Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 05-27-2010, 08:50 AM
  #12406
M03Racer's Avatar
Trader Rating: 33 (100%+)
Cool video guys. Although I would never do that to my minis.
M03Racer is offline
Old 05-27-2010, 10:36 AM
  #12407
superspeed's Avatar
m05ra - rally version of m chassis with swift body, they need to put oil dampers and longer spring in these rally kits. Better yet, put bearings and oil filled shocks in all non pro m chassis kits.
superspeed is offline
Old 05-27-2010, 10:37 AM
  #12408
Originally Posted by tony gray
There's a reason Tony P and Tim are standing behind that big concrete pipe.
And yes, that red blur IS a mini (an M05 to be exact)
Check out the stupidity HERE
Although i condone this sort of abuse to the lesserspotted mini i do respect you for having some one in goal!!!
this sort of sillyness can result in belly ache and sight loss due to laughing !!!
Respect goes to the red mini who thoughout all the abuse it kept going till its wheel fell off
well done guys i like it a lot and now my laptop is covered in the chinese i was eating when watching the video
sidecarphil1 is offline
Old 05-27-2010, 10:58 AM
  #12409
M03Racer's Avatar
My M03M chassis with the Suzuki Swift super 1600 body has 55mm aluminum shocks installed and 1/10 full size wheels and tires on it. Its a lot higher then my regular M03, M03R even higher then my M04 chassis. I can even take it off road if I want to.
M03Racer is offline
Old 05-27-2010, 02:02 PM
  #12410
superspeed's Avatar
have you raced at TCS event before? I went to Trackside back in 2006, they had a rally class exhibition. It was pretty cool, only drawback was the kit tires didn't work too well on the dirt offroad track.
Old 05-27-2010, 02:07 PM
  #12411
tony gray's Avatar
Originally Posted by bjspinner
No wonder you cant get your MO5 going any good Mr Gray
Tis not my car featured... I was the camera guy...
No Minis were harmed in the making of this film.
tony gray is offline
Old 05-27-2010, 02:59 PM
  #12412
F N CUDA's Avatar
Trader Rating: 34 (100%+)
I'll bet those silver can motors didn't meet the 12,500 RPM limit
F N CUDA is offline
Old 05-27-2010, 03:07 PM
  #12413
MD
MD's Avatar
Trader Rating: 136 (100%+)
Maybe we need a new organization, PETM(People for the Ethical Treatment of Minis).
MD is offline
Old 05-27-2010, 06:59 PM
  #12414
M03Racer's Avatar
Here is what I mean about my M03M Suzuki on the left versus my M03 Mini on the right. I could even use 1/10 tamiya rally block tires on my M03M Suzuki Super 1600. I mean after all it is a rally car. Its just too bad that in my area there isn't any track that runs a rally class. I would be game.
M03Racer is offline
Old 05-27-2010, 09:40 PM
  #12415
PaPeRo's Avatar
Who makes those silver shocks? They look nice.
PaPeRo is offline
Old 05-27-2010, 10:11 PM
  #12416
M03Racer's Avatar
The silver aluminum dampers/shocks are made by X spede. They fit a variety of cars.
M03Racer is offline
Old 05-28-2010, 12:10 AM
  #12417
PaPeRo's Avatar
Oh wow I didn't even know they made them in silver. I have the same shocks but gun metal colored. I put white Tamiya springs and TRF spring retainers on mine.
PaPeRo is offline
Old 05-28-2010, 01:44 AM
  #12418
Peter $'s Avatar
Default 3Racing speed tuned gear?
Hi guys.
There has opened a new racing class in my area, which is called FunnyRacing (because that’s what’s it's all about )
The rules state that you have to use a M-chassis car, and the 13T Ezrun motor (or silvercan or Sportstuned, but they are clearly at a disadvantage here). That’s pretty much the only restrictions there are.
In the first race (which I participated in) in became clear that foam tires was the way to go. The fastest guys use normal 1/10 foams, they make 60 mm in diameter (don't know the word for the process when you sandpaper the tires).
My brother and I drove on minifoams from Year-racing. We were very happy with handling and traction, but since the wheels are only 54 mm in diameter from the start, in means that we lose about 10% in top speed, compared to the others.
So on to my question (at last). Have any of you tried the new M05 speed tuned gears from 3Racing? Do they work, and can we also use them in our M03 and M04?
Mind you there are NO rules concerning modding the car, so it’s not illegal in our races to change parts on our cars, as long as the chassis still is a M-chassis from Tamiya.
Also I don't like the look of the big wheels, so I'm very keen to keep using the mini foam tires if possible.
Thanks for any replies
Peter
Peter $ is offline
Old 05-28-2010, 02:58 AM
  #12419
I use the 3Racing speed gears with great sucsess butninhave spent a lot of time perfecting them and checkimg for the gear mesh as the instructiojs are rubbish
My advice is that you check which holes line up best for which pinion as the first time i used them the mesh was bad and i destroyed it within 10 mins !!!
Old 05-28-2010, 03:30 AM
  #12420
Peter $'s Avatar
Thanks a lot.
What pinionsize do you use? And do you use the smaller or the larger of the spurgears?
Thanks again.
Peter
Peter $ is offline
