Like Tree81Likes
Old 05-28-2010, 03:50 AM   #12421
Originally Posted by Peter $ View Post
Thanks a lot.
What pinionsize do you use? And do you use the smaller or the larger of the spurgears?
Thanks again.
Peter
I use the small of the spur gears with a 22 tooth pinion because our track has a 70m straight and we can only use silvercans
the 24 tooth pinion wont fit my M05 due to the hole in the alloy motor mount is too small for it
sidecarphil1 is offline   Reply With Quote
Old 05-29-2010, 08:43 AM   #12422
academygaz's Avatar
A mate of mine needs new steering links for his original M03 (his popped over the ballstud causing the steering to stop re-centreing).
Instead of buying the whole C-Parts tree, would the ballends from 50953 work?
http://www.tamiya.modelsport.co.uk/i...n&ItemID=13458
I hate working out Tamiya parts and part numbers....
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 05-29-2010, 12:20 PM   #12423
PaPeRo's Avatar
If you want to use those you need 6mm ball studs or ball collars. Most Tamiya cars use 5mm links and balls.
deans - dodgy electrics amps not sufficient
PaPeRo is offline   Reply With Quote
Old 05-29-2010, 04:10 PM   #12424
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
try 50875 or 53601. I use the 53601
tamiyarcracer is offline   Reply With Quote
Old 05-30-2010, 01:59 PM   #12425
M03Racer's Avatar
Trader Rating: 32 (100%+)
What do you guys think of the Tamiya's GT tuned motor is it any good for the Mini its 27T motor I'm not using this for racing or anything. I have a Tamiya sport tuned black can motor and a Tamiya lightly tuned silver can 28T motor in both my M03 chassis cars. I have the stock 540SH silver can motor that the car came with in my M04 and I was thinking on getting a GT tuned motor is it a waste of money or what do you guys think. I've seen them for about $38 with shipping.
M03Racer is offline   Reply With Quote
Old 05-30-2010, 04:12 PM   #12426
PaPeRo's Avatar
You could get a Hobbywing brushless motor for about $30. I think it's a waste of money to get a brushed motor nowadays.
Old 05-30-2010, 08:13 PM   #12427
M03Racer's Avatar
What does KV mean on a brushless motor?
Old 05-30-2010, 08:15 PM   #12428
cannon's Avatar
Trader Rating: 35 (100%+)
rpms per volt
so a 3000kV does 3000 rpm per volt
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 05-30-2010, 08:38 PM   #12429
does anyone know if a hpi cup racer dautson 510 body will fit the m03 chassis?
bgcountry is offline   Reply With Quote
Old 05-30-2010, 09:28 PM   #12430
M03Racer's Avatar
It will fit the M04 since the bodies length is 225mm but not the M03. Its a little longer then the M03.
Old 05-30-2010, 10:01 PM   #12431
darn i realy like the way that body looks too! oh well! thank you for the info
Old 05-31-2010, 12:06 AM   #12432
Peter $'s Avatar
Not entirely true. The M03-M has the right wheelbase. You can make your car longer or shorter so it will be either 210 mm, 225 mm or 239 mm.
Cheers
Peter
Peter $ is offline   Reply With Quote
Old 05-31-2010, 02:14 AM   #12433
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
actually you might have more of a problem fitting the datsun with the servo mount on the M03 - not with the wheelbase...
the datsun is made to mount on a cup racer with a low-profile front nose (ie, laydown shocks vs stand-up shocks) and the top of the M03 will most likely be a HUGE issues on the HPI datsun
sorry, dude
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 05-31-2010, 06:18 AM   #12434
Yes, It will fit the M03m
Bodywerx_rc is offline   Reply With Quote
Old 05-31-2010, 07:09 AM   #12435
M03Racer's Avatar
True the Datsun will fit the M03M just like this Alfa but it will looks plain ridiculous it rides too high because of the servo mount even with full size 1/10 tires. The nose on the Alfa and Datsun are much flatter then that of the Mini or the Suzuki. The nose of the Suzuki and Mini are more rounder and taller so that's why they can fit over the servo mount.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
