Like Tree19Likes
Old 06-30-2010, 12:04 PM   #12676
tudor_47's Avatar
Originally Posted by M03Racer View Post
If the front spring set up is too stiff you will always spin out because the front of the car is a little heavier then the rear and it starts to bounce and you can lose traction. Now if you use a softer spring in the front the car will actually absorb the bumps better just like in a real car and will have enough traction not to spin out. I use red springs in the front and blue in the back and this does the job for me. Also try a faster motor then your stock motor to break in the gears I'd say use the Tamiya sport tuned motor 27T or the Tamiya lightly tune motor 28T. Both motors a better then the stock silver can motor that the car comes with, the Sport tuned motor has a good steady band of speed and the Lightly tuned motor has better top end speed. Run the car thru at least three battery charges and make sure your motor pinion is on tight otherwise you will strip some gears I always check to make sure I tighten the pinion right before I put the motor in. I use a little cement on the screw to make sure it does not move. I hope this helps you out a bit.
Thanks for good advice!
I am now running the Tamiya 'Super stock motor TZ' (23Turn tamiya-nr: 53696)
So it should be enough to break in the gears... I will recheck the pinion and use some loctite on it to secure it.
I will get the options springs for the 3racing dampers and test softer springs infront, as my car has started to bounce lately, since the front wheels became slicks...
Again Thanks!
/Johnny
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 07-01-2010, 03:35 AM   #12677
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
anybody tried the Datsun 280ZX? how's the handling?
hello miss, puwede pa bind?
nikkiesteban is offline   Reply With Quote
Old 07-01-2010, 06:06 AM   #12678
not too bad, but you have to run the 55d tires.
Bodywerx_rc is offline   Reply With Quote
Old 07-01-2010, 07:29 AM   #12679
i see. Why do I need to run the 55d? how about the 60d?
Old 07-01-2010, 08:05 AM   #12680
The tires do not fit the wheel arches, you would have to make them larger.
Old 07-01-2010, 12:40 PM   #12681
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Hi guys,
Just small question ... for you who are racing brushed motors on Lipo's on yours M03's and M05's, did you noted a HUGE change in motor wear when went from NiMH to LIPO ?, i mean, was like killing motors just because of the Lipo ?, i need really in depth information about this ...
thanks a lot,
Pat
Tabushi is offline   Reply With Quote
Old 07-01-2010, 01:26 PM   #12682
shortbus's Avatar
Default mini coop bodies
I recently purchased a tamiya rtr m03 mini-cooper set. I noticed that my body seems to sit pretty high compared to others that I've seen run. Are there huge differences in companys and models currently out there? What does everyone recommend for a replacement if I wanted to stick with the old school cooper body?
Thanks !!
Jeff
shortbus is offline   Reply With Quote
Old 07-01-2010, 02:14 PM   #12683
kwkride's Avatar
Originally Posted by Tabushi View Post
Hi guys,
thanks a lot,
Pat
I had no problems with running lipo packs and my silver can motor.
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 07-01-2010, 02:19 PM   #12684
In CHASIS M05 enters the lipo Oriom rocket packs?
http://jlsabucedo.wordpress.com
higbo is offline   Reply With Quote
Old 07-01-2010, 02:30 PM   #12685
Skitee's Avatar
Yes the Orion rocket packs do fit the M-03 / M-04 / M-05
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 07-01-2010, 02:35 PM   #12686
gashuffer's Avatar
Trader Rating: 48 (100%+)
Aren't those rocket packs discontinued?
T-Sal
gashuffer is offline   Reply With Quote
Old 07-01-2010, 02:43 PM   #12687
Skitee's Avatar
Nope it's a new line released in the last few months
http://www.teamorion.com/Products/IBS+LiPo+Rocket+Packs
http://www.teamorion.com/Products/LiPo+Rocket+Packs
http://www.teamorion.com/Products/LiFe+Rocket+Packs
Old 07-01-2010, 02:47 PM   #12688
Rocket 4000 is ok?
Old 07-01-2010, 02:52 PM   #12689
Skitee's Avatar
Yes the 4000 fits
Old 07-01-2010, 02:53 PM   #12690
gashuffer's Avatar
Thats weird tower had them listed as discontinued a while back.
T-Sal
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
