Like Tree1Likes
Old 06-03-2010, 01:04 PM   #12466
academygaz's Avatar
Any sources of the Venom green alloy and carbon parts that won't cost silly money to ship worldwide?
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 06-03-2010, 04:06 PM   #12467
M03Racer's Avatar
Trader Rating: 31 (100%+)
What determines a good ESC for a brushless motor I found a great deal that seems too good to be true. I found a Tacon 2230KV motor with a Hobbywing EZRUN 25A-SL-H (version2.0) ESC would this combo work or would I need a bigger Amped ESC.
M03Racer is offline   Reply With Quote
Old 06-03-2010, 08:13 PM   #12468
M03Racer's Avatar
I found out that I need at least a 40A ESC for the 2230KV motor.
Old 06-03-2010, 11:19 PM   #12469
Not true.
Hobbywing has a 35A esc with a 9T - 4300kv combo.
Sydewynder is offline   Reply With Quote
Old 06-04-2010, 12:59 AM   #12470
RossoTorro's Avatar
And 25A ESC with 3300kv is also no problem, i run that on my M04.
RossoTorro is offline   Reply With Quote
Old 06-04-2010, 07:24 AM   #12471
M03Racer's Avatar
So is that means that a 25A ESC can handle a 2230KV motor if so the guy that gave me the information was trying to make me buy a more expensive ESC.
Old 06-04-2010, 07:41 AM   #12472
RossoTorro's Avatar
Yes, 25A is more than enough. I have even used a 18A ESC on 3000kv motor.
It got a little warm but not thermal.
Old 06-04-2010, 09:03 AM   #12473
academygaz's Avatar
Or he thinks you're going to run it with a 4wd car like a touring car or buggy. Minis are a lot lighter and have a lot less friction, so don't have as much of an amp draw, so you can get away with lower-spec ESCs.
Old 06-04-2010, 11:20 AM   #12474
M03Racer's Avatar
No he was out to make more money cause I told him that it was for a M04 chassis. But I found a better deal on a 45A ESC its only a few bucks more then the 25A ESC but its in Hong Kong so the long wait for shipping starts that's the only thing I hate when buying from Hong Kong.
Old 06-04-2010, 03:11 PM   #12475
RC MARKET's Avatar
New black color shock & White color spring
RC MARKET is offline   Reply With Quote
Old 06-05-2010, 09:54 AM   #12476
M03Racer's Avatar
So I ordered the Tacon 2230KV motor with the 45A ESC. The whole combo cost me about seventy dollars, not bad considering I purchased both separate because it only cost me four dollars more for the 40A ESC compared to the 25V ESC with shipping. Now to test them when I get them I will post pics installed in my M04 chassis.
Old 06-06-2010, 11:42 AM   #12477
tiko's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to tiko
Hi I started practicing on carpet for the first time. I would like to know what kind of tire and insert combination are recommended for the carpet track. I have a M05 with Tamiya hop-ups. The car handles fairly well on asphalt but on carpet the rear end is to loose off-power. Right when I start to turn in to the corner car spins out. I donít have to use Tamiya items so any brand will do. Any and all suggestions will be greatly appreciated.
tiko is offline   Reply With Quote
Old 06-06-2010, 01:30 PM   #12478
andrew-01's Avatar
Trader Rating: 22 (100%+)
Originally Posted by tiko View Post
Hi I started practicing on carpet for the first time. I would like to know what kind of tire and insert combination are recommended for the carpet track. I have a M05 with Tamiya hop-ups. The car handles fairly well on asphalt but on carpet the rear end is to loose off-power. Right when I start to turn in to the corner car spins out. I don’t have to use Tamiya items so any brand will do. Any and all suggestions will be greatly appreciated.
I imagine your running at TQ in Chino. When I ran there last week I tried a few different setups. Some guys were saying Tamiya 60 D's with Sweep sauce was good. My buddies ran ABC tires with Jack the Gripper on rear but ended up switching to Sweep X2.
I preferred to run Sweep 33deg with pink inserts, sauced with Sweep X1. Half inside of front, full rear for 15min before run, then cleaning with the Sweep X1 after the run.
Hit a 14.7 and a hand full of 14.8's as well and feel like I can go much faster.
Shock oil was:
50 front-2 hole piston-full droop-yellow springs,
45 rear-2 hole piston-full droop-blue springs.
ANDRXW.com
andrew-01 is offline   Reply With Quote
Old 06-06-2010, 02:00 PM   #12479
tiko's Avatar
Shock oil was:
50 front-2 hole piston-8.5mm ride-full droop-yellow springs,
45 rear-2 hole piston-9mm ride-full droop-blue springs.
Hi Andrew, yes you are correct about TQ. Yesterday I tried all my Tamiya tires with different inserts and the car was okay with the S-Grips but when I went to slicks thatís when it started spinning out. Thanks for the info on the tires and all I donít have any of does but Iíll get some to try it out.
Old 06-06-2010, 02:12 PM   #12480
my M05 was planted indoors with tamiya tyres
i will look for my set up sheet for ya
sidecarphil1 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (3 members and 1 guests)
fgextreme1, Frankiemtz1, Toypainter
