Like Tree110Likes
Old 03-11-2010, 03:04 PM   #11806
Originally Posted by trerc View Post
I run touring cars and 2wd offroad so I'm familiar with ball differentials but new to front wheel drive and from what I read you wanna 'tighten the crap' outta your mini ball diff which isn't what I'm used to doing so I was seeking some insight on ball diffs and FWD.
Also what the thoughts are on ball diffs over a gear diff in mini cooper, advantages and disadvantages of each, Thanks.
The reason to tightened the diff in these car as much as you can is to get the car to pull out of corners. When the front inside wheel lifts in a corner all the power is sent to the wheel with no traction. All you hear the whiz sound as the car doesn't really go. The problem with getting to like a spool is off power you lose alot of steering. If you can take a driving line that keeps the car flatter it will keep both wheels more in contact with the ground.
Sydewynder is offline   Reply With Quote
Old 03-12-2010, 05:21 AM   #11807
Originally Posted by shawnh View Post
I reckon you've answered your own question there Andy.
When using cvd's the o'rings not only bind the driveshaft but also limit the suspension movement on the right hand side.
Like you I have also removed them and run with no problems for the last 12+ months, so my assumption is they are there to act as a buffer when using the standard kit bones.
On a similar note has anyone tried these? CLICK
I've got some on the way but interested on any experiences so far. The blades look to be a good idea.
Those are exactly what I was looking for. I don't suppose anyone has seen them available from a U.S. source have they?
Thanks to everyone for the good info in answering my question. I never thought about the O-rings holding the diff cups into the diff. Makes good sense though. I'll try the fuel tubing trick.
Andy
woodys3b is offline   Reply With Quote
Old 03-12-2010, 10:43 AM   #11808
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default NOOB QUESTION ALERT: Mini with BL?
hey mini guys.. how well does the mini cooper hold up with a 21.5BL system installed? the normal BL esc, not the UBER fast tekin v203/LRP SXX stock spec speedos...
speedwise.. is it comparable to a good silver can, etc?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 03-12-2010, 11:35 AM   #11809
I don't have experience with these both installed in a Mini. However, I do have experence with both of them installed in a TA-05 and the 21.5 is considerably faster. If you use LiPo batteries, the difference is even more drastic. I don't think you would hurt your mini with one of these motors, but don't expect your buddies running silver cans to be able to hang with you.
In the mini, I have experience with the silver can and a middle of the road 27t brushed motor. The silver can is a bit slower than the 27t.
Hope this helps
Andy
Old 03-12-2010, 12:25 PM   #11810
over gear's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Granpa View Post
The difference is that a gear diff needs much more maintenance.
i always thought that gear diff is maintenance free?
over gear is offline   Reply With Quote
Old 03-12-2010, 01:12 PM   #11811
Yes and no. It will work with no maintenance almost forever, but will loosen up very quickly. I favor the gear diff on certain tracks, but have to spend more time keeping the right amount off "drag" in the diff action. A ball diff will stay "adjusted" much longer.
I guess it is really about how particular you are in your car set ups. Possesing only moderate driving ability, I'm very attentive to this sort of stuff to make up for the deficiencies in driving ability.
Granpa is offline   Reply With Quote
Old 03-12-2010, 01:13 PM   #11812
Talk to Craig Richter. He's got more experience than anyone else at Aliso.
Old 03-12-2010, 02:00 PM   #11813
Old Tech's Avatar
I agree with Grandpa. The gear diff just lossens up too quickly under racing conditions and you wind up giving up too much corner speed. I prefer a tighter diff for this reason...a smooth, flowing diff in a FWD car doesn't work well...for me anyway. As noted, the ball diff will hold its setting better.
Old Tech is offline   Reply With Quote
Old 03-12-2010, 05:31 PM   #11814
Trader Rating: 29 (100%+)
YAAAHHHHOOOOOOO!!!!!!
My TA03 ball diff and AW Grease showed up yesterday and today! No more diffing from my car!! Finally, some drive out of the corners. It's a shame that I had to order the diff from Utah and the AW Grease from Florida. Everyone local, including Tamiya USA, was out of stock. Time to get to work on my cars improvements!
Thanks for the info people!
JustMe2 is offline   Reply With Quote
Old 03-12-2010, 09:47 PM   #11815
Peter $'s Avatar
Hi guys,
Has anyone made a list of bodies that fits on a m-chassis car?
I have tried to make a list of bodies that fit the M and L versions (because I have an M04-L myself), but I know that it isn't complete (I only have Tamiya and HPI bodies for one).
So does a more complete list exist somewhere?
Thanks.
Peter
Here is my list:
  • Tamiya, Renault Alpine A110, TAM49338
  • Tamiya, VW,
  • Tamiya, Alfa Romeo Giulia Sprint,
  • Tamiya, BMW Z3 M, TAM50848
  • Tamiya, Mini Cooper S 2006, TAM51335
  • Tamiya, Suzuki Swift Super 1600, TAM51236
  • Tamiya, Porsche Boxster, TAM50754
  • HPI, Datsun 240z, HPI7210
  • HPI, Toyota Corolla Levin, HPI7213
  • HPI, Honda Civic Mini, HPI7024
  • HPI, Mazda Miata, HPI7205
  • HPI, Datsun 510, HPI7209
Peter $ is offline   Reply With Quote
Old 03-12-2010, 10:35 PM   #11816
Clayton's Avatar
Originally Posted by Peter $ View Post
Hi guys,
Thanks.
Peter
Here is my list:
  • Tamiya, VW,
try rc-mini.net, its the best listing i have found
Bro-Kin racing, Castle Hill Raceway
Clayton is offline   Reply With Quote
Old 03-13-2010, 03:14 AM   #11817
Peter $'s Avatar
Could you help me, I can't find any list on their website?
Cheers,
Peter
Old 03-13-2010, 04:44 AM   #11818
Timbulb's Avatar
You didn't look very hard...
http://www.rc-mini.net/joomla/index....fits&Itemid=59
Timbulb is offline   Reply With Quote
Old 03-13-2010, 10:05 AM   #11819
G-mini's Avatar
hi all i'm having a bit of a problem with my m03 i'm hoping someone can help?
Two weeks ago my m03 was planted i could nearly go flat out round the corners and it would go flat out down the straight and would go straight as a dart i was well happy with it, now its still great round the corners but as soon as a i put the power down the car goes to the left. i've looked all over the car and find nothing wrong.
i'm running 17.5Bl with a Ta03 ball diff,any help would be great
Cheers Ginge
DnV Racing
Sponser,Reality Racing/CML
G-mini is offline   Reply With Quote
Old 03-13-2010, 10:27 AM   #11820
Cheers Ginge
ball diff , mine did the same thing once
rebuild it and look at everything
sidecarphil1 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
