Like Tree198Likes
Old 11-29-2009, 04:48 AM   #10846
rccardr's Avatar
HEADS UP!!!
The next batch of Red Dot silver can motors ships the second week in December- just in time for the Holidays.
Interested parties who want fast, reliable silver can power for their Mini should e-mail me at [email protected]
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 11-29-2009, 09:41 PM   #10847
2009 Tamiya World Championship - Mini
Long wheelbase configuration wins again. Does anyone know what chassis was used?
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 11-29-2009, 11:30 PM   #10848
rccardr, could you tell me what the difference between the red dot silver can and a black can is? I am currently running a black can in my mini and was wondering what the difference would be with the silver can?
fishnfst is offline   Reply With Quote
Old 11-30-2009, 04:25 AM   #10849
rccardr's Avatar
Sure.
Black can is a 23 turn modified motor with mild timing. Turns around 15,600 at 5 volts out of the box, has fairly soft brushes and runs pretty hot with a 20 tooth pinion gear.
Red Dot silver can is a 27 turn motor using a Tamiya #53689 core, fully TCS legal. Turns around 16-17,500 RPM at five volts, has somewhat harder (and longer lasting) brushes and will come off the track at a perfect 170 degrees with a 20 tooth pinion.
Performance on most tracks is (roughly) equal, but the Red Dots tend to last longer. Our testing shows very close lap times between the two using the same driver, same car & same battery.
I've never lost.
Old 11-30-2009, 09:30 AM   #10850
dannyboy15's Avatar
Send a message via MSN to dannyboy15
Default im back
the minis seam to be starting up again at my local club for the last 5 weeks there have only been 3 of us raceing now there are 6 and counting. because i have been mantaining my tc more than the mini, it has been pushed aside now when i race it is usless round corners. i have rensably hard foam tyers on the front and soft on the back and it looses masses of speed through the corners it also only has a gear diff because the ball diff died would this be the answer of are there any other answers for not losing a lot of speed? are the standered kit tyers any good on the carpet tracks?
dannyboy15 is offline   Reply With Quote
Old 11-30-2009, 01:06 PM   #10851
Trader Rating: 22 (100%+)
Originally Posted by Team Ash View Post
Got a question for the experts out there.
Raced mini last night, my mate had M03 and I have an M05. I was very happy with the car except when cornering. His car ran away at least 1-2 meters on every corner. We even swapped cars and the same result his car was way better through the corners. The only real set up difference is he has cvd's and I have dog bones.
My car washes lots of speed off, his carries speed right through, will dog bones do this? The corners are almost all very sharp 100deg+.
We both have ball diffs, the same shocks, he has team powers tyres and I have Spice. Both cars have silver can motors and are identicle on the straights. They both have plenty of grip with very little body roll and are both planted in corners. We have very different driving styles but when we swapped cars I beat him with his car so it is a set up thing.
Any suggestions?
Terry
I have had a look over my car and after the one race night there is a groove worn around the inside of both front tyres about 2-3mm from the inside edge. I am running spice32 with med/hard inserts (cant remember which). I am running on asphalt where the grip level changes week to week due to dust etc. The other night it was v/high grip. If I am getting too much front grip, could that be the cause of washing off speed and the tyre wear/
I used to get the same wear on my Xray tourer but I did not expect it on the m05.
Terry
Is your car slow..Xray it!.......FK05, M18, M18t
RexX
Assoc...T3,T4, B4
Team Ash is offline   Reply With Quote
Old 11-30-2009, 01:52 PM   #10852
Timbulb's Avatar
I think your main problem is you're comparing an M05 to an XRay.
Timbulb is offline   Reply With Quote
Old 11-30-2009, 03:54 PM   #10853
racerb's Avatar
Default quick one for ya
Hey all got a quick one for ya mini guru's...... my buddy has a M03 (greyish chassis) and he broke an upright... will a upright from the M03L kit work.... figured it should but just want to double check
thanx
racerb is offline   Reply With Quote
Old 11-30-2009, 05:19 PM   #10854
hanzo3's Avatar
Trader Rating: 55 (100%+)
What hopups do you recommend that won't break the bank? I have the M05. Do I just need bearings and dampers? What about lipo options? Do we have to put in lead weights with lipos? Does the stock ESC support lipo cutoff?
hanzo3 is offline   Reply With Quote
Old 11-30-2009, 06:06 PM   #10855
Timbulb's Avatar
thanx
yes.
Old 11-30-2009, 07:04 PM   #10856
portyansky's Avatar
Trader Rating: 54 (100%+)
Yes, yes(with spring set), depends if you are running just at your club(see their rules) or TCS (2400,3200,3400 Orion carbon packs) I dont thin it needs it, I dont think the esc supports lipo cutoff, but just to give you a quick idea, I run the 2400 Orion pack, and use less then 700mah after 5 minute heats with a few practice laps.
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 11-30-2009, 08:44 PM   #10857
jcr
Just wondering, do people have issues fitting the 60D tires on the short wheelbase mini? Doesn't the 60D tires seem a little big for the wheel well of the old mini body?
Trying to figure out what body to get next...
jcr is offline   Reply With Quote
Old 11-30-2009, 08:50 PM   #10858
Default Tyres
A race buddy of mine put 60Ds on his mo5 for last weeks racing and had to cut his body for them to fit.
Terry
RexX
Assoc...T3,T4, B4
Old 11-30-2009, 10:02 PM   #10859
Skitee's Avatar
thanx
You'll just need to check something, the swb M-03 kits use 1150 bearings in the uprights as did the older lwb M-03L kit but the 2006 cooper lwb kit uses 1050 bearings in the uprights.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 12-01-2009, 04:24 AM   #10860
jcr
Terry
any chance you got a picture of it? Want to see how much you need to cut out? Or what tires do people use with the old mini body (for TCS)?
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
