14-2010, 06:55 PM   #12779
RevMaxx's Avatar
cool, we have similar electncs set-up, also have the xerun 60A but used 11.5T Team Powers motor. also, what set-ups have u implemented on the car? and how many teeth - pinion ur using now?
let us know how you find it.
Old 07-14-2010, 08:03 PM   #12780
RossoTorro's Avatar
We run spec with Ezrun 13T, but i tested a few races with my Xerun/Team Powers setup. It was insane compared to the others, so much faster top speed and acceleration. We run stock gears with hard coated 20t pinions with Xpress or Yeah Racing foams. The tirelife was halved, normally 1 set of fronts lasts 2 racenights, this time i had mine reduced to nothing in a few races, the track is very high grip carpet. The other racers are pretty good drivers, but with this setup i lapped them all twice in 20 laps. We normally have low 10 sec laps with Mini's. I was almost a full second a lap faster.
Other setup is when running Ezrun 13T:
Tamiya alu steering, 3mm toe out
Tamiya alu upright front/rear (1.5 degree toe in rear)
Hybrid TA03/Manta Ray diff (metal parts from TA03, gear and thrustbearing from Manta Ray, set loose)
Tamiya TRF M-chassi dampers with blue spring all around, 2 hole piston and 200 Tamiya oil
Tamiya carbon shaft in gearbox
Tamiya M03 universal shaft
Tamiya Alu motor mount with DF02 heatsink
Tamiya Steering turnbuckle
Futaba S9402 steering servo
Rideheight is 2mm front/rear
Camber in front is stock, upper hole in chassi
Camber rear is 0,5 degrees, upper hole on upright
Wheelbase is 210mm with Colt Beetle body
25 gram weight under servo and 20 gram on top chassi
Lipo is Intellect 4000mah 25C
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
