Old 02-19-2010, 08:18 PM   #11551
shangrila,
Is it around the right way?
which side is the screw head on?
Wylie27 is offline   Reply With Quote
Old 02-19-2010, 10:55 PM   #11552
oldnwise's Avatar
Originally Posted by Shangrila View Post
And why is the 416 screw not being used as well as the nut? It is only 3mm shorter and seems long enough to use?
The 22mm screw does not extend all the way through the nut in an M05 diff. You need to use thread lock on the screw/nut to stop it coming loose and the more contact between the screw and the nut the less likelihood of it loosening.
oldnwise is offline   Reply With Quote
Old 02-21-2010, 08:31 AM   #11553
Shangrila's Avatar
Well the ball diff seems to be designed to have that movement. The red (urethane?) sponges and the C caps on the inboard driveshaft end seem to be designed as dampers to keep the ball diff centered in the gearbox while giving some shock damping buy allowing some side to side movement. I guess there is sense to that, but it would certainly help if the diff instructions mentioned that the diff moves inside once the gearbox/chassis is sealed.
I think perhaps I overtightened it as it is now almost a spool. With one hand it will spin like a spool with the TCS 540 stock motor installed, with two hands it still takes a big effort to make them spin opposite directions / diff action.
I may try loosen it at the next race.
I raced the car all day yesterday in TCS. I missed the first 2 quals as i was still building it!! but made the 3rd and ended 3rd. This automatically meant I missed A main which was irritating after being up the night building, but was more relaxed and let me play with the car without pressure. The car is TCS rules set up with most of the Tamiya hops ups (but I forgot to buy the 1050 bearings for the front alu knuckles ). Carpet racing. I did cut away alot of the rear chassis and "no carry handles" installed. The car ran perfectly fine but understeered alot in the fast corners. To cure this I swapped the rear uprights over so that it had 1.5 toe OUT and this made the car very nice to drive. 1st, 2nd, 1st B main was fun but being mid field in A would have been more satisfying! But the car is built now so I can qual properly next month!
BTW, 2 of the M04 drivers (yes, our TCS allows all M chassis still, so top 4 spots are always M04 cars) ran with a sold front set up, swapping the front dampers for 2 rods! Seemed to have little impact on the handling. Those cars still came 3rd and 6th!
Thanks for the replies re the diff, all!
Last edited by Shangrila; 02-21-2010 at 08:33 AM. Reason: adding thanks for replies.
Shangrila is offline   Reply With Quote
Old 02-21-2010, 01:51 PM   #11554
tony gray's Avatar
BTW, 2 of the M04 drivers ran with a sold front set up, swapping the front dampers for 2 rods!
How the hell can replacing dampers for solid rods be TCS legal?.....
tony gray is offline   Reply With Quote
Old 02-21-2010, 02:18 PM   #11555
NT
NT's Avatar
Trader Rating: 21 (100%+)
Tamiya rod?
NT is offline   Reply With Quote
Old 02-21-2010, 02:46 PM   #11556
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by NT View Post
Tamiya rod?
Don't matter - can't alter the design or suspension geometry
So I'm stumped as well
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-21-2010, 02:56 PM   #11557
is there any extra screw for m-05 ball diff tamiya selling?
skyshen is offline   Reply With Quote
Old 02-21-2010, 03:28 PM   #11558
oldnwise's Avatar
HPI part A162 is a two pack of 2mm x 25mm screws which fit the Tamiya M05 Ball Diff.
HPI also have a 2mm x 25mm diff screw and heavy duty nut. Part is HPI73522.
Old 02-21-2010, 03:40 PM   #11559
C5R01's Avatar
Send a message via Yahoo to C5R01
Is there a Tamiya rep there, or is the house running TCS?
Current Cars:
Tamiya Garage:TB03; TA05V2-IFS; 414X #60;F104 V2;TA03r-s:TA03F:TA03R: FF01: FF03: M01: M03: M06: 1/14 Mercedes Semi truck- w/Reefer trailer ( fully functional): Tamiya Juggernaut 4X4X4, Tamiya RC Freightliner Cascadia Evo.; Honda City Turbo WR-02C; TRF102 F1
OTHERS:Kyosho 1/8th scale nitro Corvette C6R: Yokomo GT4 nitro, Slash 2WD,TA SCm5
C5R01 is offline   Reply With Quote
Old 02-21-2010, 04:58 PM   #11560
Yea, I also thought cutting material out of the chassis was not legal...
Tristar Racing is offline   Reply With Quote
Old 02-21-2010, 05:16 PM   #11561
C5R01's Avatar
I guess we will see, according to the rules seems like a bunch of cars should be DQ'd
Current Cars:
Old 02-21-2010, 07:40 PM   #11562
jcr
Is there a part number for the stock 3x32mm turnbuckle for the M03?
jcr is offline   Reply With Quote
Old 02-22-2010, 12:55 AM   #11563
Tim K's Avatar
Hi jcr,
Part number is 2500029.
I haven't got them listed on my site yet but price will be $3.50AUD
Tim K is offline   Reply With Quote
Old 02-22-2010, 08:45 AM   #11564
Atcom's Avatar
Does the cupracer body fit on the xevo ff conversion?
Atcom is offline   Reply With Quote
Old 02-22-2010, 09:11 AM   #11565
Shangrila's Avatar
Tamiya rules are the discretion of each national importer, so there are some variations globally. This series is in Central Europe.
Tamiya parts are allowed, motors are all hand out on the day (Carson, as these are the Tamiya EU (Germany HQ) agents stock motor, 540 silver can type), , 20T pinion, 21T M04, TEU101 speedos only with 3.5cm min wire length. Tires are limited to 60D ofcourse but Tamtech slicks are also allowed also if you choose.
This approach keeps the field active and growing. Play with rods, shocks, cutting if you want, it helps you learn and have fun.
Some of the top guys run in mini because its fun with this approach, and it lets less technical people learn from those guys. M04s will be removed next year tho, and hopefully a std brushless as the top guys can tune their handout motors better than the rest.
I am pushing for reverse grid myself, I think that is a great way to keep it fun.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests)
SEO by vBSEO 3.5.0
