Like Tree100Likes
Old 02-06-2010, 04:46 PM   #11431
I use the MPower 4000mah Lipo's. They fit nicely. I have had no troubles with them so far.
Wylie27 is offline   Reply With Quote
Old 02-06-2010, 05:10 PM   #11432
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by BadSign View Post
Out of curiosity, what LiPo do most of you feel works best in the cooper, since the "rouneded edges are required?
I've been using the Orion 3400 and 2400 packs, and both seem to work very well
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-06-2010, 05:15 PM   #11433
Toh WL's Avatar
so how about the Orca battery? anyone tried?
Toh WL is offline   Reply With Quote
Old 02-06-2010, 05:45 PM   #11434
tiko's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to tiko
Has anyone tried any of the HPI Cup Racer bodies on the M-05
tiko is offline   Reply With Quote
Old 02-06-2010, 11:24 PM   #11435
jcr
I've just seen the Datsun fitted onto a M05 today. Looks pretty cool but that body has a long hood and trunk so it makes the body seem very long.
jcr is offline   Reply With Quote
Old 02-07-2010, 09:08 AM   #11436
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
yep ive got the Toyota AE86, works beautifully, the Porsche 911, and the Datsun 510. All fit on the M05 and M03, but the 911 wont fit on the M03 due to the steering servo. Toyota is definately the best handling so far, Porsche pretty close and Datsun not far off, a little tall so makes the car want to roll more. The 280 does look long. I saw it on a M04 once.
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 02-07-2010, 10:27 AM   #11437
tiko's Avatar
Thanks guys I appreciate the info. I have to give does bodies a try. Axle, which one would you recommend more on the M03.
Thanks Tiko.
Old 02-07-2010, 11:12 AM   #11438
axle182's Avatar
Thanks Tiko.
Id recommend the Toyota AE86, looks like a drifter (very cool) and handles very well. Seems like itll take some abuse also.
Aaron "AJ" Freind
Old 02-07-2010, 12:54 PM   #11439
Send a message via AIM to minijosh Send a message via Yahoo to minijosh
Default Rebuilding my M03
Ok it's been years, no really years, since I've touched my Mini and want to get it race ready again. I know new gears and bearings will be installed but I need new steering arms from the servo saver out. What's a good servo saver to use with the Mini? I need links too from the saver out to the steering knuckles. What do you suggest?
http://rccarparts.biz/
Joshua T
minijosh is offline   Reply With Quote
Old 02-07-2010, 02:25 PM   #11440
Starteur's Avatar
Smile
I run Kimbrough mid size KP201 and for turnbuckles I use 10 x 32 mm Titanium ones from Tamiya.
This should fit your mini also, and you will have no problemo with this set-up!
Hope this helps.
Regards
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Old 02-07-2010, 02:34 PM   #11441
caltek1's Avatar
I would recommend getting the Tamiya alloy servo piece and the Tamiya high torque servo saver for the MO3. I have this fitted to my MO3 and it works a treat. Tamiya PNo's as per below.
54120 RC HT Servo Saver Alum Horn - M Chassis
51000 RC Hi-Torque Servo Saver - Black
The other alternate is to use a large Kimbrough servo saver and trim to prevent hitting the chassis at full lock. The other thing is by using a shorter servo saver you change the angle of your turnbuckles which will affect your steering. You can always use longer screws and spacers on your knuckles to make it standard again.
The Tamiya offering is far easier. The length of the turnbuckles will be dependant on which front knuckle you use. If using the Tamiya MO3R knuckle and outer hole, you will require long turnbuckles and for standard the usual shorter turn buckles.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 02-07-2010, 02:42 PM   #11442
tiko's Avatar
Thanks Axle
Old 02-07-2010, 02:48 PM   #11443
Core Creations's Avatar
Trader Rating: 93 (100%+)
Send a message via AIM to Core Creations
If anyone is looking for a nice M03...
Tamiya M03 Mini Swift TRF Blue chassis w/hop ups cheap!!
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 02-07-2010, 08:38 PM   #11444
jcr
Anyone find that the Xpress Mini rubber tires has a really soft sidewall? I'm using it on my front and rears right now, when they're new my car handles great but once the front wears a slight groove on the outside edge, my car traction rolls like mad. Recommend CA glue the edge of the front tire?
Old 02-08-2010, 01:42 AM   #11445
hi guys .. I just recently into Mini. I got a M-05 pro with L setup. I running Tekin RSpro esc is it programable with the 540J motor?
skyshen is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
