Like Tree81Likes
Old 04-19-2010, 08:58 PM   #12091
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by Scooby Horton1 View Post
Do you guys know what cvd's fit in the front of the mo5? I have the mo5 front diff.
try these - http://www.tamiyausa.com/product/ite...oduct-id=53597 - they say for the M03, but they work on both chassis
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 04-19-2010, 09:07 PM   #12092
J-VET's Avatar
The Tamiya set works well, With or with out the ball diff. I haven't had any issues. There are also a few other brands on rc-mart
J-VET is offline   Reply With Quote
Old 04-19-2010, 11:29 PM   #12093
colt1402's Avatar
Trader Rating: 84 (100%+)
Any m03 uni-shaft will fit find in m05. There're 2 versions from tamiya, one is black & another is sliver. Just make sure you get the black one as we believe they tend to last longer.
*************************Addicted To RC*************************
colt1402 is offline   Reply With Quote
Old 04-20-2010, 12:43 AM   #12094
Originally Posted by Auskenny View Post
my budgets not that low
im looking at
-futaba 3pm-x
-spectrum dx3s or dx3r (but keep hearing bad things about spectrum)
I have a DX3.0 as well as the el-cheapo.
The DX3.0 has had no issues except broken aerial hinge(a bit too easy to break)
Some spektrum's have onboard cmos/firmware batt. When this dies you have to send it in to an authorized service agent for replacement- this worries me a bit. Why they didnt make it user replaceable is anyones guess
Have a look at the cost of extra receivers before you buy anything.Not an issue if you only have 2 cars though..
Just why a RX needs to cost so much I dont know.
If the cheapo's 2.4G RX cost $7 and work perfectly & the brand name rx can cost $70 ++, are we just being ripped off??
1101 is offline   Reply With Quote
Old 04-20-2010, 10:05 AM   #12095
reenmachine's Avatar
Trader Rating: 26 (100%+)
Default A quick lesson
No, the $70 companies have R&D, Engineering, Sales/Marketing, Advertising, and Customer Service departments, not to mention expensive professional employees, employee benefits, etc.
The $7 company takes the $70 company's product, copies it using lower-grade components and substandard manufacturing processes, then pays pennies to have it made.
Some of the $70 companies go out of business, other potential new ones decide not to enter the market, and thus innovation stagnates.
The consumer who thought he was winning by saving money loses in the end.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 04-20-2010, 02:12 PM   #12096
Regarding the Tamiya M-05 ball-diff:
Is it 'normal' to be able to adjust the diffs tension by rotating the front wheels in opposite directions? I can change the diff action from fully tight to fully loose by doing this, and I'm not sure if I've built it wrong or fitted it the wrong way around (looking at front of car, screw on left side, nut on right side).
I first ran the diff with the original screw/nut combo and it seemed to work OK for a few races, but I wanted it a bit tighter, and inevitably cracked the nuts plastic housing trying to tighten it. I then bought the TRF screw & nut, tightened the diff down, and it went completely loose 5 laps into the next race.
To be honest, right now I'm thinking about just going back to the TA03 balldiff, as you can make it as tight as you like, and with a bit of threadlock, it stays like that for good.
Toon is offline   Reply With Quote
Old 04-20-2010, 02:52 PM   #12097
tony gray's Avatar
Which is exactly what we've done....
The M05 ball diff is...well umm...not great. And from where we stand, is not a good reliable unit. Too many issues to trust it fully in a race situation, and no real advantage to using it anyway.
TA03 ball diff = Bulletproof
tony gray is offline   Reply With Quote
Old 04-20-2010, 03:00 PM   #12098
Toon,
Welcome to the joys of the m05 ball diff....if you want to persist with this diff then you need to do this
replace the diff nut and screw with a trf 416 diff screw and nut.. Then loctite blue the thread... Leave it for 24 hours.. Then reapply the loctite and put the screw in the diff and tighten it up.. Leave that for 24 hours.. That should hold for a few races....
It seems tamiya screwed up this diff. Most people I know have either the ta-03 diff or a shimmed gear diff..
I still have the m05 diff.. However I have gotten taking it out down to ten minutes.
Cheers
Jason
"sent from my iPhone"
Regarding the Tamiya M-05 ball-diff...
Wylie27 is offline   Reply With Quote
Old 04-20-2010, 10:10 PM   #12099
colt1402's Avatar
M05 ball-diff is suck! Used for only 2 lap with proper lock-thread & it came lose like nobody business. Gear-diff is million times better than the 05 Ball!
Old 04-20-2010, 11:37 PM   #12100
Sorry Guy's
I have to dissagree with your comments , i have run the ball diff in my M05 for about 4 months and after changing the balls to carbide , the screw , thrust bearing , nut and plastic holder , i have had NO problems
I rebuilt it just before the outdoor season and it was perfect , i have only had the bolt coming loose because i put the diff in the wrong way round , the screw needs to be on the left side of the car , and use a LOT of loctite , i never adjust it , and it is very tight !!!!!
I used a tightened gear diff for one race in my M03(ball diffs banned) and after one days racing with a silvercan it was mush !!! the ball diff is good , but the gear diff is less work if you leave it alone and dont space the looseness out of it
sidecarphil1 is offline   Reply With Quote
Old 04-21-2010, 12:08 AM   #12101
racerb's Avatar
Default ball diff
I used the manta ray ball diff (i believe this is what it was)... in my M03, there is no screw but I stripped out the splines on one side... does this sound normal??? I have used it for about 4 race days on carpet and 2 races.. on our opening day of outdoor....
overall just curious if this is something that just kinda happens or....??
racerb is offline   Reply With Quote
Old 04-21-2010, 01:27 AM   #12102
colt1402's Avatar
Originally Posted by sidecarphil1 View Post
Sorry Guy's
Hi bro, you're using the 3racing ball-diff... What i have and mentioned in earlier post is Tamiya M05 ball-diff.
Old 04-21-2010, 01:54 AM   #12103
oooohhh ok
My bad
buy the 3Racing one it is great
Old 04-21-2010, 06:09 AM   #12104
This is normal for the Manta Ray ball diff in my experience.
Pete Waydo
Old 04-21-2010, 08:19 AM   #12105
scribbler's Avatar
In my experience the Manta Ray Diff, and the TA03 diff both strip the splines out. The last one I had to replace stripped the splines off the diff and the cups. I was hoping the new M-05 diff woud address this issue, and remedy this problem.
Is tamiya's engineers going to redesign the M05 diff again, or are there remedies to make the current M05 diff work with more aggressive racing??
I like the looks of the new design, and I'm disappointed to hear that it isn't working that great.
scribbler is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
