Like Tree23Likes
Old 01-11-2010, 01:31 AM   #11236
niznai's Avatar
Originally Posted by 1101 View Post
Im not an expert, but Ive been running MuchMore Sweeps. Really good price (for a pack of 4), heaps of grip & outlast any of the tamiya tyres Ive tried
Ive a 9T brushless, so I was going through a pair of Tamiya tyres every other session. Still on the same set of Sweeps.
http://www.rcmart.com/catalog/rc-min...?cPath=35_1385
You're running outdoors on tarmac, I guess?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 01-11-2010, 03:15 AM   #11237
Atcom's Avatar
I changed the tire insert to softer ones recently and i noticed that it doesnt zpin out of controll anymore in a corner!
Atcom is offline   Reply With Quote
Old 01-11-2010, 04:39 AM   #11238
caltek1's Avatar
Trader Rating: 33 (100%+)
Generally we run a harder tyre compound on the front and a softer on the rear. (example: Spice 36 front, 28 Rear) The type of insert you use will be dependant on the grip conditions of the track. The sweeps I have only ever used as a rear tyre with a firm insert.
I have found that I use firm inserts front and back on my cars. Normally a 5mm medium spice insert in the front and a 5.5 or 5mm Spice insert in the rear. I have found this combination of inserts to work on most tracks and in different tyres.
It all comes back to a little experimentation or asking the fast guy's at the tracks you visit for some assistance. I do know some people will not share, but they are normally the ones you upset when you beat them on there home track.
Some tyre choices will require you to change your basic car setup. I do that last. My tuning method is tyres and inserts first then car setup.
My thoughts only. Happy Racing.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 01-11-2010, 04:53 AM   #11239
Default Mo5
Thanks for the reply. I will be running on indoor carpet oval. Have never
run road coarse. This is all new to me.
nc state is offline   Reply With Quote
Old 01-11-2010, 05:17 AM   #11240
Default mo5
CALTEC1,
Thanks for suggesting that web site to go to. Alot good info there.
I am in North Carolina, USA.
This is good stuff.
NC State.
Old 01-11-2010, 09:31 AM   #11241
Originally Posted by sidecarphil1 View Post
2 kids at our club run them !!!!!
they are shite , no grip and smaller then the tamiya , thus no top speed
i use M grip front and S grip rears , that combination works well
Oh, I dunno there, I was using these exclusively purely because they are so cheap over here in the UK. I actually thought they were OK on carpet gripwise once they'd had a lap or so under them. Now I've found a reliable source of M-Grips though I've stopped using the Ansmanns as I agree, they do take away a little too much top end and as the previous poster said they are super brittle, I've actually had a rim come off the centre whilst cornering WITHOUT hitting anything - the chrome plating was actually thicker than the plastic.
Mini35 is offline   Reply With Quote
Old 01-11-2010, 09:37 AM   #11242
Default What have I done...
OK, I'm paranoid but now I've ordered a Xevo I've suddenly been racked with guilt. At present our club is happily running a mix of M03's and M05's. We have no "rules" as such but everyone seems to have stuck to brushed motors and cheapy speedos, and we are all having a good laugh, the cars being fairly evenly matched. My concern is that if the Xevo performs as I hope it will, have I unintentionally destroyed the status quo? I wish I'd had this thought before I clicked "checkout" on the RC Mart site.
On a side subject, will any RW Racing 0.6 module pinion fit a Xevo or do I have to stick with the rubbish Tamiya alloy offerings (I do have one "hardened" Tamiya Hop-Up 20T though)?
Old 01-11-2010, 10:38 AM   #11243
Starteur's Avatar
Hi,
I'm looking for the lightest servo to put on a M03, in order to remove some weight on top of the car.
Any suggestions?
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Old 01-11-2010, 11:25 AM   #11244
hey, good guess.
1101 is offline   Reply With Quote
Old 01-11-2010, 12:19 PM   #11245
caltek1's Avatar
Default Xevo
Mini35,
The Xevo can be geared the same as a MO3/MO5. Yes you will have to use the Tamiya pinions.
We have Hobbywing 13T brushless systems fitted to our cars here in Australia. These are awesome and provide equality in performance for all. We do not have the problem with fast black or silver cans.
In testing we have done using the 3Racing speed gear set 33T spur and 23T pinion the car is very fast. We have not had it traction roll at all, the rear end will slide. This is on a asphalt surface. The only thing we have found is you have to apply the throttle gently otherwise the car spins the tyres and sort of hops before mellowing out. We believe this is because of the large amount of droop in the front end.
I would not feel guilty, especailly if you gear with a 20T pinion. We have ours setup at 225mm length.(medium)
Tyres
We have found that the mini express tyre fitted to the rear with a firm insert works well on mini's on carpet. The frontfor speed you need to use M grips or on a tight track the Kawada or HPI M grips work well also.
Regards,
Calvin.
Old 01-11-2010, 12:24 PM   #11246
caltek1's Avatar
Starteur,
Comes back to how much do you want to spend on a servo. I know some who use the Futaba 9551 servos which are compact, light and also very fast. I have not used one of these on an MO3, however I have one fitted to my MO5.
I have heard of people using 1/12 scale servos, but I think they may not survive a large hit.
I would be inclined to use either a 9550 or a 9551. You can turn the steering down if they are too fast.
CYA,
Calvin.
Old 01-11-2010, 12:58 PM   #11247
Starteur's Avatar
Thank you Calvin,
There is something I don't understand, the 9551 servo is heavier than my 3004,
so I will not remove any weight from the high part of my car.
9551= 1.6 oz or 45.35 grams
3004= 1.3 oz or 36.85 grams
I would like to remove some weight from that part of the frame so I have more tuning options and a less tip-over car.
So any suggestion is welcome
Best regards
Old 01-11-2010, 01:10 PM   #11248
Originally Posted by Team Ash View Post
I had one a while ago on an M03. It was a perfect fit and the best looking of all my bodies. I only had it for show and it attracted lots of attention. I will definately be getting another one.
Terry
this is my new one
want the TT-01 rear posts to lower the rear body height
cool body fits first time and looks MINT in retro pale blue
sidecarphil1 is offline   Reply With Quote
Old 01-12-2010, 12:07 AM   #11249
Trader Rating: 22 (100%+)
Default Mini Ute
Very nice. I love these utes.
Is your car slow..Xray it!.......FK05, M18, M18t
RexX
Assoc...T3,T4, B4
Team Ash is offline   Reply With Quote
Old 01-12-2010, 01:10 AM   #11250
niznai's Avatar
hey, good guess.
Yeah, those tires aren't any good on carpet. I've tried them.
Team Greasy Weasel
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
