Like Tree57Likes
Old 02-02-2010, 05:11 PM   #11416
tony gray's Avatar
So....
Has the Xevo got company in the high-end FWD Mini stakes now?
From TOP Racing.
This front wheel drive chassis is designed as a more professional type chassis for the Tamiya FF02 class. The drive train is front gear driven, with the gear ratio & gears compatible with the Tamiya FF02 and use universals and wheel hubs from its bigger brother, the Photon. The suspension parts too are borrowed from the Photon as well as the rear bulkheads and differential. The car utilizes a super narrow and low CG chassis designed specifically for front wheel drive racing and uses the Photon LiPo battery balancing and guiding system.
And then a little further down...
T.O.P. are also planning to release a pro kit for the M05 class and Mini 4wd touring class by the middle of this year, called the Sabre Mini FD
tony gray is offline   Reply With Quote
Old 02-04-2010, 10:46 AM   #11417
stitchy's Avatar
Originally Posted by rccardr View Post
Sure: machine screws and shock sleeves (the short cylinder that fits into the bottom of older plastic Tamita shocks...or the kingpin sleeves from MO3R's...or just a short piece of brass tubing).
Have part # for these sleeves?
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 02-04-2010, 05:58 PM   #11418
rccardr's Avatar
No, I do not.
Call Gary Demory at Tamiya, he can tell you what the number is...
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 02-04-2010, 07:41 PM   #11419
Albert, this works fairly well. #50593 4x6mm flanged tube. I'll have to check out Doc's solution tho.
Granpa is offline   Reply With Quote
Old 02-05-2010, 11:18 AM   #11420
Starteur's Avatar
On both ends of the camber arm???????
What's the lenght of the machine screws?
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Old 02-05-2010, 03:14 PM   #11421
caltek1's Avatar
Trader Rating: 33 (100%+)
JustMe2,
I only use the HPI X patterns on the front and slicks rear on one track in Sydney and that is a high grip, Boral painted concrete surface. This is so the car will understeer and corner better. I did see another front tyre used last night which hooked up very well, but I haven't tried it yet. I will be making up a set of tyres and giving them a tryout next week.
For carpet here I am led to believe that the Tamiya M grips fitted front and rear work well. The front tyres need to be used and the new ones go on the rear. Inserts are the Tamiya firm black foam.
The best solution would be to ask the fast guy's at your local track what they run and how they setup the suspension on there mini's.
Regards,
Calvin.
caltek1 is online now   Reply With Quote
Old 02-05-2010, 03:17 PM   #11422
caltek1's Avatar
TFG,
The Top FWD mini could be a better prospect than the Xevo, especially if they have the droop problem sorted out and not having positive camber in the front. It still has the exposed front gears which can be a problem.
Later,
Calvin.
Old 02-05-2010, 03:18 PM   #11423
Originally Posted by tony gray View Post
Lol that drive train looks exactly like the M03/05. Don't run it on a dirty track...
redbones is offline   Reply With Quote
Old 02-06-2010, 12:55 AM   #11424
caltek1's Avatar
TFG,
Looks like I will have to contact the Top Importer and pre-order one of these before I head O/S.
I can't miss out on one them. It will give me something to play with when I get home. Perhaps this is what the Switch should/could have been.
Later,
Calvin.
Old 02-06-2010, 05:47 AM   #11425
sim600's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to sim600
Yay. New 239mm WB from Tamiya. Alfa Romeo MiTo
http://www.tamiyausa.com/product/ite...oduct-id=58453
sim600 is offline   Reply With Quote
Old 02-06-2010, 06:34 AM   #11426
MINT i want one
sidecarphil1 is offline   Reply With Quote
Old 02-06-2010, 11:29 AM   #11427
tony gray's Avatar
If you've ever had a Tamiya Mini Cooper, chances are the bodyshell came off THIS plug...
Old 02-06-2010, 11:34 AM   #11428
so why do they have the crap mould lines across the shell ??
thought it would be vacuum moulded
cool piccy though
Old 02-06-2010, 12:44 PM   #11429
Trader Rating: 29 (100%+)
Originally Posted by caltek1 View Post
JustMe2,
Regards,
Calvin.
Hey Calvin,
This is a new track and for now we are the fast guys even though we are just starting. Thanks for the info, it at least gives us a starting point.
Thanks.
JustMe2 is offline   Reply With Quote
Old 02-06-2010, 04:27 PM   #11430
BadSign's Avatar
Out of curiosity, what LiPo do most of you feel works best in the cooper, since the "rouneded edges are required?
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
