Like Tree200Likes
Old 06-06-2010, 02:19 PM   #12481
here you go i ren this set up all winter end no one could catch me
fully rebuilt and he is running
3Racing ball diff
TRF shocks (mini type) with 300 oil all round
yellow front springs
red rear springs
2mm spacer on toe tierods (toe out)
Adjustable upper arms rear
3Racing steering mechanism
3Racing battery holder
Tamiya alloy motor mount
Tamiya DF03 heat sink bars
Tamiya Alloy steering connector rod
Titanium screw set
TRF servo saver
silvercan and stock speedo
Bionic batterys stickpack lipo
10g lead inside front bumper
M grip tyres all round with cut down touringcar inserts Swift wheels
Mini body shell
sidecarphil1 is offline   Reply With Quote
Old 06-06-2010, 06:17 PM   #12482
tiko's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to tiko
Originally Posted by sidecarphil1 View Post
my M05 was planted indoors with tamiya tyres
i will look for my set up sheet for ya
3Racing ball diff
red rear springs
Titanium screw set
TRF servo saver
Mini body shell
Thank you buddy really appreciate the info. I almost have everything that you listed. Any specific TC inserts that you recommend. Also did you go with 3 hole or 2 hole piston for the shock. Thanks again.
tiko is offline   Reply With Quote
Old 06-06-2010, 07:25 PM   #12483
Default Traction roll
Hi there, whats the lowdown on stopping traction roll.
Searching the forum just seems to give totally conflicting advice.
Car is pretty std M03(except the motor) cold tarmac, std shocks, 40R Sweep rubber, no sway bars(they seemed to make it worse)
I think going to lipo made it alot worse.
cheers
1101 is offline   Reply With Quote
Old 06-06-2010, 07:30 PM   #12484
MD
MD's Avatar
Trader Rating: 118 (100%+)
On the carpet track I run on, one constant is Tamiya "S" grips in the front and "M" grips in the rear.
MD is offline   Reply With Quote
Old 06-06-2010, 08:47 PM   #12485
M03Racer's Avatar
Trader Rating: 33 (100%+)
Was there ever a 4WD M chassis made by Tamiya? Because I just purchased a chassis that looks like M04L but it has driveshafts even in the front and the seller could not tell me what it was. I got it really cheap cause its just a rolling chassis (no body, motor or electrics). When I get it I will post some pics of it.
M03Racer is offline   Reply With Quote
Old 06-06-2010, 09:39 PM   #12486
andrew-01's Avatar
Trader Rating: 22 (100%+)
cheers
From the way I understand it, the higher R ratings is for hotter weather. You say your running on cold tarmac so you may need to run 25R Sweeps. What about saucing or not saucing your tires? Oil filled shocks or std as is in friction shocks?
My buddy had much better luck when he mounted all his electronics(M03) down low like say an M05. I use to get rear end chatter(M05) and that would occasionally lead to rolling so I lowered my weights to inside the tub(they sit maybe 10mm off the ground from inside the actual chassis).
Whats your ride height at as well?
ANDRXW.com
andrew-01 is offline   Reply With Quote
Old 06-06-2010, 11:23 PM   #12487
tiko's Avatar
It could be a TT01 conversion kit from 3Racing.
Old 06-06-2010, 11:26 PM   #12488
i used the Vtec inserts from the LRP vtec30's
and 3 hole pistons in the shicks with 3mm spacers to limit the down movement
Old 06-06-2010, 11:26 PM   #12489
the best way to stop tracion rolling is to superglue the sidewalls of the front tyres
Old 06-07-2010, 01:47 AM   #12490
cheers
Lower the car as much as you can. 3-4mm ride height.
Going to lipos will require you to add weight to avoid traction rolls.
Go to rc-min.net -> "How To's" -> "Adding Weights" for help.
Sydewynder is offline   Reply With Quote
Old 06-07-2010, 09:19 AM   #12491
tiko's Avatar
Thanks I have to rebuild a set of shock for the carpet track.
Old 06-07-2010, 01:32 PM   #12492
academygaz's Avatar
Does anyone know if the HPI Switch Fiat 500 body is available separately? Even better, a shop stocking it? And is it 225mm or 210mm?
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 06-07-2010, 04:25 PM   #12493
M03Racer's Avatar
You can get the Tamiya Fiat Abarth 500 light weight body (its the racing version of the Fiat 500) that's pretty cool looking. And it fits the M03M or 225mm chassis.
Old 06-08-2010, 04:10 AM   #12494
academygaz's Avatar
I know, but the Tamiya body splits too easily because its a 3pc mold and Tamiya use thick lexan even on the lightweight bodies, the HPI one should stand up to a bit more abuse (if I can find one ).
Old 06-08-2010, 10:56 AM   #12495
gashuffer's Avatar
Trader Rating: 48 (100%+)
http://www.abchobbyusa.com/datsun510bre.aspx
T-Sal
gashuffer is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
