Like Tree19Likes
Old 01-18-2010, 05:37 PM   #11281
subaru73's Avatar
Trader Rating: 41 (100%+)
Default m05
Originally Posted by XanderBingo View Post
Do you know what the Tamiya part number is for these aluminium spring perches? I have been looking for some for my TRF dampers (42102) but can't find them. Any help is most appreciated. Cheers!
here you go part#49311 blue color ,84009 black color,
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 01-18-2010, 05:45 PM   #11282
gashuffer's Avatar
Trader Rating: 48 (100%+)
Get these 53876. They are the 1mm low down which will lower your ride height. The car will handle even better.√ You can get them much cheaper.
http://www.tamiyausa.com/product/ite...oduct-id=53876
T-Sal
gashuffer is offline   Reply With Quote
Old 01-18-2010, 06:21 PM   #11283
mcdogboy's Avatar
[GVIDEO][/GVIDEO]
Originally Posted by gashuffer View Post
Buy a M04. Problem solved.
Heh, got one already, but it's a LWB, no idea what's involved in makin' a shortie from it, now that I think about it though, think theres a bit on rcmini.
mcdogboy is offline   Reply With Quote
Old 01-19-2010, 07:55 AM   #11284
eevul's Avatar
Do you know if part #53876 will fit on the Tamiya Mini TRF (#54000) shocks?
eevul is offline   Reply With Quote
Old 01-19-2010, 08:57 AM   #11285
Starteur's Avatar
Yes i'm running them on my 54000.
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Old 01-19-2010, 10:45 AM   #11286
gashuffer's Avatar
The only differences on the M-chassis shocks is the length of the rod and bodies. Yes they will fit. I use them.
T-Sal
Old 01-19-2010, 01:15 PM   #11287
and they only come with plastic adjuster rings on the M chassis TRF dampers
sidecarphil1 is offline   Reply With Quote
Old 01-20-2010, 08:46 AM   #11288
eevul's Avatar
Thumbs up
Thanks for the reply guys.
Old 01-20-2010, 09:00 AM   #11289
niznai's Avatar
54000 come with the threaded TRF adjusters
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 01-20-2010, 09:42 AM   #11290
The adjuster rings on the 54000 threaded shock bodies are plastic though, not alloy. I've found that the plastic adjuster rings tend to move too freely, and adjust themselves during a race, so I've I replaced them with the alloy ones, which have a rubber o-ring inside, and stay in the position you put them in.
Toon is offline   Reply With Quote
Old 01-20-2010, 09:47 AM   #11291
niznai's Avatar
I'll check again.
That means you have to buy the rings separately. Dang. What's the part number and how much were they?
Team Greasy Weasel
Old 01-20-2010, 10:10 AM   #11292
rccardr's Avatar
No need for the fancy-schmancy rubber ring adjusters. Just put a thin coat of rubber cement (also known as contact cement) on the body threads and let it dry. You can still thread the adjuster back on, but the cement stays a little pliant and acts as a lock for the adjuster, while still permitting you to change the preload. Has worked for me for years.
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 01-20-2010, 10:24 AM   #11293
MD
MD's Avatar
Trader Rating: 106 (100%+)
rccardr - What a great tip. A simple, cheap solution.
MD is offline   Reply With Quote
Old 01-20-2010, 01:21 PM   #11294
tamiya anti wear grease on the threaded shock collar
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 01-21-2010, 06:26 AM   #11295
kwkride's Avatar
Last night I had a problem with my rear tires collecting carpet. Of course once they do this, they have no bite. The car works pretty good for the first few minutes and then my handling goes away completely.
I have an M03-M. I am running s-grips in the front and kit tires in the rear. These are fairly new tires, about 3 weeks of racing use. I use "jack the gripper" traction compound. This setup was working good two weeks ago.
I even tried running one heat race with no traction compound on the rear tires and they still had carpet stuck to them when it came off the track.
I cleaned the tires with motor spray before the evenings events, and once more between rounds. Any suggestions?
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
