Like Tree81Likes
Old 01-02-2010, 01:06 PM   #11176
gtfour93's Avatar
Trader Rating: 22 (100%+)
Default M-Chassis battery
Originally Posted by asw7576 View Post
Hi friends,
what lipo battery that can fit into M04 and M03's battery slot without modification ? ..... hopefully something like team orion 3800mah 30c ?
[ I measured the widest point of M04 and M03's battery slot are 46.5mm and 48.5 mm respectively ].
I use this. Fits perfect & good power.
www.activrc.com
gtfour93 is offline   Reply With Quote
Old 01-03-2010, 07:27 AM   #11177
niznai's Avatar
Did anyone else find they had to shim quite substantially the balldiff (54194) for sideplay? Mine has about 2mm of play.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 01-03-2010, 07:58 AM   #11178
SERPENT7twenty's Avatar
Trader Rating: 20 (100%+)
Hi friends,
Team Orion Rocket Pack in Stick config. they sell them in I believe 4000mah and up to 5k.
TEAM KAMIKAZE - SERPENT 966 - NOVAROSSI - HUDY - KO PROPO - XCEED
Kamikaze Development Driver - R&D = Rebuild & Destroy
www.Kamikazetoysandhobbies.com
SERPENT7twenty is offline   Reply With Quote
Old 01-03-2010, 08:55 AM   #11179
Atcom's Avatar
here are some more pictures
Atcom is offline   Reply With Quote
Old 01-03-2010, 09:05 AM   #11180
asw7576's Avatar
Picture of your M04's battery slot ?
Old 01-03-2010, 11:45 AM   #11181
Atcom's Avatar
I had to cut of some of the plastic in the corners. The car is still very stable and does not bend in the middle.How can you put pictures in the reply without attaching them? Attaching files is really problematic. It fails at the second picture! Thanks!
Old 01-03-2010, 11:57 AM   #11182
Atcom's Avatar
My battery is 26x48x138mm. The body on the car is a HPI Wheely King body.
I got all the aluminium modification parts from etamiya.
Old 01-03-2010, 12:39 PM   #11183
Atcom's Avatar
"Description:
With this conversion kit you can convert your Tamiya M03/M04/M05 with front motor chassis to reduce front tire slip and enhance maximum mobility and traction. Come with Aluminum motor mount and used with pinion of gear from 19T to 26T.
Feature:
For: Tamiya M03/M04/M05
Material: Aluminum and Black FRP
Specification:
Wheelbase: 210/225mm
Pinion gear: from 19T to 26T
Length of suitable battery: max. 225mm
Include:
Xevo FF Conversion Kit for M03/M04/M05 (1set)"
Qouted from hobbytalk.com
This is the Xevo FF Conversion!
Does anyone know if this is a good change for the car?(wouldnt say hop up because it replaces the whole chassis)
If anyone knows something about this let me know! Thanks
Old 01-03-2010, 02:23 PM   #11184
"Description:
Feature:
Specification:
Include:
The guys at rcmini say it is the car the m05 should have been. I have heard it is better in every way to the m03/5. Go to http://www.rc-mini.net for a l review.
Terry
Is your car slow..Xray it!.......FK05, M18, M18t
RexX
Assoc...T3,T4, B4
Team Ash is offline   Reply With Quote
Old 01-03-2010, 02:44 PM   #11185
caltek1's Avatar
Trader Rating: 35 (100%+)
Default XEVO
Atcom,
The Xevo is very good and I agree with the RC-mini-net comments. The car is very stable and I haven't had a traction roll with my Xevo. The rear end can slide a little but it is not uncontrollable. I have the 3Racing speed set in mine,which makes it substantially faster, does tend to mess up your braking points though. I have overshot a few corners with this car.
The review at rc-mini-net is worth a read as is the entire site for those just starting out with a mini.
Regards,
Calvin.
Tamiya mini cooper-dsc02218.jpg   Tamiya mini cooper-dsc02220.jpg   Tamiya mini cooper-dsc02222.jpg
caltek1 is offline   Reply With Quote
Old 01-03-2010, 02:48 PM   #11186
Originally Posted by caltek1 View Post
Atcom,
Regards,
Calvin.
Hi guys- dumb newb question from me: What is traction roll? Is that just when the car goes around a corner, and it rolls over off it's wheels? Or just that it is rolling (looking top heavy)? Or something else?
Jason
JasonRP is offline   Reply With Quote
Old 01-03-2010, 02:53 PM   #11187
caltek1's Avatar
Traction roll happens with both TC and mini. It is where the car rolls going into a corner due to having too much grip.
The MO3 tended to have more of an issue with this than the MO5. A lot of time due to high ride height and not enough weight in the car.
Later,
Calvin.
Old 01-03-2010, 03:42 PM   #11188
Starteur's Avatar
Originally Posted by Starteur View Post
Do you think the adjustable front camber arms for M05 discussed in this thread will be out soon?
Anyone have the answer?????
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Old 01-03-2010, 03:57 PM   #11189
caltek1's Avatar
Starteur,
Tamiya have not released a set and will most probably not. The adjustable arms everyione was referring to at the time was the rear set that has been released. People thought these were for the front.
If you want adjustable arms for the front then you will need to make them yourself or get them from 3Racing as a turnbuckle set.
The other option is to get fixed length arms in two lengths available for the front and rear made by Tobee Craft or Tech Racing.
I have not had problems using the standard front camber links on my MO5, fitted in the upper hole. If I place in the lower hole it wears the inside of the tyre out quickly.
I hope that answers your question.
Regards,
Calvin.
Old 01-03-2010, 04:42 PM   #11190
Atcom's Avatar
Atcom,
Regards,
Calvin.
Im planning to order this kit. Do you know where is the best to buy it? Do you suggest any other parts to buy that are related to this kit?
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
