Like Tree195Likes
Old 12-07-2009, 03:37 AM   #10906
caltek1's Avatar
Trader Rating: 36 (100%+)
Well I have just come back from racing and must say that my MO5L is way better to drive than my MO5M. I think I will be doing some setup changes to the medium wheelbase.
I think the MO5L might need to do some laps at Windsor.
Later,
Calvin.
caltek1 is offline   Reply With Quote
Old 12-07-2009, 10:10 AM   #10907
Trader Rating: 35 (100%+)
My first day out with my M05 and one of my steering knuckles bent/deformed to the degree where it was actually touching the wheel. I have since upgraded to the Tamiya alloy front and rear hubs/knuckles.
Geppetto is offline   Reply With Quote
Old 12-07-2009, 10:39 AM   #10908
portyansky's Avatar
Trader Rating: 54 (100%+)
I bet it happened to the side where the motor is, right? Common problem with the m03 and I knew it would be with the m05, motor heats up and the knuckle closest to it also gets warm and bends.
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 12-07-2009, 10:50 AM   #10909
Yup, you're right! The knuckle that bent was on the motor side.
Do you really think that it's heat, and not the weight of the motor on that side of the car? My motor does get hot, but I can't imagine that motor heat could affect the steering knuckle.
Old 12-07-2009, 10:55 AM   #10910
portyansky's Avatar
Believe it or not, yes. Next time you have it out, temp both of your alum knuckles and see the temp difference, you might be surprised...
Team Hitec
Old 12-07-2009, 11:17 AM   #10911
dannyboy15's Avatar
Send a message via MSN to dannyboy15
some 1 do that and post the results because my mo3 knuckle bent by the motor before i got metal ones it sounds intresting
dannyboy15 is offline   Reply With Quote
Old 12-07-2009, 11:23 AM   #10912
dannyboy15's Avatar
Default o yer
o yes looks like im gonna win our local mini class just because i have turned up to almost every week ONLY 1 ROUND LEFT WOOOOOOOO
1 Dan (1625) 150 146 148 148 146 146 146 148 149 150 144 - 148 144 -
2 Joe (1192) - 149 - 150 149 148 149 150 149 148 - - - - -
3 Frank (1043) - 149 150 - 149 150 149 - - - 148 - - 148 -
4 Dominic (448) - - - - - - - - - - 149 - 150 149 -
5 Paul (294) - - - - - - - - - - 147 - - 147 -
6 Chris (284) - - - - - - - - - - 142 - - 142 -
Old 12-11-2009, 09:21 AM   #10913
rccardr's Avatar
Wow. Did somebody turn the lights out in the Mini Cooper clubhouse?
Four days and zero posts. Weird
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 12-11-2009, 12:58 PM   #10914
RossoTorro's Avatar
Seems so...
I will post some then. Raced my M05Pro against some dailed M03M and M03L's. And there was nothing to choose between us, i was so pleased with how the car handled and behaved. I use it on Long wheelbase with TRF damper, 3racing steering and M05 Ball diff. The new balldiff really transformed my car with handling!
This is starting to be my favourite M-Chassi. My M04 would not behave whatever i did to it. And all i done with it from a perfect setup i had before was a chassi change.... Same set up as before but was crap to drive now, no matter what adjustments it would not turn or have rear grip....
RossoTorro is offline   Reply With Quote
Old 12-11-2009, 01:31 PM   #10915
RossoTorro, don't give up on the M04. Last weekend we had our yearly Futaba Cup race. Despite being limited to 19T gearing, my M04 was doing 18 laps (16.8sec/lap) whilst the rest of M03/M05 was 17 laps (17.4sec/lap). This was running sport tuned motors, lipo and 1,200 grm weight limit. It was fun driving my 6 year old M04 once again.
I do have an M03 and M05 as well. But I knew my 2004 M04 car would be faster. Rear wheel drive minis just accellerate so much faster and take sweepers so much smoother. A shame they are banned in the Tamiya World Championships.
P.S. I did make special tires for the race. It was Sorex 36r cut down to mini size. Our race allowed for any brand rubber tires as long as mini size.
Above pic is a joke to my friends as they have banned my "fabricated" tires. So I have "productionized" them
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 12-11-2009, 01:37 PM   #10916
RossoTorro's Avatar
Yeah, i know the M04 is a monster with right set up.
I just could not get it dailed last time. We run EzRun 13T with Xpress or Yeah Racing foams. One time i put 2nd place two laps down on a 3 min race, we do 10.7sec a lap (small track). Still it was total domination of the M04. they even talked about banning my car after the race.....
I will try it more next week, we are going to change layout of the track then.
Old 12-11-2009, 01:57 PM   #10917
Trader Rating: 22 (100%+)
Default Groove.
Originally Posted by caltek1 View Post
Terry,
On your MO5, which hole do you have your front camber link in? If it is on the lower front mounting hole, then that type of tyre wear is normal. Most of us here are running the front camber link in the upper hole, as the tyres do noy wear as quickly.
Regards,
Calvin.
Cal,
The front link is in the top hole. I might get some adjustable links but it is handling so well I dont want to really change much. The tyres are not hard (meaning there is play between the tyre and the insert). Maybe this is helping to cause it. The wear is bad enough that I reccon I will get maybe 2/3 max nights out of the fronts.
Terry
Is your car slow..Xray it!.......FK05, M18, M18t
RexX
Assoc...T3,T4, B4
Team Ash is offline   Reply With Quote
Old 12-11-2009, 08:53 PM   #10918
caltek1's Avatar
G'day Terry,
I don't know which tyres you are running, we use 3035 rides on the front with a 5mm Spice insert and use Cross 36's with a 5mm or 5.5mm insert. This works at most tracks.
I have found these to wear fairly consistantly. Front RH is 3.5mm measured behind the motor and Rear RH approx 4-5mm. I am using stiff springs front and rear.
I will post a couple of pictures of my car when I can find my camera. This setup is on my MO5L. My MO5M is another story. It needs a bit of work.
I am still using the same tyres I ran at the Nationals which were used for 5 qualifiers, one final, practice another full race meet and they will be good for a few more yet.
Regards,
Calvin.
Old 12-11-2009, 08:55 PM   #10919
caltek1's Avatar
RossoTorro,
Which new MO5 ball diff are you using? I know the Tamiya was released in Japan on the 10 Dec. Is it the 3Racing or Tamiya? and is it setup as standard?
Regards,
Calvin.
Old 12-11-2009, 09:20 PM   #10920
NT
NT's Avatar
Trader Rating: 21 (100%+)
Hadn't made it to Singapore when i enquired yesterday at the Tamiya shop/importer. They had no fixed date........
NT is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
