Like Tree108Likes
Old 12-13-2009, 04:43 PM   #10951
portyansky's Avatar
Trader Rating: 54 (100%+)
Its just different. But after 10 years you would think they would improve it. With that said, I still like it even though I am still trying to get it to handle like my m03... almost there.
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 12-13-2009, 05:34 PM   #10952
Hi, here are photos of the Top 3 m-chassis winners in the 2009 Tamiya World Championship. All are M05s. No M03 made the podium.
http://www.rccartips.com/tamiya-mcha...009-worlds.htm
Thanks to Mr. Masatoshi for posting these pics on his flickr. His username is Grahoo.
Taking lightweight to the extreme
Bye bye M03. Time to work my M05.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is online now   Reply With Quote
Old 12-13-2009, 05:46 PM   #10953
Do you need to trim off that much to reduce the weight?
studysession is offline   Reply With Quote
Old 12-13-2009, 06:17 PM   #10954
I'm shocked to see the use of the awful Tamiya battery connectors. They must be mandatory for the TCS series. Brutal.
I wonder if all the weight trimming is necessary, especially since the second place car appears to have a stock chassis. The aluminum hubs probably negated any weight lost from hacking the chassis apart.
:: Tamiya TA05 MS :: Tamiya TB04 Pro II/Exotek EXO6 :: Tamiya M05V2 :: Losi XX :: Tamiya TB01 :: Tamiya XV-01 Rally ::
ErikO is offline   Reply With Quote
Old 12-13-2009, 06:17 PM   #10955
SilverShelby's Avatar
Thats not going to fly in the states....
and YES Its a can motor!!!!!
M03,M05L,M06M,FF03PRO,CC01 Jeep,M03L-Yello Mini
ABC Hobby Goose,Genetic
2011 Memphis winner Mini,FWD
2013 e mergent winner Mini
SilverShelby is offline   Reply With Quote
Old 12-13-2009, 09:08 PM   #10956
jasons9's Avatar
Quick question, I got an aluminum motor plate for my M05 with the heatsink. Is there any harm in leaving out the paper motor spacer thing?
I believe it would work best if the motor was touching the aluminum motor mount directly.
Thanks,
jasons9 is offline   Reply With Quote
Old 12-13-2009, 09:25 PM   #10957
Originally Posted by caltek1 View Post
ErikO,
I hate to disappoint you, however the new MO5 diff will not fit the MO3. The MO5 has 1510 bearing mounts injected into the chassis the MO3 has only 1150.
Regards,
Calvin.
I'm a little confused by your answer. I'm not disputing it. Isn't the ID of the bearing the determinig factor? Whether the OD is 10mm or 11mm seems to be irrelevant. I used a TA03 ball diff in my M05 so the gear mesh seems to be the same and the width is the same and the gears in the gear diff are the same. I must be missing something here.
I am not saying it does fit, I just don't think the bearing OD is the reason.
Granpa is offline   Reply With Quote
Old 12-13-2009, 09:27 PM   #10958
C5R01's Avatar
Send a message via Yahoo to C5R01
Thanks,
leave the paper out, never used it and been running Tamiya since 89.
Current Cars:
Tamiya Garage:TB03; TA05V2-IFS; 414X #60;F104 V2;TA03r-s:TA03F:TA03R: FF01: FF03: M01: M03: M06: 1/14 Mercedes Semi truck- w/Reefer trailer ( fully functional): Tamiya Juggernaut 4X4X4, Tamiya RC Freightliner Cascadia Evo.; Honda City Turbo WR-02C; TRF102 F1
OTHERS:Kyosho 1/8th scale nitro Corvette C6R: Yokomo GT4 nitro, Slash 2WD,TA SCm5
C5R01 is offline   Reply With Quote
Old 12-13-2009, 09:28 PM   #10959
Thanks,
You are right.
Old 12-13-2009, 09:41 PM   #10960
caltek1's Avatar
Trader Rating: 35 (100%+)
Hello Granpa,
The reason the TAO3 ball diff can be used in the MO5 is because they have a plastic sleeve which encompasses the 1150 bearing to make it into a 1510 size which then fits into the chassis halves.
The new MO5 ball diff is larger in diameter and uses the 1510 bearing with out the requirement for the plastic spacer.
The MO3 chassis only has a space for the diff bearing which will only accept a 1150 bearing.
The internal diameter of the 1150 bearing will not go over the diff cups on the new MO5 ball diff. The TAO3 ball diff uses a externally fitted diff cup which is smaller in diameter than the new items. The new diff is the same size as a touring car diff and uses blades. I would take photo's however the new diff is already in the car.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 12-13-2009, 10:00 PM   #10961
jasons9's Avatar
Awesome, thanks!
Old 12-13-2009, 10:04 PM   #10962
Hello Granpa,
Regards,
Calvin.
Thank you for the quick answer cause I was going to order 2 diffs and now will just order one. You saved me over $40 with the tax. I knew I was missing something so I had to ask.
I've never even seen a M05 ball diff, but understand that they use a blade drive ala Xray TCs. ??for ya. Could you mill out the slots in the M03 out drives and then be able to use the nylon bit that goes over the drive pins? I'm getting tired of buying new out drives, the hardened ones even, and replacing universals cause the drive pins wore out. We run a lot out here and a 15 battery day is not unusual.
Old 12-13-2009, 10:12 PM   #10963
caltek1's Avatar
Hello Granpa,
I have seen it done. The only thing you would need to to do is ensure that the opening is equal and accepts the blade you install. A friend of mine does this regularly because he is sick and tired of spending $$ on replacement diff cups. I myself have not performed this, but he swears by it. It might not be TCS legal though.
I have found that with a tight ball diff or spool the hardened diff cups are trashed in only a short space of time. I have also experienced that the MO5 runs straighter and does not pull left or right when the diff is not locked up or really tight. I have also found it steers better.
BTW,
Any brand blades can be used.
Just my opinion.
Regards,
Calvin.
Old 12-14-2009, 04:13 PM   #10964
hey guys, just bought an m05,and i was wondering wat are some must have hop-up parts,and what battery and chargers are you guys using?
djr53 is offline   Reply With Quote
Old 12-14-2009, 06:12 PM   #10965
I also am looking for a decent charger. I will probably stick with Nicad for now, but move to lipo in the future. The local shop recommends a Venom charger, but I have read some questionable reviews.
Tristar Racing is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
