Old 03-15-2010, 10:34 AM   #11836
Trader Rating: 21 (100%+)
Default M04 Pinion size?
I'm just waiting for my EzRun 35A / 13T combo to arrive, but was wondering about what pinion size I should use.
It looks like the M04 only lets me run a 17T, 20T or 21T pinion. A 17T came with my kit, so I was just planning on using that one. Will the 17T be okay?
And what size (teeth wise) is the Spur? And is there anyway to change out the spur size? Since it seems to be built into the gear box, I would guess that answer is No, but figured I'd check anyway.
Steve420 is offline   Reply With Quote
Old 03-15-2010, 12:38 PM   #11837
los limbos's Avatar
Hello,
Can anywone tell me witch bold en nut from HPI they haved use with the Tamiya ball diff in the M05.
I can't find it back on the page's here.
Thankx,
Bart
los limbos is offline   Reply With Quote
Old 03-15-2010, 12:55 PM   #11838
Originally Posted by los limbos View Post
Hello,
Thankx,
Bart
i used the one from the TRF416
fit perfectly and mine is TIGHT !!!!! without stripping or snapping
sidecarphil1 is offline   Reply With Quote
Old 03-15-2010, 01:17 PM   #11839
Trader Rating: 29 (100%+)
A lot depends on the track you are running on and your driving. If it a small tight track the 17T might be ok to start, but with the BL, I would go with the 21T. You are correct, the spur gear is what it is and can not be changed.
JustMe2 is offline   Reply With Quote
Old 03-15-2010, 03:04 PM   #11840
the spur can be changed if it is the same gearbos as the M05/M03
there is a speed tuned gearset from 3Racing and . . . .
http://shopping.rcmodel.hk/advanced_...ort=3a&&page=5
(the 4 items half way down from Tobee )
i have no idea how they work as i am yet to buy them
the 3Racing ones are a bit hard and after a few batterys they start to get a bit noisy !!!
Old 03-16-2010, 12:34 AM   #11841
The m03 and m05 use the same gears in the tranny. Those gears look interesting. They appear to be just a gear and clip in the bag. I wonder what they attach to or how they are installed. Anybody used these gears yet?
Old 03-16-2010, 12:54 AM   #11842
over gear's Avatar
Trader Rating: 15 (100%+)
how do you build the M05 ball diff tight. i mean TIGHT. almost spool like.
over gear is offline   Reply With Quote
Old 03-16-2010, 01:52 AM   #11843
Drop of loctite and tighten the bolt and nut TIIIIGGGGGGHHHTTTTTT
Wylie27 is offline   Reply With Quote
Old 03-16-2010, 02:08 AM   #11844
Skitee's Avatar
How do keep from crushing the thrust bearing, I TIGHTENED mine down firmly once and the thrust bearing didn't even last for one run.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 03-16-2010, 04:45 AM   #11845
I used one from a trf and used bearing oil/ anti wear grease on it , no problems so far , it is 3 months old and still going strong
Old 03-16-2010, 04:49 AM   #11846
Does this body fit on a M-03?
http://shopping.rcmodel.hk/product_i...ducts_id=10519
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-16-2010, 05:25 AM   #11847
tudor_47's Avatar
Originally Posted by mikky32 View Post
Most available bodies are listed here as to if and how tehy fit the MR03 chassies
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 03-16-2010, 06:02 AM   #11848
Timbulb's Avatar
Yes I have it on my M03. Although you do have to trim the wheel wells out a lot to fit 60D tires.
Timbulb is offline   Reply With Quote
Old 03-16-2010, 06:08 AM   #11849
Thanks.
I have other tires that have a smaller diameter.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-16-2010, 06:57 AM   #11850
Hey mikky are you getting into mini racing ??
If so come to groningen this weekend and watch our 6 uurs race
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
SEO by vBSEO 3.5.0
