Like Tree21Likes
Old 02-27-2006, 04:30 PM   #1261
akuhon's Avatar
Also
53301 TL01 suspension shaft set - SS
might worth to be considered
akuhon is offline   Reply With Quote
Old 02-27-2006, 04:45 PM   #1262
BringItOn's Avatar
Originally Posted by danjoy25
Guys,
Just a couple of ???? to mini pros.
1) Does the 60D Type A come with inserts or do I need to get 50686 60D Inner Sponge Tire Set (Soft) as well?
2) What is the difference between TA03 diff set and Manta Ray diff set? Which one should I get.
3) Is the new M03m chassis basically the same but with a shorter extension piece to M03L? Just want to know if I get the chassis extension then I could run the BMW Cooper body.
4) Any useless stuff in the list below or did I miss anything that I need.
58368 Suzuki Swift Super 1600 - M03M
51237 Suzuki Swift Super 1600 Wheel Set
53267 TA03 Ball Differential Set
53343 M03 Front/Rear Stabilizer
53344 M03 Aluminum Heat Sink
53345 Toe-in Rear Upright
53346 Ouick Release Batt Holder
53390 Hollw Carbon Gear Shaft
53523 Alum Front Upright Set
53527 3 x 32 Titan Turnbuckle
53569 Clamp Type Alum Wheel Hub - 6mm
49198 TRF Damper Set
53488 Adjustable Ball Connectors x 2
53333 Touring Car Tuned Spring Set (Short)
53205 M-Chassis Universal Shaft Set
53340 M Chassis 60D Reinforced Tires Type A x 4
50686 60D Inner Sponge Tire Set (Soft) x 2
53379 Light Weight Diff Balls
Does anyone know where to get a Honda Civic Type R EK hatchback body that can fit the M03 chassis?
Thanks in advance.
1. get the hard inserts.
2. get the ta03 diff. its smaller
3. run BMW for long chassis
4. I would get. Toe in (for tuning), Quick release battery holder (makes changing batteries much easier - no need for body clips), Spring set (tuning), Turnbuckle (tuning more easier), Hollow carbon fibre shafts (faster)
Also essential (if you want to go fast) is ball bearings if you dont already have
BringItOn is offline   Reply With Quote
Old 02-27-2006, 04:50 PM   #1263
lbckevin's Avatar
Trader Rating: 85 (99%+)
How are you guys lowering the car down to 4mm-5mm....?
Kevin Smith
Schuur Speed* Hobbywing * Pro-Line * MIP * Paint Monster Airbrushing * Schelle Racing
lbckevin is online now   Reply With Quote
Old 02-27-2006, 05:15 PM   #1264
Slotmachine's Avatar
Send a message via MSN to Slotmachine
You need to go buy the correct springs for the car, not sedan springs. They make Mini springs you can buy in pairs only , they do not sell them in sets.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 02-27-2006, 08:21 PM   #1265
speedemall's Avatar
Trader Rating: 37 (100%+)
Guys,
Thanks in advance.
Call HPI I think they still make them
speedemall is offline   Reply With Quote
Old 02-27-2006, 09:48 PM   #1266
rayman's Avatar
Guys,
Thanks in advance.
That motor alum heatsink is useless. Its more bling than actually functional as a heatsink. But its cheap anyway so pimp your car Everything else is useful.
rayman is offline   Reply With Quote
Old 02-27-2006, 10:59 PM   #1267
414play's Avatar
Guys,
Thanks in advance.
i dought the alloy front upright set will fit the m03m as it has new uprights and c-hubs and i think use ta04 king pins.
414play is offline   Reply With Quote
Old 02-27-2006, 11:39 PM   #1268
asw7576's Avatar
I use tamiya blue short spring front and regular yellow spring rear.
Old 02-28-2006, 01:29 AM   #1269
ckbridge's Avatar
Default Upper arms
Hi, I too love racing these M-cars. I'm building another now and was wondering if the 53303 TL01 adustable arms will work on the M03. Has anybody tried this? If they work the car should still be TCS legal.
Also, does anybody know when the Suzuki Swift Super 1600 - M03M
will be released? I would like to get the chassis extender so I can use an HPI 225mm body.
ckbridge is offline   Reply With Quote
Old 02-28-2006, 02:59 AM   #1270
volracer's Avatar
Send a message via ICQ to volracer
I had seen a date of March 30th and also April. If you check the Tamiya USA website, they list the part number for the new suspension pieces including the body extender. Does anyone know the dimensions of the "1050" bearing that are used in the new suspension pieces?
volracer is offline   Reply With Quote
Old 02-28-2006, 08:57 AM   #1271
snopro31's Avatar
Trader Rating: 36 (100%+)
Anyone one have a carpet setup for a m04m ? any tips on this car are very welcomed.
snopro31 is offline   Reply With Quote
Old 02-28-2006, 09:51 AM   #1272
asw7576's Avatar
Anyone had tried fixed axle in mini cooper ?
I want to completely eliminate the spin issue.
Old 02-28-2006, 10:23 AM   #1273
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
1050's are 5mmx10mm, likely 4mm thickness..
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 02-28-2006, 10:50 AM   #1274
ckbridge's Avatar
Default fixed axle
You could squirt shoe-goo in a stock diff. That should lock it up. If you try it tell us how it goes.
Old 02-28-2006, 12:52 PM   #1275
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
I did and it added a lot of weight up front.....
Turning became an issue with a tight track and I felt it did not help me at all.
The front wheels have 2 functions on the m03, the rear one....
Front: Wheel drive and steering
Rear: tracking only
On a tight track a well built ball diff is the only way to go.....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
