Like Tree19Likes
Old 04-24-2010, 11:20 PM   #12136
Scooby Horton1's Avatar
Any word on if you use the pulley with the ta03 diff in an mo5?
Trinity,EPIC,Oddy Racing,IRS,Sweep racing,Brown Engineering,Mugen USA,Team Xray,RC America,R.I.P. motorsports,Tekin,Customworks,Parma PSE,Ashford Hobbies,D&K Hobbies, TQ-wire,Local 69 Woodputters Union,Big Ant get well soon!!Quinn my BFF!
Dee Lee is a nut and I don't condone what he will say next!
Scooby Horton1 is offline   Reply With Quote
Old 04-24-2010, 11:31 PM   #12137
cannon's Avatar
Trader Rating: 35 (100%+)
The "pulley" you refer to is not a pulley but rather a housing which the bolt sits inside of. You put the plate over it and can use it in the M05
Look at the metal "pulley" as you call it. It doesn't have even teeth on it and drives nothing in the Minis
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 04-25-2010, 01:09 AM   #12138
Originally Posted by cannon View Post
Read the instructions. They are ONLY designed for the rear of the car.
I am not familiar with your TCS rules but if the rules say they have to be uised for their intended use then they cant be used on the front
HMMM i am 100% that the instructions say they fit the M05 front AND rear , but the M03 ONLY rear
not bothered but hey , we dont have a TCS here so no rules about this ,
i need some help with my M05 on low/ medium grip asphalt
the car is unstable at high speeds and on corners the rear will step out off power but on power the rear is ok
any one got a good set up for the M05 outside ???
sidecarphil1 is offline   Reply With Quote
Old 04-25-2010, 01:15 AM   #12139
cannon's Avatar
Try a little more front toe out.
Run 2 degree rear hubs (the new 3 Racing ones are good because it allows the use of long rear links which helps
Old 04-25-2010, 03:29 AM   #12140
Clayton's Avatar
i have been using the standard plastic 2 degree rear hubs & my car does
feel better at higher speeds than it did with the alloy 1.5 degree but am keen
to try the 3 racing hubs, was wondering about the longer rear links, do
they allow more flex? & have you tried the 3 degree hubs?
Bro-Kin racing, Castle Hill Raceway
Clayton is offline   Reply With Quote
Old 04-25-2010, 03:44 AM   #12141
cannon's Avatar
Clayton
I have used the 3 degree hubs and they work well . It just depends on the track.
The longer rear link means less camber change under compression so better handling
Old 04-25-2010, 04:25 AM   #12142
Raced my M03 last Saturday with a BMW body. By coincidence, I spotted a real BMW by a fellow racer. Maybe someday...
More photos of the mini bmw.
Thanks for looking.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 04-25-2010, 07:05 AM   #12143
i am running the standard rear hubs
i was going to try the 1.5 alloy ones but i think it would make it more nervous
i am going to strip it clean everything and try a totally differant set up as this is totally wrong
so i want a complete setup from someone please
Old 04-25-2010, 02:17 PM   #12144
Clayton's Avatar
Clayton
thanks mate
Old 04-26-2010, 01:16 PM   #12145
well i think i have found my problem .
I was looking at my shocks and i decieded to rebuild them and for some stupid reason i had added 3mm spacers under the piston of the mini shocks giving me almost no rebound/droop
i have rebuilt them with 350 oil all round and Yellow mini springs , M chassis instead of my normal S chassis and 2mm spacers in the adjustable upper arms giving me 2 degrees of camber and i am using the standard hubs with i think 3 dergees toe in
this should see me quicker
Old 04-26-2010, 02:35 PM   #12146
tony gray's Avatar
For those who want to see the cream of Aussie Mini racers in action. Here's the 3 'A' Mains from the 2010 Australian Mini Nationals held just a few days ago at the fantastic Wodonga track in Victoria.
Mini A1 http://www.youtube.com/watch?v=00iTRrODT6M
Mini A2 http://www.youtube.com/watch?v=RbfcgB-DMt0
Mini A3 http://www.youtube.com/watch?v=fHt2_mAWddI
(Videos courtesy of Daniel Maher)
tony gray is offline   Reply With Quote
Old 04-26-2010, 04:44 PM   #12147
stitchy's Avatar
A wrinkle on the M-03 and M-05 comparison, I'd like to hear opinions from those who have owned both.
Which chassis is TOUGHER? As in, which one would experience less breakage in the hands of a beginning racer?
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 04-26-2010, 04:59 PM   #12148
The M05 chassis is tougher, but the C hubs are a littled more prone to breaking. M03 C hubs can be substituted for them, or you can get aluminum replacements.
mariob62 is offline   Reply With Quote
Old 04-26-2010, 05:26 PM   #12149
tony gray's Avatar
Umm, M05 and M03 C hubs are the same...
The M05 uses the uprated front suspension that every M03 from the Suzuki Swift onwards has used.
Which is tougher? M03. Less bits to break. The M05 steering has lots of bits in the whole bellcrank system, none of which the M03 has.
Apart from that there's nothing in it really.
Old 04-26-2010, 08:49 PM   #12150
M03 & M05 C hubs are different. The M05's have the steering link bump stop & seem to be a little more brittle in my experience.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
