Old 03-16-2010, 07:49 AM   #11851
J-VET's Avatar
Originally Posted by JustMe2 View Post
The m03 and m05 use the same gears in the tranny. Those gears look interesting. They appear to be just a gear and clip in the bag. I wonder what they attach to or how they are installed. Anybody used these gears yet?
There is another part you ned to buy. It replaces the gear that is molded to the spur on the stock set. I bought a Tobee craft spur only to find out about the other gear after taking my mini apart.
The spur gear is still in my tool box.
J-VET is offline   Reply With Quote
Old 03-16-2010, 08:04 AM   #11852
I just bought a set of 3Racing front knuckles for my M03, only to find out they don't fit and use different bearrings. The guy at HKS hobby told me that I had an older M03. I bought an older set that are bigger than the 3Racing ones and they work fine. The knuckles will be on fs forum tonight. What about the backs? I want to run 2.0 blocks but don't know if they will fit.
kingsfanrob is offline   Reply With Quote
Old 03-16-2010, 09:43 AM   #11853
Tsquare's Avatar
Originally Posted by Tsquare View Post
I recently built my M05 - need some troubleshooting help.
On throttle the car drives straight, off throttle the car moves left. I am running a new Tamiya ball diff and CVD's no "o" rings or foams in the cups. Any thoughts would be greatly appreciated. Suspension and steering are free (has new Tamiya aluminum steering ). This one has me baffled.
Bueller.......Bueller.......Anyone........Anyone.. ......????
Tsquare is offline   Reply With Quote
Old 03-16-2010, 10:09 AM   #11854
Chris Furman's Avatar
Trader Rating: 112 (100%+)
Bearings... You probably have a bad one on one side... Under acceleration it can handle the spin... But once you slow down the friction comes into play slowing down the one side. You will have to check all of them.. The ones in the axles first and next the ones on each side of the diff.
Chris Furman is offline   Reply With Quote
Old 03-16-2010, 12:44 PM   #11855
Tsquare's Avatar
I will check, did not think to go there the kit is new, maybe I have a bind - if that is not it - any other thoughts. I was thinking on-throttle the the front wheels will toe-in and of-throttle toe-out?
Old 03-16-2010, 12:49 PM   #11856
yeah there is 2 parts to them the "driven" part and the "driver" part
you need both of them , i think i will order all 4 pieces and test them on our outdoor track
sidecarphil1 is offline   Reply With Quote
Old 03-16-2010, 01:17 PM   #11857
Trader Rating: 29 (100%+)
Hey, if you stop hitting the boards the stock rear plastic 2* up rights work just fine. I need to replce the fronts with Al on my kids car, he eats the fronts from learning to drive without being ham fisted.
JustMe2 is offline   Reply With Quote
Old 03-16-2010, 02:24 PM   #11858
los limbos's Avatar
Originally Posted by sidecarphil1 View Post
i used the one from the TRF416
fit perfectly and mine is TIGHT !!!!! without stripping or snapping
Phill,
Do you got the part number for me?
los limbos is offline   Reply With Quote
Old 03-16-2010, 02:42 PM   #11859
Originally Posted by los limbos View Post
Phill,
Tamiya the part number is #51341
http://www.rcmart.com/catalog/rc-trf...w-p-27325.html
Wylie27 is offline   Reply With Quote
Old 03-16-2010, 02:53 PM   #11860
los limbos's Avatar
Thankx...
Old 03-16-2010, 05:46 PM   #11861
fleetmaster's Avatar
Trader Rating: 16 (100%+)
There have been a few mini veterans struggle with the 5.
It seems they get better as they loosen up. Most find they take a couple of hours to "run in ".
I had rear shocks sticking a little, not allowing proper droop. Made the car a pig.
Also , rear tyres with too big an air gap can make them wander like mad.
fleetmaster is offline   Reply With Quote
Old 03-16-2010, 06:30 PM   #11862
Source: http://mailboxck.multiply.com
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 03-16-2010, 08:09 PM   #11863
[QUOTE=rccartips;7146164]
BBBBBBRRRRRRRAAAAAAAAAAAAPPPPPPPPPPPPP!
Old 03-16-2010, 08:14 PM   #11864
scribbler's Avatar
Has anybody had any experience with the new ball dif for the M-05, and will it fit into the M-03?
scribbler is offline   Reply With Quote
Old 03-16-2010, 08:49 PM   #11865
The M05 ball diff will not work in the M03. The diff bearings are larger. The 2 diffs (Manta Ray and TA03) for the M03 will fit in the M05 with the included bearing adapters from the M05.
Sydewynder is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
SEO by vBSEO 3.5.0
