Like Tree200Likes
Old 03-13-2010, 01:37 PM   #11821
G-mini's Avatar
cheers for that just rebuilt the diff and found nothing wrong but i try it next friday and see how it goes
Ginge
DnV Racing
Sponser,Reality Racing/CML
G-mini is offline   Reply With Quote
Old 03-13-2010, 01:46 PM   #11822
tony gray's Avatar
Originally Posted by G-mini View Post
hi all i'm having a bit of a problem with my m03 i'm hoping someone can help?
Two weeks ago my m03 was planted i could nearly go flat out round the corners and it would go flat out down the straight and would go straight as a dart i was well happy with it, now its still great round the corners but as soon as a i put the power down the car goes to the left. i've looked all over the car and find nothing wrong.
i'm running 17.5Bl with a Ta03 ball diff,any help would be great
Cheers Ginge
The probability is that one of your outdrives has popped out of the diff on one side. Do you have the 'o' rings in the outdrives? Or is one of them badly worn?
This is the main purpose of those 'o' rings, to keep the outdrives properly seated. It's also possible that if there is looseness there that the splines have now started to strip.
tony gray is online now   Reply With Quote
Old 03-13-2010, 07:21 PM   #11823
Hi, just sharing. 1st Tamiya RC Open held inside SM Megamall. Exposing minis to lots of people. Hopefully more indoor mall races to come.
+ YouTube Video
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 03-13-2010, 08:35 PM   #11824
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
That looks awesome. Looks like you had a huge crowd.
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC Xti Altered Ego|Associated B5M|TT02|TA05|TL01RA|TL01|
f1larry is offline   Reply With Quote
Old 03-14-2010, 05:44 AM   #11825
MD
MD's Avatar
Trader Rating: 118 (100%+)
Malls may be a great venue for a race. With the economy slumping malls are looking for events that will bring in a crowd. Great job!
MD is offline   Reply With Quote
Old 03-14-2010, 06:55 AM   #11826
Hi f1larry, MD, yes hopefully some new drivers from the crowd. Tamiya is doing a good job.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
Old 03-14-2010, 07:07 AM   #11827
Starteur's Avatar
[QUOTE=tony gray;7131293]The probability is that one of your outdrives has popped out of the diff on one side. Do you have the 'o' rings in the outdrives? Or is one of them badly worn?
This is the main purpose of those 'o' rings, to keep the outdrives properly seated. It's also possible that if there is looseness there that the splines have now started to strip.[/QUOTE
Even when you have universals?
Do you still put them ?
No suspension binds?
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer -Tamiya F-104X1 Formula 1 Racer.
Starteur is offline   Reply With Quote
Old 03-14-2010, 07:34 AM   #11828
niznai's Avatar
[QUOTE=Starteur;7133577]
The O rings have a double role. One is as explained above, to keep in the dogbones if used. The second role is to keep in the diff outdrives if the older TA03/Manta ray version is used, as these outdrives are not held inside by anything. If you use the balldiff and universals there's no need for the rings. Otherwise you need them.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 03-14-2010, 09:22 AM   #11829
Default M05 Traction
Been running my M05 this morning fine top speed but slow off the line and through the infield and as we are running standard motors it difficult to catch back up again. running S grips all round will full additive and ca on the front walls. Guess my problem is purely one of lack of traction from rest / low speed. Using tamiya alloy shocks and white kit springs. Any suggestions?
Bosscat is offline   Reply With Quote
Old 03-14-2010, 10:21 AM   #11830
G-mini's Avatar
The probability is that one of your out drives has popped out of the diff on one side. Do you have the 'o' rings in the out drives? Or is one of them badly worn?
This is the main purpose of those 'o' rings, to keep the out drives properly seated. It's also possible that if there is looseness there that the splines have now started to strip.[/QUOTE
hi there
it had all new out drives and o'rings a couple of races ago, but i've gone all over the car and can't find nothing wrong, the suspension is free and not binding i've strip the diff and rebuilt it but there was nothing wrong with it.
but until Friday i cant properly test it
maybe i should call scooby doo coz its a real mystery
cheers for your help
Ginge
DnV Racing
Old 03-14-2010, 10:30 AM   #11831
niznai's Avatar
Diff slipping?
Team Greasy Weasel
Old 03-14-2010, 12:05 PM   #11832
post your set up on here and i will try to help with set up , are you racing on carpet ??
mine is the fastest of our track
sidecarphil1 is offline   Reply With Quote
Old 03-14-2010, 02:10 PM   #11833
Peter $'s Avatar
Originally Posted by Timbulb View Post
Not a very polite answer to follow that link, but thanks anyway.
But it's not a very updated or complete list is it? I mean I think I have heard of some other manufacturers like Carson and Kamtec that also make bodies that wil work on a M or L size M-chassis.
Anyone know of any?
Thanks,
Peter
Peter $ is offline   Reply With Quote
Old 03-14-2010, 04:27 PM   #11834
Hey Bosscat,
are you running the standard kit diff (gear diff) a ball diff or a Spool Diff?
If your running a ball diff how tight is it?
Wylie27 is offline   Reply With Quote
Old 03-14-2010, 09:36 PM   #11835
Tsquare's Avatar
I recently built my M05 - need some troubleshooting help.
On throttle the car drives straight, off throttle the car moves left. I am running a new Tamiya ball diff and CVD's no "o" rings or foams in the cups. Any thoughts would be greatly appreciated. Suspension and steering are free (has new Tamiya aluminum steering ). This one has me baffled.
Tsquare is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
