Like Tree2Likes
Old 06-18-2010, 01:40 AM   #12571
Originally Posted by M03Racer View Post
...but its a TL-01 so its not an M chassis as the guy advertised it. Its in good shape has ball bearing upgrade, I took it apart the gears look new I just lubed them and cleaned the whole chassis. I got it for twenty bucks including shipping so the price was good, now I'm debating on keeping it or selling it.
It can be converted to a M chassis, there are a few conversions around
Its just a matter of the a hunk out of the middle & fitting mini suspension arms.(more or less-)
1101 is offline   Reply With Quote
Old 06-18-2010, 06:51 AM   #12572
Default servo saver & servo(sorry)
Hi there.
I'm putting a M05Pro together(still no locking hex-hubs!! I thought this was a high end version)
Ive never figured out the servo saver. Are all 3 springs supposed to go in it??
Is it even needed. with all 3 springs it seems almost solid. Im sure something else will give out before can do its 'saving' job ?? (did on my M03, ripped out ball connector)
I hate to ask about servos here again, but Is a Futaba 3003 good enough??
I'd rather used my spare Spektrum(JR??) servo, but none of the Tamiya servo parts fit its spline- any ideas on how to use a Spektrum servo ??
cheers
Old 06-18-2010, 07:03 AM   #12573
John.C's Avatar
Trader Rating: 36 (100%+)
I just purchased a M03R with hopups but no electronics. I'm also in need of some advice on what type of servo, ESC, battery to purchase for this car. I plan to race at the TCS events so my search criteria would only include items that are TCS legal.
Thanks in advance for the help and advice.
-John
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 06-18-2010, 07:05 AM   #12574
cannon's Avatar
Trader Rating: 35 (100%+)
Originally Posted by 1101 View Post
Hi there.
cheers
You use all 3 spring clips otherwise the steering will wander under load. 2 gold on the inside and the black on the outside. It is supposed to be near solid. It is designed as a "servo saver" . It saves the servo gears from being stripped when under extreme load (a crash or hit)
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 06-18-2010, 07:09 AM   #12575
Well I finally got the chassis today after two weeks. It was the slowest item ever shipped that I got locally from the bay. I was confused at first cause it looked like an M04 chassis but its a TL-01 so its not an M chassis as the guy advertised it. Its in good shape has ball bearing upgrade, I took it apart the gears look new I just lubed them and cleaned the whole chassis. I got it for twenty bucks including shipping so the price was good, now I'm debating on keeping it or selling it.
Ill take it for $20.00 P.m. me.
Bodywerx_rc is offline   Reply With Quote
Old 06-18-2010, 09:01 AM   #12576
Timbulb's Avatar
What exactly is the advantage of locking hexes? I've used them and never saw any advantage. In fact I've gone back to the regular plastic ones because they're lighter and the aluminum ones were a hassle to remove when it came time to service the bearings.
Timbulb is offline   Reply With Quote
Old 06-18-2010, 09:05 AM   #12577
academygaz's Avatar
With locking hexes, when you take the wheel off the hex stays on the car instead of stuck in the wheel.
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 06-18-2010, 10:21 AM   #12578
M03Racer's Avatar
Trader Rating: 31 (100%+)
GMP makes some nice aluminum hex adapters because they have a machined cut in them so they adjust to any wheel.
M03Racer is offline   Reply With Quote
Old 06-18-2010, 01:28 PM   #12579
gtfour93's Avatar
Trader Rating: 22 (100%+)
^ You mean GPM. By the way, Tamiya USA has the original Alfa Romeo wheels that you are looking for.
www.activrc.com
gtfour93 is offline   Reply With Quote
Old 06-18-2010, 02:31 PM   #12580
Trader Rating: 69 (100%+)
over time the plastic hexes can deform and bind on the axels and bearings. when the plastic ones are new and fresh, they are fine. but after cranking down on the wheel nut or crashing a bunch of times, they can actually touch the shields on the bearings causing them to drag which hinders top speed and causes uneeded motor heat. I once rebuilt my drivetrain 2 times wondering why it wasn't as free as other people's minis (I'd see it on the straight using matched 15k motors, even swapped motors for 1 qualifier). It turned out to be the dang gone plastic wheel nuts. changed them to the aluminum hexes and never had the problem again.
Markus is offline   Reply With Quote
Old 06-18-2010, 03:22 PM   #12581
MD
MD's Avatar
Trader Rating: 105 (100%+)
You can get aluminum hexes that are not locking. I have some Tamiya ones and they are very good. I'm sorry I don't have the part number.
MD is online now   Reply With Quote
Old 06-18-2010, 03:31 PM   #12582
tony gray's Avatar
Here's something new. The first (that I know of) of the Li-Fe packs that will fit into a Mini. 6.6v and 30c. Are these the future? Who knows...
And, some more pics of the Spice phat Toyota Starlet.
tony gray is offline   Reply With Quote
Old 06-18-2010, 07:32 PM   #12583
nothing worse than the plastic hex coming off with the wheel & the small pin falling out never to be found again.
Plastic ones also can deform , making wheel hard to fit on/take off.
I bought some 3racing locking hex's a while back. I have yet to find ANY rc car that they actually will clamp down on.
Luckily I some some spare locking hex's I can use on the mini
(Come on Tamiya, would only have cost beggr all to include them)
Old 06-18-2010, 07:37 PM   #12584
cannon's Avatar
Some hexes are just a bit open in the split in the hex. Try squeezing the hex shut with a pair of pliers. I did that to some hexes and problem solved. They now fit perfectly
Old 06-18-2010, 07:55 PM   #12585
cannon's Avatar
Tony
There are quite a few LIFE packs around that will fit Minis
Intellect make some ... including a 9.9 volt one. They go very well with the 9.9 volts
That Eagle Pack looks very much like the Intellect one
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
