Like Tree4Likes
Old 01-03-2010, 06:33 PM   #11191
Starteur's Avatar
Thank you Calvin,
What I was refering to was the front kit for the M05 that was dicsussed in this thread earlier this year, I just wanted to fit those to my M03 to be TCS legal, could I build one set and still be legal?
Thanks again
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Old 01-03-2010, 08:54 PM   #11192
caltek1's Avatar
Trader Rating: 33 (100%+)
Starteur,
There is no front set for the MO5. It was a mis understanding by some who jumped to the wrong conclusion when it was to be released.
For TCS you would have to use the kit provided part on both the MO3 and MO5.
The set was an adjustable set for the rear that can be used on both the MO3 and MO5. This is included with the MO3R and MO5 Pro rear 1.5 alloy degree hubs.
For TCS the set would be legal on the rear provided it is constructed and used with the correct length. These are with the instructions. It is an approved Tamiya hop up. I do believe that the length would be no longer than the kit part?
I can not be exact as we no longer have TCS races in Australia.
Atcom,
RC Mart have them listed at US $70 or 80. They were in stock last week.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 01-03-2010, 08:58 PM   #11193
Official's Avatar
something to consider when getting the Xevo from RCMART.COM
They keep asking for document for address confirmation even if you are paying thru paypal. Asked them many times and with many mail bounch back after sending them a address confirmation document. Money was deducted from my account for a week and the still ask for confirmation. Very suspicious...
Ordered 3 sets of Xevo from them 2 weeks ago till now there is still no tracking number given and money was deducted.
3 cents worth.
Chassis :4WD = CEFX Photon,TA-05|2WD = Xevo, M05PRO, FF-03Pro, Kysho Evola M3, Kyosho V-One RRR Shimo, Team C TC02
ESC :Brushless - Tekin RS-Pro, Keyence Tachyon|Brushed - Tekin FX-Pro
www.hiro-seiko.com ; www.cefx.net
e-mail: officialracing@gmail.com
Official is offline   Reply With Quote
Old 01-04-2010, 05:11 AM   #11194
asw7576's Avatar
Originally Posted by Atcom View Post
I had to cut of some of the plastic in the corners. The car is still very stable and does not bend in the middle.How can you put pictures in the reply without attaching them? Attaching files is really problematic. It fails at the second picture! Thanks!
Wow.... look like a warzone....... I think I 'll go with 4000mah 25c stick battery.
Thank you for showing the battery slot though ....
about attaching photo :
first you need to open account at photobucket, free of charge.
2nd, you need to upload your picture to photobucket.com
3rd, you need to link up the picture image you want to show in this thread.
Old 01-04-2010, 07:07 AM   #11195
Atcom's Avatar
Thanks... What hop ups do you use in your car?
Atcom is offline   Reply With Quote
Old 01-04-2010, 08:57 AM   #11196
asw7576's Avatar
I use longer titanium screws all around ( 3x12mm and 3x18mm ), Three degree rear toe in uprights, carbon graphite rods for internal gear shaft holder, TRF dampers, and Tamiya slicks.
Old 01-04-2010, 11:53 AM   #11197
Starteur's Avatar
Hi again,
Are all of Yeah Racing's batteries ROAR legal?????
That what they advertise on RC Mart's website.
And I can't find more than the 3200 on ROAR's List.
I need to know before buying.
Best regards
Old 01-06-2010, 12:52 AM   #11198
Default TA03 ball diff is causing me issues
Hi there. The TA03 ball diff is causing my mini to pull either left or right under full power (9T Ezrun BL). I tightened it as much as I dared without breakng it.
The old gear diff didnt have this issue. Any ideas on what I need to do ??
Is the motor just too much for this diff??
I may have to put the old diff back in.
1101 is offline   Reply With Quote
Old 01-06-2010, 01:03 AM   #11199
caltek1's Avatar
What was the old diff? How tight have you made the TAO3 ball diff? If you made it to tight it may cause the symptoms. The same if the universal is binding on the o ring in the diff cup. Try a thinner o ring and see if that works.
The TAO3 ball diff is usually very good, even when you add an extra cone washer to make it tighter.
Good luck,
Calvin.
Old 01-06-2010, 05:04 AM   #11200
mild seven's Avatar
Trader Rating: 62 (100%+)
Send a message via MSN to mild seven
Originally Posted by Starteur View Post
Hi again,
Best regards
only the YR 3200 stick packs are legal. rcmarts ad is a bit misleading.
mild seven is offline   Reply With Quote
Old 01-06-2010, 02:20 PM   #11201
Starteur's Avatar
Thanks you very much.
Starteur
Old 01-06-2010, 06:18 PM   #11202
jcr
I'm interested in getting the HPI Honda Civic mini body, but was reading RC-Mini and it said it doesn't fit so well on the M03 because it's not wide enough. Was wondering is it not wide enough all around or just one end? And how much narrower is it compare to the M chassis?
jcr is offline   Reply With Quote
Old 01-06-2010, 07:31 PM   #11203
RaceAce701's Avatar
Trader Rating: 83 (99%+)
i just wounted mine and its only a few mm's narrower but it still fits good ill post a pic later
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 01-06-2010, 07:31 PM   #11204
jcr
a few mm like 2-3mm or more than 5mm?
Old 01-06-2010, 08:17 PM   #11205
RaceAce701's Avatar
here you go
Tamiya mini cooper-dscn1194a.jpg   Tamiya mini cooper-dscn1190.jpg   Tamiya mini cooper-dscn1191.jpg   Tamiya mini cooper-dscn1192.jpg   Tamiya mini cooper-dscn1193.jpg
Alex "ACE" Kubilus
ACE design works
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
