Like Tree81Likes
Old 12-16-2009, 06:00 PM   #10996
portyansky's Avatar
Trader Rating: 54 (100%+)
I got my M05 handling SOOOOO much better. Its almost 100%, I think im gonna go a little heavier on the shock oil, but no more traction rolling and im diving into the corners hard. The ball diff and long wheel base made a big difference. I did manage to break a part of the steering, but thankfully my lhs had the optional aluminum set, pricey, but I dont think I will ever brake that again.
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 12-16-2009, 08:23 PM   #10997
Timbulb's Avatar
No your right, it'll just bend.
Timbulb is offline   Reply With Quote
Old 12-16-2009, 11:42 PM   #10998
caltek1's Avatar
Trader Rating: 34 (100%+)
" That's Tops " We like it.
caltek1 is offline   Reply With Quote
Old 12-17-2009, 02:21 AM   #10999
Julius's Avatar
Default Rounding tire edges
Hi,
I've read about using superglue on the Tamiya tire sidewalls to reduce grip roll, but did anyone ever try rounding the edge of the tire a bit?
I'd think this will not prevent the tire flexing but it might be more smooth?
Thanks for any insights
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 12-17-2009, 02:54 AM   #11000
PizzaDude's Avatar
Originally Posted by Julius View Post
Hi,
Juul,
This will not reduce the tire from heating up. Especially on carpet.
Superglue will reduce the rubbing and thus the overheating of the tires which causes grip roll.
Usually the grip roll will aggravate during the race because of the heat.
Good luck, flyboy.
M
PizzaDude is offline   Reply With Quote
Old 12-17-2009, 04:01 AM   #11001
Timbulb's Avatar
That's not how the CA glue trick works. It works by making the tire slide out ever so slightly as soon as the vehicle begins to bicycle. That's why you only need to do the front tires and it's also why you can see the effect as soon as you hit the track, whether the tires are cold or warm.
Old 12-17-2009, 05:06 AM   #11002
portyansky's Avatar
Hi,
I have never used that trick. I just setup my cars properly. When applying traction compound, just do the inside front, full rear.
Team Hitec
Old 12-17-2009, 05:31 AM   #11003
Hi Julius,
I tried rounding off the tires on brand new tires (Sgrip, Mgrip), regretted doing it. The tires lost grip. Maybe overheated when I was sanding them, hence destroying the tires in the process.
Try the M05, much less succeptible to grip roll.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is online now   Reply With Quote
Old 12-17-2009, 09:35 AM   #11004
i set my cars up propperly too
but i still need superglue , even with no smear they still grip roll due to the weight height of the M chassis !!!!
i even superglue my Xray T3s front tyres and my set up is perfect !!!
sidecarphil1 is offline   Reply With Quote
Old 12-17-2009, 09:51 AM   #11005
racerb's Avatar
Default hmmm
I do not have traction roll issues but the damn thing chatters so bad... I have done everything you all have said (other than the universal shafts which are on order) I do not understand as other guy's in my club have the exact same cars (m03L) no-one is having any kinda problems like mine..... we don't race now till the 27th... I guess I will have to tear it down and totaly rebuild it again.... I consistently place right behind the top driver in the club but gotta drive my butt off to do it... can't wait to get this thing so that I can start racin with him
racerb is offline   Reply With Quote
Old 12-17-2009, 11:50 AM   #11006
Julius's Avatar
True, setup makes a difference for traction roll. However depending on the track and the amount of grip sometimes tricks like superglue are needed.
Especially with tires that have such high sidewalls....
I'm ok with my car for the moment and like you said the amount of traction compund makes for huge differences. Just looking for other options.
Maybe just adding lead weight down low will do enough. I'm 150gms underweight for our rules at the moment
Old 12-17-2009, 12:09 PM   #11007
are you at AMCC on sunday ???
Old 12-17-2009, 01:33 PM   #11008
Julius's Avatar
Nope. Working sunday
Old 12-17-2009, 07:15 PM   #11009
caltek1's Avatar
Default MO5M
Here's a couple of snaps of my MO5M with the new Tamiya MO5 Ball Diff and new Tamiya Steering Rack.
Later,
Calvin.
Tamiya mini cooper-dsc02180.jpg   Tamiya mini cooper-dsc02169.jpg   Tamiya mini cooper-dsc02170.jpg   Tamiya mini cooper-dsc02182.jpg
Old 12-17-2009, 10:14 PM   #11010
doriftu's Avatar
Later,
Calvin.
how do the new ball diff and steering system perform? any reviews?
thanks
six-shifter.blogspot.com
supercharged-e36.blogspot.com
doriftu is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
