Like Tree51Likes
Old 12-14-2009, 06:22 PM   #10966
portyansky's Avatar
Trader Rating: 54 (100%+)
Originally Posted by djr53 View Post
hey guys, just bought an m05,and i was wondering wat are some must have hop-up parts,and what battery and chargers are you guys using?
Front aluminum knuckles, oil filled shocks, bearings, ball diff. I run this batt mainly b/c we run a spec class... http://www3.towerhobbies.com/cgi-bin...?&I=LXXCJ9&P=7
I use about 700mah after a 5 min heat with at least 2 minutes of practice.
Originally Posted by Tristar Racing View Post
I also am looking for a decent charger. I will probably stick with Nicad for now, but move to lipo in the future. The local shop recommends a Venom charger, but I have read some questionable reviews.
I have this charger, but its not needed http://www3.towerhobbies.com/cgi-bin...&I=LXVZA8&P=ML
Other options...
http://www3.towerhobbies.com/cgi-bin...&I=LXVRS6&P=ML
(I owned this one as well and was happy with it, but I needed something that was goona produce more watts since I was charginf 5s batts) http://www.maxamps.com/EOS0606i-AC-DC.htm
There are many good ones.
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 12-14-2009, 08:17 PM   #10967
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
you can give the duratrax onyx 230 a try I've been using it for a while and love it...its ac/dc, does just about everything except gel cells, and can do a 2c charge for lipo (max of 10amps)
http://www3.towerhobbies.com/cgi-bin...&I=LXTCK1&P=ML -- and for the price you can't beat it
i tend to use this charger more then my checkpoint t1030
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 12-14-2009, 09:16 PM   #10968
caltek1's Avatar
Trader Rating: 33 (100%+)
djr53,
The car will work fine with standard front knuckles and rear hubs. The main hop up to get is the bearings to replace all of the bushes and plastic bearing parts. I have not heard of anyone having heat bending issues with the front left knuckle.
You should take a look at the http://www.rc-mini.net/joomla/index.php site and see what they have to say. Make sure you have a good read and then ask some more questions.
The ball diff is not always a requirement, but it is good to have. The universals would be higher on my list. 3Racing oil shocks or Tamiya's super mini cva shocks will work with a selection of springs. If your budget stretches then get TRF shocks however they are not really required.
You should build the car and drive it and then change things when you want too.
Not all of the bling is required to have a fast mini. The standard plastic steering does work, a couple shims and it is gold.
My thoughts only.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 12-14-2009, 09:18 PM   #10969
mcdogboy's Avatar
Anyone else notice the s800 m05 body on rcmart?
Wasn't the s800 RWD, are we gonna see an m06?
Hmmm.
mcdogboy is offline   Reply With Quote
Old 12-14-2009, 09:36 PM   #10970
k_bojar's Avatar
Hmmm.
i'd highly doubt it - i think the rwd mini ship has sailed...Everyone knows it take mucho effort to get the mo4's to hook up - but once they hook up, they are killer...
plus i think tamiya realized they dropped the ball by giving the m04 a different gearing option then the m03/m05
i think the only way you'll see a rwd m05 is with some end-user customization
Old 12-15-2009, 04:11 AM   #10971
Three's Avatar
Does the M05 chassis need to be taken apart to adjust the M05 ball diff? Was told it could be externally adjusted.
Electric good..........
Three is offline   Reply With Quote
Old 12-15-2009, 04:13 AM   #10972
Core Creations's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to Core Creations
It is externally adjustable.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 12-15-2009, 04:15 AM   #10973
Skitee's Avatar
No need to split the chassis with the M-05 ball diff, just unscrew the upper arm and move the drive shaft/dog bone out of the diff outdrive and adjust with 1.5mm driver.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 12-15-2009, 04:22 AM   #10974
Three's Avatar
Damn, could racing Minis get any better?
Old 12-15-2009, 04:40 AM   #10975
Julius's Avatar
Default Tire inserts
Hey guys,
I need some advice on the tire inserts.
I need to run stock or m-grip tires. Surface is carpet.
Which insert should I go for? Probably many different opinions but let's hear em
Also do you glue the insert to the tire or just glue both ends together and stuff it in?
Julius
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 12-15-2009, 04:59 AM   #10976
Rogier's Avatar
Can anybody provide me the partnumber of the Union Jack roof sticker for the Mini Cooper of Tamiya? I tried Google, but he's not my best friend today.
My RCTech trader feedback: http://www.rctech.net/forum/trader-feedback/146331-rogiers-feedback-thread.html
Rogier is offline   Reply With Quote
Old 12-15-2009, 06:01 AM   #10977
Hi Julius,
There are only two inserts, hard and soft. Make tires with both. I would try hard insert first. Glue the foam insert end to end then stuff it in.
Good luck and hope you can join our mini races in JP Raceway.
Joel
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 12-15-2009, 06:05 AM   #10978
Julius's Avatar
Originally Posted by rccartips View Post
Hi Julius,
Joel
Hi Joel,
JP raceway with Mini. That would be a new trick!
Old 12-15-2009, 06:12 AM   #10979
Hi Julius,
Mini racing in JP Raceway is an old trick A new trick would be to get JP to race minis. And what a sight that would be to see you and JP race the mini's
Happy Holidays!
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
Old 12-15-2009, 06:19 AM   #10980
Suspended
Trader Rating: 2 (75%+)
is everyone running the silver can motors, or have anyone gone 17.5 BL route, or are there other options?
justanotherdude is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
gigaplex
