Like Tree136Likes
Old 03-28-2010, 05:48 PM   #11971
PaPeRo's Avatar
Originally Posted by Pro10noob View Post
I know it is a bit to high
I can't get it any lower due to the front body posts
And it is the HPI body.
Perhaps i am going to make special body posts to get it lower at the front
cheers Roy
Doesn't look too high to me. The front isn't supposed to look exactly like the rear on the Datsun due to the fenders being lower on the rear. The front and rear wheel wells are supposed to be different heights.
deans - dodgy electrics amps not sufficient
PaPeRo is offline   Reply With Quote
Old 03-28-2010, 07:09 PM   #11972
MD
MD's Avatar
Trader Rating: 112 (100%+)
HPI makes them.
MD is offline   Reply With Quote
Old 03-28-2010, 07:51 PM   #11973
Barry White's Avatar
Originally Posted by oldnwise View Post
Tamiya use a metric 0.6 pitch. You do not really have much choice as there are not many 0.6 pinions other than the ones Tamiya distribute
Plenty of choice:
If you want steel. RW Racing. Very high quality, much better than Robinson Racing. Harder, smoother and lighter. 10~30 teeth.
Also steel (but RW gots my vote). Tobee Craft. 14~34 teeth.
If you want aluminium Square 24~29 teeth. Kawada 12~28 teeth. (Square gets my vote but unusable becouse only starting at 24t)
HPI have it from 20~35 teeth but I don't know their material.
Barry White is offline   Reply With Quote
Old 03-28-2010, 08:19 PM   #11974
mangoman's Avatar
Originally Posted by Shangrila View Post
Many thanks for your response Tony!
How often do you remove them? I may have been king konging it tightening but the thread inside the pinion and the sidewall / end of the pinion (facing motor side) did crack right behind the grub screw hole. Mini racer next to didn't even have to look at it to tell me what happened. So it's happened here often enough for people not to want to use it.
I'd like to buy another one but it's expensive if it's going to fail again.
So, can anyone help with the pitch?
Thanks very much for the tire size info. Very helpful to know.
I know of other people who have stripped the thread on the hardened aluminium tamiya pinions. Including myself
For me strangely it stripped when i undid the grub screw to put the pinion on another car.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 03-28-2010, 08:20 PM   #11975
Trader Rating: 29 (100%+)
Hey Barry, did you ever find that diff screw you needed? I used the TRF416 diff screw that sidecarphil suggested and it works great! The 416 screw includes the metal T nut instead of the plastic one in the ball diff kit.
JustMe2 is offline   Reply With Quote
Old 03-28-2010, 09:04 PM   #11976
Allways room for improvement. I wonder if this works.
Old 03-29-2010, 12:29 PM   #11977
Shangrila's Avatar
Thanks to everyone who replied!
I will get an RW one.
RE the M05 rear alu upright. I have the 1.5 deg one on my pro. Are there alu Tamiya versions of 0 deg? Or only plastic?
I had ALOT of pleasure driving my M05 during Saturdays last winter carpet race. I lowered it to 2mm and 1 - it did touch often - and for the first time ever I could corner everything except a full U turn at full throttle. It was a fantastic feeling.
Shangrila is offline   Reply With Quote
Old 03-29-2010, 03:53 PM   #11978
tony gray's Avatar
Venom Racing have released their own version of the Hobbywing brushless system, just for Minis.
Read all about it HERE
tony gray is offline   Reply With Quote
Old 03-30-2010, 02:44 AM   #11979
Tim K's Avatar
Tamiya do an alloy 0 degree upright: 53380 TG10 Aluminum Rear Upright Set.
It will fit an M03/M04/M05 no problem.
I'm not 100% sure, but I think it uses 1150 bearings.
Tim K is offline   Reply With Quote
Old 03-30-2010, 02:58 AM   #11980
Kail's Avatar
Tony's is the HW 13T faster than Team Orion's 19T? In TITC, that motor was crazy fast!
Kail is offline   Reply With Quote
Old 03-30-2010, 09:10 AM   #11981
Stock M03 kits come with 0 degree plastic rears. TL01 upgrade rear uprights are toe in plastic as is the stock M03M ones. Not sure if they are 1.5 degree or 2.
Sydewynder is offline   Reply With Quote
Old 03-30-2010, 01:25 PM   #11982
tony gray's Avatar
Not sure, TITC was unrestricted gearing too so that would also make a difference in itself.
I'm sure Cannon will read this and be able to give a fair idea of a comparison between the two systems.
Old 03-30-2010, 06:27 PM   #11983
=FLIP='s Avatar
Trader Rating: 24 (100%+)
The orion motor is about the same speed as the 13 t hw with stAndard tamiya gearing
--------------------------HOBBYWING----------PROAMP LIPOS----------------------------
-EAD- Racing NEED SPEED GET SOME EAD-
=FLIP= is offline   Reply With Quote
Old 03-31-2010, 01:08 AM   #11984
mangoman's Avatar
No comment about deans plug already being fitted? Or is that normal on the hobbywings now?
www.smaracing.org
Old 03-31-2010, 01:56 PM   #11985
Hey... I have a m05 and have broken one of the stock dogbone driveshafts.... One of the pins snapped off... I don't really want I pay the 40 bucks my lhs wants for the upgaded universal shafts.... And I can't get the stock driveshafts through my lhs. What can I use as diveshafts? Is there any other option other than the stock or upgraded ones?
More power than brains!
associated tc4
associated t4
associated 10L3
ummm...go fast?
nitrofreak07 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
