Like Tree137Likes
Old 02-01-2006, 07:47 PM   #1096
Anyone ever use this mini foam tires ?
Check this out :
http://www.asiatees.com/display.php?...odel=ALL&pid=1
What shores ?
rcmnx is offline   Reply With Quote
Old 02-01-2006, 08:18 PM   #1097
racenut's Avatar
Trader Rating: 15 (100%+)
Originally Posted by rcmnx
Can't be used. It's for TL01/TA04
TL01 knuckle arms will fit Minis....FYI
racenut is offline   Reply With Quote
Old 02-01-2006, 08:58 PM   #1098
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by westerdude42
Hey Troy, Can you get a center section to convert the mini for the Swift body? Is the body available in Japan?
Typicaly the bodies are out about 2 weeks after the kits. and the spare parts, come out with the kits sometimes. So No bodies right now, and no extesion right now, not till the kit comes out. But I think the suspension will be worth buying the kit.
tamiyarcracer is offline   Reply With Quote
Old 02-02-2006, 03:21 AM   #1099
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to HotrodHopkins
ok, is there any besides tamiyas that will fit it?
SHAUN HOPKINS a.k.a NoRod Hopkins
-1990 Chevrolet K1500 Silverado TBI350 "Heavy Half". 1971 Chevrolet Nova
-My lug nuts require more Torque than your Honda makes.
HotrodHopkins is offline   Reply With Quote
Old 02-02-2006, 03:36 PM   #1100
racenut's Avatar
Originally Posted by dirk
Thanks! I'm using the stock friction shocks. I thought these cars where non adjustable, I was wrong. WOW! the handling is so much sharper! Almost like the 1/12 scale pancars. I also put in some stiffer springs. This little Mini is the most fun rc car I've ever driven!
Now your talking!!! Minis are great!!!
Old 02-02-2006, 06:49 PM   #1101
Send a message via AIM to Bane
Default Ball Diff Help
I ahve never assembled a ball diff int he past and the directions on the back of the package are definately not full of info. I lubed the balls and thrust washers as stated and placed everything in the way it says to but when tightening I dont know when to stop. I know most say tighten all the way down but is that till you can turn no more. Almost seems liket he the little washer springs would totally depress and be of no use if you do this. I dont want to ruin it. Ive tighten it down a good bit but is it suppose to be real smooth (its not) I fI hold each drive cup in each hand and move back and forth it does spin but not very smooth. PLEASE HELP!!!!THANKS!!!!
Bane is offline   Reply With Quote
Old 02-02-2006, 07:39 PM   #1102
racenut's Avatar
Check if your assembly was properly aligned
Old 02-03-2006, 05:35 AM   #1103
Did you grease the diff balls before you put it in? Just tighten it until it hold in place, no need to break your fingers tightening it.
I take it you are using the stock diff balls, I switched to carbide ones and find it better and smoother than the stock ones.
natskiboy is offline   Reply With Quote
Old 02-03-2006, 11:44 AM   #1104
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Hah.. the Sea Bass..
So, Kingpins on each upright? Does this mean TCS-legal camber adjustment?
It's also interesting they'd use it in the rear uprights.. would they pivot too for adjustable rear toe? That would mean ball links to the rear of the chassis, which seems to be unchanged, but who knows..
With different suspension arms, will there be added shock positions? The simplicity of the M-chassis was the reason it was so easy to drive, and the setup so hard to screw up, since all you really mess with are springs, oil, toe and sway bars. Now it may get a little more complex..
Through the description of treaded rubber tires with foam inserts, I'm sure they'll be the 60D size, not sedan tires.
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 02-03-2006, 06:50 PM   #1105
Trader Rating: 76 (100%+)
If anyone is interested I have a mini-cooper for sale with some mods.
MUDVAYNE is offline   Reply With Quote
Old 02-04-2006, 04:19 AM   #1106
does anyone know good swing shafts for the M-03 that are not Tamiya brand?
Old 02-04-2006, 07:37 AM   #1107
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Tamiya makes 2 different sets for the mini #53205 is one of them I cant seem to find the other number. The newest is a true CVD the old one is a universal joint
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 02-05-2006, 08:25 PM   #1108
racenut's Avatar
I am, Pm me for your offer and post some pics too
Old 02-06-2006, 11:18 AM   #1109
SpeedChair's Avatar
Hi, I just got a M03, and wanted to upgrade some of the parts. Who has the best price for Tamiya upgrades that's located in the states. I'm looking to buy the alum front uprights, TA03 diff, and possibly TRF shocks.
Thanks ahead.
SpeedChair is offline   Reply With Quote
Old 02-06-2006, 12:57 PM   #1110
Hill834's Avatar
Thanks ahead.
Tower Hobbies - www.towerhobbies.com seems to have the best prices and selection that I've found. If you know the part number you just put that into the search feature on Tower. TRF shocks may be a problem though.
Hill834 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
