Like Tree200Likes
Old 04-15-2010, 09:44 AM   #12061
Tsquare's Avatar
Originally Posted by sidecarphil1 View Post
I bought the m05 mini and added all the hopups i wanted it is better value if you do this i think , the m05pro is ok but i think you need CVDs and alloy shocks before the alloy uprights
+1
Tsquare is offline   Reply With Quote
Old 04-15-2010, 10:35 AM   #12062
Originally Posted by reenmachine View Post
Thanks for the info Granpa, and it's great to hear from you again. We'd love to see you up here in Camarillo again if you can make it up.
I do have a ball diff in the M03. I don't remember which one -- I recall there were two that fit. I tried one and almost immediately stripped out the ill-fitting splines, then tried the other, which worked but I don't know that it's all that much better than the bomb-proof gear diff. One was Manta Ray and one was ???
I will not be racing TCS so I'll go for the 3racing parts.
So it sounds like the way to go for me is to get a regular kit, add my TRF shocks, ball bearings, and the 3racing steering bits, and see how that feels.
What tires do you recommend for our dialed asphalt?
Build your car as a M or L version. Much friendlier and responds to tuning better. They do tune much different than a SWB car so toss out most of your SWB tricks. A SWB car is an "evil", twitchy, bite the hand that feeds it beast.
It was probably the TA03 ball diff and is IMO the best diff for a Mini if you use antiwear grease for assembly. Otherwise, no tricks other than to bottom out the diff screw.
Tires are a totally different deal. Some things are givens tho and #1 is that the grippier the track surface the more important tire selection is and insert selection becomes critical. This is where it becomes confusing. Also, the grippier the surface, the lower you run the car and the stiffer the set up.
Let's start with the tires we can get locally which are the ABC, HPI, RP, and the Tamiya tires. Believe it or not, a medium firm kit tire works well for front tires and you can try S-Grips in the rear. If the new surface you have is as good as I've heard, the tires won't wear that fast as the rapid wear comes from the tires sliding. The ABC has a little less grip than the RP, which is the grippiest of all the tires mentioned. The best tires for your use might be the HPI belted X-pattern (#4565) up front and the HPI radial (#4530) in the rear. At WestCoast, that combination is very driveable and fast. Can't tell you what insert cause the tires were glued 4 years ago.
As far as inserts go, cut down TC inserts give you the most flexibility. Start out at 155-160mm in length. You can vary the hardness of the tires by the length of the insert. The longer the insert the harder the tire. I'm partial to the Muchmore Pink and the HPI yellows and greens. For the Tamiya tires, the Muchmore Pink with the Tamiya soft blue foam is my favorite combo. That's the insert that came in your Muchmore Premounts.
Sorry to all for the long answer, but, Pete, you can pm me cause we're just scratching the surface about tires. If you want more info on the other tire types and/or makes Tony and his Australian group seem to have the best handle on that. I try to stick with just what is available here locally.
Granpa is offline   Reply With Quote
Old 04-15-2010, 04:38 PM   #12063
Scooby Horton1's Avatar
What swaybar, shock oil, and spring should I start with for out door?
Trinity,EPIC,Oddy Racing,IRS,Sweep racing,Brown Engineering,Mugen USA,Team Xray,RC America,R.I.P. motorsports,Tekin,Customworks,Parma PSE,Ashford Hobbies,D&K Hobbies, TQ-wire,Local 69 Woodputters Union,Big Ant get well soon!!Quinn my BFF!
Dee Lee is a nut and I don't condone what he will say next!
Scooby Horton1 is offline   Reply With Quote
Old 04-15-2010, 05:27 PM   #12064
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Unless Tamiya came out with somethng new - there is no swaybar kit for the M05... The M03's can fit, but it needs to be bent to not bind the front end
pm Casey from Maryland -he had theM03's on his M05 at the Slowbirds
might wanna try shirt white fronts with blue rears - I heard that worked decently for some of the Brownie's guys outside, that's what I'll start the day with on mine...along with the kit oil- was too lazy to get different
stuff when I built mine
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 04-15-2010, 06:24 PM   #12065
Trader Rating: 22 (100%+)
Default shocks
Originally Posted by jcr View Post
anyone tried the Yeah Racing aluminum shocks from RCMart? http://www.rcmart.com/catalog/rc-dam...?cPath=389_390
Looks like one of the reviews said it has difficulties installing onto M03.... anyone have problems? What is the right length to get? 55mm?
A mate and myself tried them a year or so ago. We will never be so stupid again.
If you want low cost but good shocks buy the 3 racing ones.
Terry
Is your car slow..Xray it!.......FK05, M18, M18t
RexX
Assoc...T3,T4, B4
Team Ash is offline   Reply With Quote
Old 04-15-2010, 06:52 PM   #12066
jcr
Terry
May I know what's wrong with it?
jcr is offline   Reply With Quote
Old 04-15-2010, 08:42 PM   #12067
reenmachine's Avatar
Trader Rating: 26 (100%+)
So I gather from a search that the S800 body is for the short wheelbase configuration. Is the Abarth the way to go for medium wheelbase? Is there a long wheelbase M05 kit or do you have to run the new-style Mini Cooper body?
EDIT: Now I see the MiTo for long wheelbase...
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 04-15-2010, 08:52 PM   #12068
k_bojar's Avatar
You also have the Swift for 'm' wheelbase as well
Old 04-16-2010, 06:49 AM   #12069
academygaz's Avatar
I successfully converted my M03 intn M05 today. Used the parts leftover from converting the M05 to Xevo, so it was all the chassis parts and steering from the M05, mated to the suspension and gearbox of the M03. It was pretty straightforwards apart from needing to use M05 upper links because they are different to M03 (M03 ones use themselves for the screw thread, whereas the M05 ones pass through and screw into the chassis).
Apart from that, it was simple.
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 04-16-2010, 01:51 PM   #12070
Shangrila's Avatar
Default M05 bumper weight seller?
I seem to remember that one company was (planning?) on selling molded lead inserts to fit inside the M05's front bumper. Does anyone know who it was/is?
Did a forum and google search but couldn't find anything.
Shangrila is offline   Reply With Quote
Old 04-16-2010, 02:01 PM   #12071
stitchy's Avatar
I just fill mine with solder. Hey, it works.
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 04-16-2010, 06:17 PM   #12072
subaru73's Avatar
Trader Rating: 41 (100%+)
Default weight
tech racing made the part you are looking for the part # is mr5070
hope this helps i have one in my car.
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 04-18-2010, 01:54 AM   #12073
We found the yeah racing shocks leaked almost as fast as you could fill them. Theyhad 2 "O" rings and spacers in the base to seal the shaft. We found the actually worked as a pump when being used and pumped the oil out.
Terry
RexX
Assoc...T3,T4, B4
Old 04-18-2010, 02:06 AM   #12074
Auskenny's Avatar
Hey guys im buidling a M05 to start racing soon still need to pick my radio, can people tell me what radio they use for racing minis ?
cheers
Auskenny is offline   Reply With Quote
Old 04-18-2010, 02:09 AM   #12075
cannon's Avatar
Trader Rating: 35 (100%+)
The gun MWB body is the Ride Subaru Impreza .. but obviously not from Tamiya
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
