Like Tree103Likes
Old 01-12-2010, 09:21 AM   #11251
Shake's Avatar
Hey all...
I'm looking for a piece that once was listed in rc-mini website...
It was some sort of droop limiter for m03 chassis, but I haven't been able to find it....
Can anyone tell me the part number/brand?
Thank you!
Shake is offline   Reply With Quote
Old 01-12-2010, 07:23 PM   #11252
edwintklee's Avatar
Trader Rating: 23 (96%+)
Originally Posted by Shake View Post
Hey all...
Thank you!
i think it finish selling, i got a lightly use set, pm me if you need them.
I am a Red Star, Blue Star, Fans......
edwintklee is offline   Reply With Quote
Old 01-12-2010, 07:28 PM   #11253
RaceAce701's Avatar
Trader Rating: 84 (99%+)
could you post a pic
id b interested to see how it works
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 01-13-2010, 03:05 AM   #11254
Hi, just sharing some M05 tuning tips that work for me. Hope it helps. ty.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 01-13-2010, 05:50 AM   #11255
Default rccartips
Great stuff. We race indoor carpet oval. About 140ft race line. Any help for oval would be great. Some of my concerns are shocks, springs, and oil. I know i have to go out and see how it handles, but any thing would be helpful.
nc state is offline   Reply With Quote
Old 01-13-2010, 06:37 AM   #11256
hi nc state, for oval i would probably wedge it. example if running counterclockwise, ride height 3mm left side, 5mm right side, weight heavy on left side. soft springs left side, hard springs right side. hope this helps.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
Old 01-13-2010, 06:42 AM   #11257
i have the original TRF dampers on my M05 and i use 5mm spacers in them
what do you use ??
i use the mini springs also
what thickness oil do you use in them ???
sidecarphil1 is offline   Reply With Quote
Old 01-13-2010, 07:09 AM   #11258
hi sidecarphil1, I use the TRF mini shocks with no inside limiters. oil anywhere from 35wt to 60wt depending on track and temp.
I think your TRF (long) with 5mm spacers is good.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
Old 01-13-2010, 09:22 AM   #11259
Default rccartips
Thanks for those tips. The other question i have is about tires. The tires that came with the kit have 42214-39244 printed on the side. I bought a set of "M" tires. These tires have the same no. on them. So i am a little confused.
Our track is a high traction carpet. I will be replacing the shocks with TRFs.
Thanks for your help.
NC state
Old 01-13-2010, 10:08 AM   #11260
Ray k's Avatar
Trader Rating: 46 (98%+)
NC state
The kit tires has those numbers ,but only those numbers. With M-grips ,S-grips and Type A's these logo's will also be molded on the sides of the tires. So your M-grips should have some number and the words M-grip on them .
Ray k is offline   Reply With Quote
Old 01-13-2010, 12:50 PM   #11261
Default rccartips
I found the letters "M" grip on the side of the tire. My eye sight must be going away. Thats what happens when you get old. Things dont work like thay should when your young.
NC state
Old 01-14-2010, 11:46 AM   #11262
tony gray's Avatar
An old school Toyota MR2 shell in 210mm from Team Atlas. Should fit an M05, forget about an M03 though..
tony gray is offline   Reply With Quote
Old 01-14-2010, 09:31 PM   #11263
doriftu's Avatar
what type of grease is recommended for the M05 ball diff?
AW grease?
tamiya diff grease?
Assc Stealth diff grease?
Thanks!
six-shifter.blogspot.com
supercharged-e36.blogspot.com
doriftu is offline   Reply With Quote
Old 01-14-2010, 10:09 PM   #11264
niznai's Avatar
Silicone on the big balls, AW on the thrust bearing.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 01-14-2010, 10:12 PM   #11265
caltek1's Avatar
Trader Rating: 35 (100%+)
doriftu,
I used AW grease on the diff plates and 3mm balls. However I first sanded the diff plates to make them flat and I used Much More Thrust bearing grease on the thrust. I changed the balls to the carbide 3mm Tamiya balls.
Make sure you do not over tighten the diff nut. I have already stripped a 2mm locknut, split a thrust bearing and snapped a screw.
I am now trying some other Tamiya parts in the MO5 diff, which are stronger.
Later,
Calvin.
caltek1 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
