Old 02-23-2010, 10:43 PM   #11581
niznai's Avatar
Originally Posted by Project D View Post
Thnx for the help
I was about to get the 05 but suddenly I came across the 03R Blue Edition and it looks so delicious lol.
When you say TC Balldiff, does it mean that the Hot Bodies TC ball diff fits perfectly for the 05 but not the 03? Why dont we use Tamiya Ball diff I think the TA03 ones fit.
The old design balldiff found in TA03 and the rest of them is a very clunky construction meant to fit inside older Tamiya cars across the entire range of hobbyist grade chassies they had at the time. It has various problems relating to reliability and even though it does the job, it is far from ideal. As explained above it can only be adjusted by taking the chassis apart which for a mini is not a two (or ten) second operation. Taking the chassis halves apart means taking out and puting back in the screws that go in plastic and eventually the plastic threads are stripped and you need a new chassis. Why bother? Apart from this, the TC style balldiff offers virtually infinite adjustability (as you probably know already) and doesn't need you take anything apart.
I did not check if any other TC balldiff fits, and I would guess no (or not without some creative engineering) but the Tamiya's offering is on par with the TRF balldiffs and that's a pretty high standard.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 02-23-2010, 10:57 PM   #11582
trerc's Avatar
Trader Rating: 89 (100%+)
Looking for Lipo for my m03, was wondering if anyone had used the Orion Rocket series packs yet? Look like a decent pack for the $
http://www3.towerhobbies.com/cgi-bin...&I=LXYCB0&P=ML
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 02-24-2010, 12:00 AM   #11583
Trader Rating: 29 (100%+)
Team Orion usually makes good stuff. So why put a Tamiya connector on a lipo? Yeah, I know it can be changed, but why?
JustMe2 is offline   Reply With Quote
Old 02-24-2010, 04:43 AM   #11584
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
the ball diff for the Cyclone TC won't work because its a pulley-based diff versus a gear-based diff...when everyone says a 'TC ball diff' they mean a diff styled like those you'd see in the 416 or the TC
and for the records, a TA03 diff IS a Tamiya diff and the TA03 and the Manta Ray diffs are the only 2 that will fit in a M03
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-24-2010, 05:39 AM   #11585
trerc's Avatar
Yea they also offer it with a Traxxas plug, both would be snipped off and replaced with a Deans. Looks like it'd be a good pack for the m03 and the price is right.
Old 02-24-2010, 06:45 AM   #11586
Atcom's Avatar
Why do people usually change the tamiya plug? It seems fine...
Atcom is offline   Reply With Quote
Old 02-24-2010, 06:54 AM   #11587
jcr
they're high resistence and can overheat and melt
jcr is offline   Reply With Quote
Old 02-24-2010, 06:57 AM   #11588
trerc's Avatar
+1
They are garbage
Old 02-24-2010, 07:10 AM   #11589
Timbulb's Avatar
The Traxxas is a great connector. If I didn't have 20+ connectors to change I'd switch to them.
Timbulb is offline   Reply With Quote
Old 02-24-2010, 09:20 AM   #11590
jcr
+1
They are garbage
Nothing like coming off the track and trying to remove the battery pack but find out that the connectors are fused together
Old 02-24-2010, 09:27 AM   #11591
Atcom's Avatar
If not tamiya connectors than wich one?
Old 02-24-2010, 09:31 AM   #11592
kwkride's Avatar
Deans
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 02-24-2010, 10:54 AM   #11593
niznai's Avatar
After using Deans for a number of years I moved on to Corally plugs. I still have a box of Deans lying around that developed a strange symptom. They did not make contact when pushed all the way in, so I had to back them off a hair. Very weird and eventually I got fed up. Simple is better. Please note, I said "Corally", not "corally-style". There's a lot of crap out there.
Team Greasy Weasel
Old 02-24-2010, 11:03 AM   #11594
trerc's Avatar
Yes, the Traxxas is a fine connector, my comment was directed toward Tamiya connectors
Old 02-24-2010, 11:13 AM   #11595
MrLesac's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to MrLesac
hey guys, I posted this on our local thread, but figured youd all get a kick out of it too.
from the TCS race this last weekend.
+ YouTube Video
Kevin --- Facebook.com/FormulaGraphics---
Exotek
Formula Graphics
MrLesac is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
SEO by vBSEO 3.5.0
