Like Tree200Likes
Old 01-06-2010, 09:54 PM   #11206
jcr
Originally Posted by RaceAce701 View Post
here you go
thanks, looks like around 1-2mm on each side of the rear?
jcr is offline   Reply With Quote
Old 01-06-2010, 10:28 PM   #11207
RaceAce701's Avatar
Trader Rating: 86 (99%+)
yep
thr front tires shouldnt rub at all but the rears might barly rib
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 01-07-2010, 04:52 PM   #11208
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
Just finished building a mo5 chassis,car seems to have loads of front toe out with the 2mm spacing between the toe links.Is this how you guys run them? Or do i need to be putting it to 0* or -1* toe in?
TIA
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 01-07-2010, 07:57 PM   #11209
TIA
It seems to be the way most of the guys down at my local track run their minis... Plenty of toe out.
rnd_tang is offline   Reply With Quote
Old 01-07-2010, 10:23 PM   #11210
niznai's Avatar
Default Finally!!
Well, it took almost a week but it's DONE! Tamiya have outdone themselves with this shell (again). There's an extra polycarbonate moulding with the rear diffuser, light buckets and some other bits to use if you're into detailing to the Nth degree. Difficult to cut accurately too.
The emblem on the top alone took me three days to paint (rattle cans and masking tape job). All the stickers are for decoration, but if peeled off, the car has been painted in the correct colours underneath (window frames, chrome, white strip at the bottom, lights are clear so I can use the light kit later if I want, etc). The colour looks flat because of the artificial lighting and the crappy camera flash. It is in fact a really nice metallic green created with Tamiya fluoro green backed with bright silver and interlayered with Lame Flake. Spot the mistake on the Abarth emblem and you get the prize.
Car has all the upgrades I consider useful, and drives perfectly straight out. It cost a pretty penny though with TRF shocks, balldiff, all aluminium steering, stainless steel hingepins, ballbearings, front and rear aluminium uprights and turnbuckle camber links.
One suggestion to people hwo complain about front toe-out. Drop the ride height a bit and it will take some of the toe out. It will improve the handling too. Mine sits at about 5mm and I like it. With the kit shocks (revolting items, those) it is considerably higher. I didn't use any o-rings int eh TRF shocks to achieve this, but have a minimum of preload on the springs, used short shock shaft ends screwed in all the way. I use a stick pack Lipo with dimpled bottom and a strip of lead taped to it.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 01-08-2010, 08:42 AM   #11211
I like a challenge, so I had a closer look at the pics...
On the roof logo, under the 'Abarth' text, you have the 3 colours of the Italian national flag as red/white/green left-to-right, but it should be green/white/red (as on the rear license plate decal).
I wouldn't worry though, as no-one will notice unless they're looking for it, and it doesn't detract from a good looking bodyshell.
I'm not a big fan of the standard Tamiya Fiat 500 bodyshell, but the Abarth version looks better. Although I'm lazy, so I wouldn't even try replicate the Abarth logo myself, I'd just buy a pre-printed vinyl one like this (http://cgi.ebay.co.uk/Fiat-Abarth-st...item2554243f05).
Toon is offline   Reply With Quote
Old 01-08-2010, 08:52 AM   #11212
niznai's Avatar
You bastard. Congrats. You get the prize for the biggest anorak without a life. Your certificate will arrive in the mail in four to six weeks.
Yep, that's it. It is because I flipped the mask in the computer before cutting and then looked at the flipped image to paint it. Was high on paint fumes too.
I didn't really like the wya the colour turned out. I have used the technique int he past and I turned out better colours, but it is starting to grow on me.
There are numerous other imperfections, difficult to spot in such low quality pictures, but I am not that big a paint nerd nor do I hold delusions of grandeur. Come to think of it, it sure is a lot of time spend painting a shell. Dang.
The car goes like stink though, and that's the most important point for me.
Team Greasy Weasel
Old 01-08-2010, 08:59 AM   #11213
I only saw the 'mistake' because I compared it to an Abarth logo I found online, I wouldn't have had a clue otherwise. I'm pretty good at spot-the-difference puzzles though!
And if you use the bodyshell for racing, you won't notice or care about any 'imperfections' after a couple of races. Or maybe that's just my bodyshells, they do tend get beat up a bit...
Old 01-08-2010, 11:09 AM   #11214
niznai's Avatar
Keep persevering. My shells used to get beaten up quite badly in the past too, but as I got older they tend to keep in shape better these days. Some say it's skill, hehehehe!
Team Greasy Weasel
Old 01-08-2010, 01:47 PM   #11215
volracer's Avatar
Send a message via ICQ to volracer
Wink
One of the first lessons I learned when started racing many years ago was: "Old age and treachery overcome youth and exuberance every time".
volracer is offline   Reply With Quote
Old 01-08-2010, 01:57 PM   #11216
Not every time
Granpa is offline   Reply With Quote
Old 01-08-2010, 04:58 PM   #11217
Thanks for the advice about the toe in guys,i ran the car for tonight for the first time but it wasn't to great but its got plenty of potential.What kind of oil/spring set ups are you lot running? Were running on low-medium traction carpet with lipo/tamiya black can motors.
Old 01-08-2010, 11:30 PM   #11218
niznai's Avatar
Wow. You're gonna have some issues there. Drop the ride height as much as you can. Use a low profile servo and add lead under it mercilessly. Add lead under the battery if it has dimpled bottom. Use a very soft oil (I use 10wt) with three hole pistons (TRF mini shocks). The idea is to let it roll gently into the corners rather than breakaway suddenly and traction roll. A little bit of camber is what I would use too if the problem still appears. Use liftoff oversteer to hook it around corners in the tight infield (if it is the case at your track). Start with M-grips on the front and S-grips on the rear. Have another pair of M-grips handy for the rear in case you need them.
We should have a thread with pearls of old (or middle aged) folks' wisdom. I think there's plenty of us but don't expect me to be a hardcore contributor. Wisdom is not my forte.
Team Greasy Weasel
Old 01-09-2010, 05:16 PM   #11219
tony gray's Avatar
Latest 210mm SWB Mini shell from Spice.
A mid 90's Toyota Starlet.
tony gray is offline   Reply With Quote
Old 01-09-2010, 07:35 PM   #11220
Niznai,
Were not allowed to use slicks at our club will the M grip radials be ok? I take it there better than the kit tyres? And are M's softer than S's?
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
