Like Tree19Likes
Old 03-17-2010, 01:17 AM   #11866
i am getting a few PM's asking me how i get the M05 ball diff so tight and my Experiences with them SO ...........
This is how i got my M05 3Racing ball diff tight as hell and not stripping/snapping screws
I stripped it , sanded the plates added a good amount of asso fat and used a TRF416 bolt , nut and thrust washer
Add extra oil/asso fat to the thrust bearing and extra loctite to the bolt
Tightened it till it was really tight to turn the ball diff outdrives and then stuck it in the M05
Make sure when you fit the diff that the adjuster bolt is on the left side of the car , this i believe stops the bolt loosening
Drive it a few laps and see how tight it is , maybe you can get a little more on the bolt
sidecarphil1 is offline   Reply With Quote
Old 03-17-2010, 03:25 AM   #11867
colt1402's Avatar
Trader Rating: 84 (100%+)
Can we use back the stock m05 ball-diff thrust washer? I only managed to get the TRF416 bolt & nut.
*************************Addicted To RC*************************
colt1402 is offline   Reply With Quote
Old 03-17-2010, 03:51 AM   #11868
you can but mine colapsed after 2 runs
Old 03-17-2010, 12:14 PM   #11869
over gear's Avatar
Trader Rating: 15 (100%+)
Isn't the m05 ball diff thrust bearing the exact same bearing as the one in 416?
over gear is offline   Reply With Quote
Old 03-17-2010, 12:18 PM   #11870
@sidecarphil
Are you using a Tamiya M05 ball diff or a 3racing M05 ball dif?
Sydewynder is offline   Reply With Quote
Old 03-17-2010, 12:50 PM   #11871
Trader Rating: 29 (100%+)
fully rebuilt and he is running
3Racing ball diff
TRF shocks (mini type) with 300 oil all round
yellow front springs
red rear springs
2mm spacer on toe tierods (toe out)
Adjustable upper arms rear
3Racing steering mechanism
3Racing battery holder
Tamiya alloy motor mount
Tamiya DF03 heat sink bars
Tamiya Alloy steering connector rod
Titanium screw set
TRF servo saver
silvercan and stock speedo
Bionic batterys stickpack lipo
10g lead inside front bumper
M grip tyres all round with cut down touringcar inserts Swift wheels
Mini body shell
Here is Phil's set up from pg 785.
Started the build on my new m05 today, waiting until tomorrow to finish so I can get the ball diff.
JustMe2 is offline   Reply With Quote
Old 03-17-2010, 04:00 PM   #11872
Yes they are the same.
@JustMe2
Just want to clarify as post from others leads me to believe that there is some confusion as to what brand diff is use.
Yes I read 3racing from Phil
Old 03-17-2010, 07:19 PM   #11873
@JustMe2
Sorry, I wasn't trying to be rude or sarcastic. I wasn't sure Phil's set up had been found. Took me a bit to find it myself. I also asked about his set up for my new m05 as well.
Old 03-17-2010, 09:18 PM   #11874
No worries. Its all good. Just want to make sure everyone is on the same page.
Old 03-17-2010, 11:37 PM   #11875
@JustMe2
it was at one stage a 3Racing ball diff BUT i changed the screw,nut and thrust bearing to TRF416 items and the balls are ceramic soooo it is 50/50 now LOL
really reliable but still not in the car for the 6 hours race we have on sunday (vids and pics to follow)
Old 03-18-2010, 12:37 AM   #11876
Peter $'s Avatar
I have just bought the "Tamiya (#53345) Toe-in Rear Upright For TL-01/M03" and installed them in my M04 VW. But to my dismay the original bearings doesn't fit - they are too small!!
Whats up with that! ?
Well I searched this thread and on page 154 a guy had the same problem, but I couldn't really see which size bearing that will fit from the replies he got back then.
So to my question: Which size bearings should I buy so that it wil fit in my new Uprights (53345)?
Any help will be appreciated.
Cheers,
Peter
Peter $ is offline   Reply With Quote
Old 03-18-2010, 12:57 AM   #11877
Cheers,
Peter
You need 5mm x 11mm bearings.
Old 03-18-2010, 01:10 AM   #11878
Peter $'s Avatar
Thanks for your answer.
Is that the ones that Tamiya has named 1150 bearings?
Cheers,
Peter
Old 03-18-2010, 02:07 AM   #11879
tudor_47's Avatar
Cheers,
Peter
Yes that is correct.
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 03-18-2010, 02:45 AM   #11880
PaPeRo's Avatar
You are using 2.4mm balls correct?
deans - dodgy electrics amps not sufficient
PaPeRo is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
