Old 12-31-2009, 12:30 AM   #11146
caltek1's Avatar
Trader Rating: 33 (100%+)
Jim,
That Miata looks like it has seen better days. Reminds me of my old Mini shell, that I wouldn't stop running. Others threatened to take the scissors to it.
Alas now long gone. It became to brittle and the shell was nearly all tape. Did nothing for the handling.
Later,
Calvin.
caltek1 is offline   Reply With Quote
Old 12-31-2009, 12:35 AM   #11147
RossoTorro's Avatar
Originally Posted by niznai View Post
I didn't think this would happen but RCmart came through with the goods in record time and at the busiest time.
This morning my Assetto Corse came home. With it I had ordered all the genuine Tamiya upgrades they had in stock on the site and thankfully it was all there, in a little bundle held together with elastic bands, inside the box. Little red labels on the sides of the kit box warned me these extra parts had been put inside. Outside, another two sets of M-grips made the bulk and cushioned the kit box along with a large double layer bubble wrap sheet all protected with an outer cardboard box.
Thank you very much for such service.
A set of TRF mini shocks bought separately off ebay is on the way to complete the build.
The bodyshell is probably the most amazing. I am used to Tamiya's high standards when it comes to realism but they have really outdone themselves with this one. The car comes with an extra lexan moulding of various parts to be used inside the shell, but most interesting is the rear diffuser which really looks the part. I can barely wait to build this little guy.
Rcmart is really good, and if they do mistake they always fix it!
Super service!
RossoTorro is offline   Reply With Quote
Old 12-31-2009, 12:45 AM   #11148
gtfour93's Avatar
Trader Rating: 22 (100%+)
Just stock up on drywall mesh tape & Shoe Goo, and you're ready to battle.
www.activrc.com
gtfour93 is offline   Reply With Quote
Old 12-31-2009, 12:55 AM   #11149
caltek1's Avatar
Quick question.
Have any of you had any luck using the Speedway Pal 37's or 27's mini tyres and if so what insert were you using. The same question for the Pit Shimizu 30 slicks.
I have been experimenting with these lately as a front tyre on my MO3 and MO5 and found them to have so much front grip. The rear end I can not get to stay planted. I have changed springs, tyres inserts etc.
Just wondering if someone has a setup or idea that might be worth a try. I am running on asphalt. I have my car setup soft with red and and yellow springs, 40 wt oil and three hole piston. I did try harder springs but no dice. I also tried 5.5mm, 5mm, 4.1mm inserts in the tyres.
Regards,
Calvin.
Old 12-31-2009, 05:51 AM   #11150
beaim's Avatar
Trader Rating: 8 (90%+)
Send a message via MSN to beaim
Try rear positive o chamber. The more negative the less grip on rear. It works on mine mo3.
beaim is offline   Reply With Quote
Old 12-31-2009, 11:06 AM   #11151
Happy New Year 2010 from Manila!!! Here are some firecrackers outside my house to celebrate. The fireworks and firecrackers are in the middle of the street. Good luck to passing cars
+ YouTube Video
+ YouTube Video
+ YouTube Video
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 12-31-2009, 04:28 PM   #11152
racerb's Avatar
Default yo
Hey all, finaly gots me some oil shocks for my M03L... but horizon sent my LHS the regular cva mini shocks (I had asked for the super mini's) Anyway is there much difference between the two?? also what is a good base set-up for the shocks (oil weight, different holes, and springs which I still waiting for those to come in so just runnin the stock silvers for now) anything I should do that instructions don't tell me??? I also got some universals as well woo hoooo should be flyin real good soon, hopefully getin rid of the wheel chatter!!!
racerb is offline   Reply With Quote
Old 12-31-2009, 05:25 PM   #11153
Default sweep tyres & inserts
Hi there
Ive bought some Sweep mini tyres & inserts.
The inserts dont seem to fill the tires,seems to be a big airgap
am I better off to stuff them with Tamiya foam inserts??
1101 is offline   Reply With Quote
Old 12-31-2009, 05:55 PM   #11154
mcdogboy's Avatar
What are the mini Shocks anyway, got a spare set of TC TRF shocks, what's the real difference between then and mini ones, can I fix it with a couple spacers under the piston?
mcdogboy is offline   Reply With Quote
Old 12-31-2009, 06:07 PM   #11155
caltek1's Avatar
racerb and mcdogboy,
The Super mini cva's from Tamiya are shorter and the best for the mini. The regular cva's are to long and will not let you slam your car down for the correct ride height. As I haven't used these for years I can't really say to much but with the super mini cva's we used to use the 6mm spacer that comes with shocks under the piston and build from there. The springs used were the 53333 from Tamiya. The TRF shocks now come in standard size and Mini length. The mini length ones require no internal spacer as such. The normal TRF's require a spacer under the piston. Depending on how much droop you want to have will be dependant on how many shims you place under the piston.
For myself I use 3mm shims under normal TRF shocks on my MO5. This seems to work for my car and my style of driving.
If you want to know more then I suggest you follow this link and all will be explained and I don't have to type so much.
http://www.rc-mini.net/joomla/index....d=44&Itemid=60
A good read through that site should help.
Happy New Year to all my fellow mini racers
Kind Regards,
Calvin.
Old 12-31-2009, 06:43 PM   #11156
mcdogboy's Avatar
Thank's mate, I believe I've trawled rc-mini fairly completely over time
Might have a play with these spare shocks anyway, guess I've gotta get off my arse and measure the difference in the rods, my 05 has the super minis anyway, but it was much easier to ask here
Old 12-31-2009, 11:14 PM   #11157
jcr
question, is there any difference in buying spring set 53333 and buying the individuals like 53630, 53631, & 53632?
jcr is online now   Reply With Quote
Old 01-01-2010, 01:33 AM   #11158
caltek1's Avatar
jcr,
They are different spring rates and also different lengths. Having them all gives you more tuning options. The Tamiya TRF mini shocks come with three pairs of springs the short TRF blue, Short Yellow and Red.
Regards,
Calvin.
Old 01-01-2010, 06:56 AM   #11159
Starteur's Avatar
Do you think the adjustable front camber arms discussed in this thread will be out soon?
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Old 01-01-2010, 10:03 AM   #11160
racerb's Avatar
Default thanks
thanks Cal. I too have read rc-mini, and I tell every new mini owner to read before they build!!
the shocks I got are the cva mini shocks,(tam50519) I believe they will work because they do say you can run them on FWD vehicles and they do come with a long spring pair or short spring.... I think this might be why they ae a couple bux more than the super mini...
so is the kit oil fine to use or maybe should I start with something like 40wt?? also what holes should I use 2 or 3?? I guess I will have to try and figure out what spacers to use to get my car sittin where I need it
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
SEO by vBSEO 3.5.0
