Like Tree1Likes
Old 03-10-2010, 04:25 AM   #11791
Great!
I just so happen to have a set of front axles looking for a new home.
Thanks guys.
Andy
woodys3b is offline   Reply With Quote
Old 03-10-2010, 05:36 AM   #11792
Trader Rating: 114 (100%+)
Question for you all.. I just started building the M05... Do the sway bars from the M03 fit?
Chris Furman is offline   Reply With Quote
Old 03-10-2010, 06:04 AM   #11793
Skitee's Avatar
No they don't
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 03-10-2010, 07:12 AM   #11794
The front yes, but not the back.
mariob62 is offline   Reply With Quote
Old 03-10-2010, 09:26 AM   #11795
How are people liking these compared to the M03?
Bodywerx_rc is offline   Reply With Quote
Old 03-10-2010, 11:00 AM   #11796
differant !!!!!
BUT i love it , quicker corner speed and lower C of G and whan you do alloy everything then it looks soooooo SWEEEEET
sidecarphil1 is offline   Reply With Quote
Old 03-10-2010, 11:26 AM   #11797
Trader Rating: 29 (100%+)
Don't waste the money. Build your car, run it and then see how you like it. The cars are so light and the suspension moves so little the bars don't seem to tweek enough to matter.
JustMe2 is offline   Reply With Quote
Old 03-11-2010, 05:27 AM   #11798
rccardr's Avatar
Steve Key- Shoot me an e-mail at rccardr@cox.net. Got your PM but I think maybe your e-mail addy is out of date. Unless you got my response and are ignoring it, which- given the content of your request- I sincerely doubt.
See you at Trackside in a month!
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 03-11-2010, 05:29 AM   #11799
Default O-rings Inside Diff Outdrive Cups?
What are they for? Why are they there? I'm using CVD's that don't allow the dog bone to float around. The O-ring seems to be too large and it pushes the drive shaft out into the hub bearings. This seems to be putting unneeded pressure on the bearings. To make matters worse, they aren't the same on both sides. One side is tighter than the other which makes one wheel pull harder than the other. Last night at practice, I got fed up with the whole thing and just pulled the O-rings out and ran without them. Everything seemed to work fine without them. So, back to the original question. Why are they they there? Am I going to screw something up by running without them?
Andy
Old 03-11-2010, 07:09 AM   #11800
Steven Key's Avatar
rccardr Steve Key- Shoot me an e-mail at rccardr@cox.net. Got your PM but I think maybe your e-mail addy is out of date. Unless you got my response and are ignoring it, which- given the content of your request- I sincerely doubt.
Thanks for the message, you're right something must be wrong with my email, I would never ignore a good looking guy like you
I sent a new message to the e-mail address above.
See you in a month.
Thanks,
Steve
Steven Key is offline   Reply With Quote
Old 03-11-2010, 02:09 PM   #11801
Andy
I reckon you've answered your own question there Andy.
When using cvd's the o'rings not only bind the driveshaft but also limit the suspension movement on the right hand side.
Like you I have also removed them and run with no problems for the last 12+ months, so my assumption is they are there to act as a buffer when using the standard kit bones.
On a similar note has anyone tried these? CLICK
I've got some on the way but interested on any experiences so far. The blades look to be a good idea.
Last edited by shawnh; 03-11-2010 at 02:36 PM. Reason: I'm stupid and carn't spell :)
shawnh is offline   Reply With Quote
Old 03-11-2010, 02:28 PM   #11802
I use the little foams from the top of the trf dampers
they are a little more squishy than the rubber Orings
Old 03-11-2010, 02:57 PM   #11803
trerc's Avatar
Trader Rating: 89 (100%+)
Default Ball Diffs
I run touring cars and 2wd offroad so I'm familiar with ball differentials but new to front wheel drive and from what I read you wanna 'tighten the crap' outta your mini ball diff which isn't what I'm used to doing so I was seeking some insight on ball diffs and FWD.
Also what the thoughts are on ball diffs over a gear diff in mini cooper, advantages and disadvantages of each, Thanks.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 03-11-2010, 03:24 PM   #11804
IMO you don't get the best diff action by "tightening the crap out your Mini ball diff". The best diffs are smooth and have a lot of drag. If you overtighten, you'll find the diff getting very "notchy". Not good.
As far as on track performance, there doesnt seem to a a SIGNIFICANT difference in properly BUILT and MAINTAINED ball diffs and gear diffs. Both work well. The difference is that a gear diff needs much more maintenance.
Lastly, do not lube the gear diff with anything other than a LIGHT application of antiwear grease. Do not stuff it with anything cause it will only work its way out a make your car a mess.
Granpa is offline   Reply With Quote
Old 03-11-2010, 03:50 PM   #11805
Andy
The orings are suppose to do 2 things.
1) Push out the dogbone to hopefully prevent the end of the dogbone in the axle from slipping out when the front wheels are turned.
2) To keep the outdrives from coming out too far and disengaging the spline to the diff. You hear people say they stripped out the splines to the drive cups sometimes.
If you don't have to adhere to TCS rules you can use nitro fuel tubing and cut a slice to replace the oring. These are softer and you can adjust the thickness to what you need. Use the stick part of a cotton swab (Q tip) inserted in the tubing to support it while you slice the tubing otherwise it will be hard to get an even cut when the tube deforms. Otherwise, as was mentioned the red foam things for the shocks will also work because they are more compressible.
Sydewynder is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
