Like Tree54Likes
Old 12-01-2009, 06:54 AM   #10861
monkeyracing's Avatar
Originally Posted by hanzo3 View Post
Does the stock ESC support lipo cutoff?
That depends which stock ESC you're talking about. Tamiya has discontinued the old reliable TEU-101BK, which did not, but it's still out there in thousands of kits on store shelves. New kits are being supplied with the TEU-104BK, which does have a cutoff built in to it.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 12-01-2009, 07:42 AM   #10862
racerb's Avatar
Default k
Originally Posted by Skitee View Post
You'll just need to check something, the swb M-03 kits use 1150 bearings in the uprights as did the older lwb M-03L kit but the 2006 cooper lwb kit uses 1050 bearings in the uprights.
K thanks everyone for the help, just not alot of parts available through our distributor, so with some things have to search around a little, especially if we need something quick!!!
racerb is offline   Reply With Quote
Old 12-01-2009, 10:35 AM   #10863
Trader Rating: 22 (100%+)
Default Pics
Originally Posted by jcr View Post
any chance you got a picture of it? Want to see how much you need to cut out? Or what tires do people use with the old mini body (for TCS)?
Sorry, I am leaving for a week away this morning. He does look occasionally on the forum so I will ring him and see if he will post .
Terry
Is your car slow..Xray it!.......FK05, M18, M18t
RexX
Assoc...T3,T4, B4
Team Ash is offline   Reply With Quote
Old 12-01-2009, 11:25 AM   #10864
jcr
Terry
Ok thanks! If anyone else got a picture of the shortwheel base Mini with 60D tires, please post a picture so I can see how much of the body needs to be cut away or if I need to set it to a higher setting on the body post.
jcr is offline   Reply With Quote
Old 12-01-2009, 11:38 AM   #10865
portyansky's Avatar
Trader Rating: 54 (100%+)
if your local hobby store deals with Great Planes then whatever Towerhobbies carry you lhs can order as well. Or your lhs can order from Borgfeldt (Located in Toronto) they usually have everything before Towerhobbies.
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 12-01-2009, 11:50 AM   #10866
gtfour93's Avatar
You can raise the body or drive the car at the desired height. After a few runs, check to see where the tires are rubbing and use a Dremel to shave off the wheel arches. This procedure always worked well for me.
www.activrc.com
gtfour93 is offline   Reply With Quote
Old 12-01-2009, 12:06 PM   #10867
academygaz's Avatar
Does anyone know what bodies fit the Xevo conversion kit? I have an M04L that I'm going to sacrifice to make into a Xevo, and I don't like the BMW Mini bodies. What else has a long enough nose to clear the motor? Suzuki Swift is what I'm leaning towards, but could the 225mm Alfa Giulia fit? How about non-Tamiya bodies?
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 12-01-2009, 01:13 PM   #10868
jcr
well trying to figure out if I need to dremel a lot of the wheel arches out.... or should I just go with another body.
Old 12-01-2009, 01:18 PM   #10869
tony gray's Avatar
Gaz, it's loooong nose and somewhat tall as well.
From what we've seen very few shells will fit. The Swift is possibly your best bet. And I reckon forget the Alfa, just not enough room out front on that one.
Anything that fits needs a LOT of room forward of the front wheels. Even the BMW Mini is really tight.
tony gray is offline   Reply With Quote
Old 12-01-2009, 02:16 PM   #10870
SilverShelby's Avatar
Here is something to think about....
If tamiya is making M05s with rear wheels drive bodys whos to say that one can't run a BMW Z-3 with big tires on a M05??
or a Miata.
this new car has me wondering about the rules for the TCS racing
cause I would like to get the S800 on a M05.
but don't want to buy it if I can't race the body on it
because in the rules proper body for chassis FWD and Rwd
sorry just think before there is a big stink at a event.
and YES Its a can motor!!!!!
M03,M05L,M06M,FF03PRO,CC01 Jeep,M03L-Yello Mini
ABC Hobby Goose,Genetic
2011 Memphis winner Mini,FWD
2013 e mergent winner Mini
SilverShelby is offline   Reply With Quote
Old 12-01-2009, 02:39 PM   #10871
academygaz's Avatar
Ahh crap, just what I was afraid of. I'll probs stick with the Swift, but as I type this, I'm having a brainwave....how about having TL01 wishbones, upper links, driveshafts, maybe longer shocks....and bingo, new FWD touring car? Only 237mm wheelbase, but HPI's Citroen Saxo and Peugeot 106 woudl fit!
Hmmmm, ideas formulating... nah, sod it, I'll leave it a Mini (Swift).
Cheers Tony.
Old 12-01-2009, 02:41 PM   #10872
racerb's Avatar
Default ..
no mine deals with horizon.... and they are usually out of most useful parts... I have had them bring in 5 minis in the last month and there is only one left, but now guy's are wanting hop-ups and such and seems like all the kool stuff,(up-rights and what-not.... Horizon seems to have on back order) oh well.....
Old 12-01-2009, 02:54 PM   #10873
gtfour93's Avatar
If you are not racing in TCS, try the ABC Hobby Toyota Sports 800 (210mm). I just built one for a friend and there are lots of room for 60D tires.
www.activrc.com
Old 12-01-2009, 06:42 PM   #10874
jcr
i would like to do the TCS that's why I'm considering the mini body....Tamiya doesn't make any other short wheelbase bodies...
Old 12-01-2009, 11:35 PM   #10875
You guys are just pulling everyones leg right???? You can't be serious about the Rover Mini body not fitting with 60D tires. Admittedly tight if using the 2 degree rears, but raising the front slightly takes care of that. Lots of SWB Minis at every TCS race I've been to and no one had to hack on their bodies.
Granpa is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
nitsuj2k
