Like Tree104Likes
Old 03-03-2010, 06:15 AM   #11671
CARD's Avatar
Originally Posted by JustMe2 View Post
Has anyone tried this HPI Mazda Miata body?
http://cgi.ebay.com/Mazda-MX-5-Miata...item563a16a4cc
Might have to go to the short chassis just to get a good looking body for my car.
COME ON TAMIYA, WAKE UP!!! Other manufactures have.
Btw, the HPI Miata body shell was more brittle than Tamiya's. IMHO
Commander At Riot Desert
Complete Adult's Repairing Depot
Can Anyone Refuse Doggie-style
CARD is offline   Reply With Quote
Old 03-03-2010, 07:32 AM   #11672
niznai's Avatar
My experience with HPI bodies is the same. I tried twice and both times they just shatterred in minor crashes as if they were made of glass. I gave up and actually sold the Miata body out of my kit straight away.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 03-03-2010, 10:05 AM   #11673
Originally Posted by billjacobs View Post
If you don't want an $8 aluminum handled screwdriver that will fit the tamiya screws perfectly, don't get one. The person asked for help in finding a perfect screwdriver for tamiya screws, and you can't get more perfect than that. Tamiya tools, just like hudy tools are expensive. If you can get a $24 driver for $8, that's even better.
Jeez.
Lighten up Francis
No one here peed in your corn flakes.
woodys3b is offline   Reply With Quote
Old 03-03-2010, 10:31 AM   #11674
Originally Posted by woodys3b View Post
After reading the last 100 pages of this thread, I started to build my M05. The upgrades I am using are:
2. Diff and CVDs. I'm happy with how the gear diff feels after assembling it with one extra shim and anti-wear grease and will probably not upgrade to the ball diff. However, I would like to use blades on the inside end of the cvd shafts. Are there any diff cups that fit into the M05 gear diff that have wider slots in them to accept the blades? Will this be the only reason I should upgrade to the Tamiya ball diff? Also, with the CVDs installed and the O rings in the diff cups, It seems that the O rings are too thick. They are pushing the CVD shafts out into the front steering knuckles too much. I even used the clear O rings as mentioned a few times in this thread. I'm tempted to Just remove them all together. Any suggestions?
Andy
If you don't have access to a mill you can use a Dremel and cut off wheels to open up the slots in the outdrives to accomodate the blades. We've been doing that here for awhile now. You don't even have to use the Tamiya blades. I'm using some X-ray ones that were in the spare parts box. Not a perfect fit, but it works just fine.
Not a big fan of the M05 ball diff as the out drives appear to be too soft and wear quickly. I'm probably going back to the TA03 diff and modify the outdrives to accept blades.
Granpa is offline   Reply With Quote
Old 03-03-2010, 11:25 AM   #11675
Trader Rating: 29 (100%+)
Jeez.
Lighten up Francis
BBBWWWAAAHHHHAHAHAHAHAHAHAHAHAHA!!!!!
Sorry, I was just amazed that Tamiya can sell a screw driver for $24, then clearance them for $8 and not feel guilty to publish they are making that type of profit, on a screw driver at that.
Thanks for the info on the HPI bodies. My son and I have the HPI Civic bodies now and they do seem thinner then most. Any other options for the mid(225mm) chassis or is the short(210mm) chassis good to run?
JustMe2 is offline   Reply With Quote
Old 03-03-2010, 11:54 AM   #11676
Old Tech's Avatar
Steady people...steady! I was just asking a tool question!
Thanks for the "JIS" tip...I didn't know that. I'll dig around for something cheap...though I don't mind paying $8 for the Tamiya version if I can't find one. One more question, do you guys keep both the #1 and #2 in your box?
Old Tech is offline   Reply With Quote
Old 03-03-2010, 02:02 PM   #11677
fleetmaster's Avatar
Trader Rating: 16 (100%+)
MWB : suzuki swift, fiat 500/abarth.
I believe ABC Hobby also makes a Honda Civic and a new Subaru WRX.
Check the rcmini website for others, or do a couple of web searches.
fleetmaster is offline   Reply With Quote
Old 03-03-2010, 02:43 PM   #11678
BadSign's Avatar
Trader Rating: 15 (100%+)
My HPI civic has drywall tape and shoe goo on the front inside- works like a charm...
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Old 03-03-2010, 02:44 PM   #11679
Mine too! Has great turn in!
Old 03-03-2010, 04:27 PM   #11680
trerc's Avatar
Trader Rating: 89 (100%+)
What servo are you guys running, I'm currently running a Futaba s9550 and may be looking to try something different, just poking for some ideas, thanks.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 03-03-2010, 11:50 PM   #11681
futaba 3003.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 03-04-2010, 03:41 AM   #11682
Fleetmaster,
I'm really diggin your avitar. Is that a real car or the HPI 510 body? The color reminds me of the Dodge Challanger Trans-Am cars back in the day. Any chance I could get a larger version of your avitar? This might be my next mini body. Imatation is the best form of flattery
Andy
Old 03-04-2010, 03:53 AM   #11683
Thanks Granpa,
Good advice. I'll give it a shot.
Andy
Old 03-04-2010, 04:00 AM   #11684
trerc's Avatar
Fleetmaster,
Andy
It's straight off HPI website and its an AWESOME looking body!
Old 03-04-2010, 04:15 AM   #11685
Anyone know if this body will go right on an M05? Wheelbase looks correct for a long wheel base chassis. What about width.
The HPI 911 cup racer body sure looks good as well. Same questions about that.
Andy
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
pyro18t
