Like Tree23Likes
Old 12-28-2009, 09:02 PM   #11116
Craig J's Avatar
Send a message via ICQ to Craig J
Default M05 Diff
I just finished my M05 pro build,,used the siler grease that came with the kit for the diff,feels kind of tight,under hard acceleration,the car seems to pull very hard to one side,is this because of the stiff grease,should I disassemble and put something lighter in?
Craig J is offline   Reply With Quote
Old 12-28-2009, 09:06 PM   #11117
caltek1's Avatar
Trader Rating: 33 (100%+)
Craig J,
Which 'O" ring did you use in the diff cups? I do not use the black 'o" ring but use the white silicon ones. Have you fitted universals to the front?
Some use spools in the MO5, without this problem.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 12-29-2009, 01:12 AM   #11118
i used REALLY REALLY thick grease in my diff and had no pulling problems
BUT when it was new it pulled like a bitch to the right side under accelaration , i think it was the rubber O rings in the diff halfs that did it
i am using a set of the Tamiya universal drive shafts and now got the 3Racing ball diff to try out , still pulls as straight as an arrow
sidecarphil1 is offline   Reply With Quote
Old 12-29-2009, 01:21 AM   #11119
caltek1's Avatar
sidecarphil1.
I am using the Tamiya universals and the new Tamiya MO5 ball diff with great success. As I said I use the Tamiya clear silicon "o " rings in my diff cups. Pulls straight. No problems.
I will only use a TAO3 ball diff in my MO3 now. The new ball diff is just so much better and easily adjusted on the MO5.
Later,
Calvin.
Old 12-29-2009, 02:51 AM   #11120
Originally Posted by caltek1 View Post
sidecarphil1.
I will only use a TAO3 ball diff in my MO3 now. The new ball diff is just so much better and easily adjusted pn the MO5.
Later,
Calvin.
i decided not to buy the Tamiya ball diff as it is SERIOUSLY expensave and i am impressed with the quality of the 3Racing F1-09 so i decided on that , it is the same looking as the Tamiya one but no silly outdrive protectors for the universals !!
it is adjustable from outside the chassis too , the only thing i am a little dissapointed about is the speed gears , i think they dont mesh propperly
Old 12-29-2009, 02:58 AM   #11121
cannon's Avatar
Trader Rating: 35 (100%+)
The speed gear set is useless. They bind
As for the 3 racing ball diff, it depoends on whether you get the steel outdrives or alloy. Alloy has blades for the universals .. the steel doesn't.
The ball diffs from 3 Racing are good but are let down by their hardware ...thrust bearings, bolt and nut . Very poor quality which causes failure
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 12-29-2009, 03:22 AM   #11122
caltek1's Avatar
sidecarphil1,
I have used both the 3Racing MO5 ball diff with the alloy cups and the Tamiya MO5 ball diff. I found that the 3Racing ball dff when tightened so it did not slip, stripped the 2mm lock nut and screw. I also noticed that the thrust bearing was not as good as the Tamiya one piece offering. I rebuilt my MO5 3Racing ball diff with a Tamiya thrust bearing, new 2mm diff screw and a new 2mm locknut and yes it works fine, however it is assigned to my spares box.
The Tamiya unit is so much better. I replaced the steel balls with the 3mm carbide balls and packed it with anti-ware grease. I purchased mine from Japan and was happy with the price. It will stay in my car until it needs a rebuild or I break it. I am still using the blades from the 3Racing diff on my universals in the Tamiya diff. They do not appear to have any wear marks, even after the thrashing I have subjected them too.
As they say in the classics, "You get what you pay for".
The same could be said for the Tamiya alloy steering linkage, however I think it works better than some of the others due to its horseshoe shape.
Just my two cents worth. Each to their own.
Regards,
Calvin.
Old 12-29-2009, 03:28 AM   #11123
i got the one with the steel outdrives
i will do as i do with all my ball diffs , strip , rebuild with some asso fat
i have spares from my busted TA05 diffs and the TRF diffs i have spares i will use a propper tamiya bolt and nut
see what i think and it will be crash/race tested
Old 12-29-2009, 03:35 AM   #11124
caltek1's Avatar
race/crash testing is always the biggest leveller of all.
Old 12-29-2009, 04:06 AM   #11125
3 racing ball diffs are more expensive than the Tamiya's in the sense they break easily. these types of poor quality products should not even be sold in the first place. crushed thrust bearings. loosening diffs.
it is light though at 17 grams.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 12-29-2009, 04:13 AM   #11126
caltek1's Avatar
You can strip the screw in the Tamiya MO5 ball diff also, just takes more effort. So I am told. Bit of a bugger to get apart. Takes at least two people to sort it out. Must of happened at the Hill.
Old 12-29-2009, 08:11 AM   #11127
The Tamiya MO5 diff will not fit the Xevo as it only uses 1150 bearings, so you will need to get a TAO3 ball diff.
Sorry, do you mean the Xevo only uses 1150's or the M05 diff only uses 1150's
I'm guessing you mean the Xevo is on 1150's so that would mean the M05 diff is on something else? Does it have outdrive adaptors then, as the M05 stock diff is exactly the same as an M03's isn't it. Would I be correct assuming this means I can't use the M05 ball diff in my M03 too?
Mini35 is offline   Reply With Quote
Old 12-29-2009, 08:22 AM   #11128
Craig J's Avatar
Default pulls
Thanks for all the advice guys,seems I have some spare clear o-rings left and will give those a shot,and maybe even a set of universals.
Old 12-29-2009, 08:54 AM   #11129
jcr
anyone tried the 3Racing mini tires? they're suppose to be 60D
jcr is offline   Reply With Quote
Old 12-29-2009, 09:11 AM   #11130
portyansky's Avatar
Trader Rating: 53 (100%+)
when building the trf m-chassis shocks how many o-rings should i put on the inside shaft? it says 1, but im thinking 2
Team Tekno Canadian Team Manager
Team Hitec
portyansky is online now   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
