Like Tree200Likes
Old 11-23-2009, 12:10 AM   #10801
hanzo3's Avatar
Trader Rating: 55 (100%+)
What are the size of the bearings for the M05?
# 850 Ball bearings x 6pcs.
# 1150 Ball bearings x 12pcs.
Trying to buy some from avid rc.
hanzo3 is offline   Reply With Quote
Old 11-23-2009, 04:12 AM   #10802
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
The M05 Pro and M05 Standard use mostly the same bearings:
1105 bearings - 8
850 bearings - 6 (front gear box AND steering rack)
the differences is the Standard uses 4 1150 bearings in the rear hub (for a total of 12 1150 bearings)...The Pro has aluminum rear uprights and they use 4 1050 bearings (which is the same size the M03R aluminum knuckles uses - so if you got both of them on your car, you'd need 8 1050 bearings)
there you go the standard uses metal bushings in the steering rack, but you might as well replace them if you're orderin'
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 11-23-2009, 06:28 AM   #10803
jcr
Since I'm new to Mini... I was wondering what are some good spare parts to have for the M03? Like which part tends to break more often?
jcr is offline   Reply With Quote
Old 11-23-2009, 08:39 AM   #10804
Trader Rating: 35 (100%+)
Steering knuckle: I'm new to Mini also (M05). After my first outing (3 weeks ago) I needed to replace the front steering knuckle. It became deformed in a crash. I decided to go with the alloy knuckles for the front and the rear.
Body posts: I like to cut my body post to the proper length for the body I'm using. So, I can never have enough body posts of differing lengths.
Rims: Last, the lip of one of my rims cracked. I was told that the Suzuki rims are strongest. If you haven't already mounted your tires, you may want to look for a set of the Suzuki rims.
Geppetto is offline   Reply With Quote
Old 11-23-2009, 10:24 AM   #10805
jcr
Thanks for the info. But body post for the M03 means I'll need to order that huge parts tree (C Parts) every time?
Old 11-23-2009, 09:39 PM   #10806
For those running lipos in their mo3's are you weighting the chassis or batteries at all?
fishnfst is offline   Reply With Quote
Old 11-23-2009, 09:45 PM   #10807
mild seven's Avatar
Trader Rating: 62 (100%+)
Send a message via MSN to mild seven
With my M03, i bring the lipo back up to a similar weight to 4600 nimh pack (about 320 grams). Thats the only weight i add.
mild seven is offline   Reply With Quote
Old 11-23-2009, 10:38 PM   #10808
hanzo3's Avatar
What is the actual size of the bearings? I want to order from avidrc.com
Old 11-24-2009, 03:50 AM   #10809
k_bojar's Avatar
whoops - sorry about that...
850 = 5x8mm
1150 = 5x11mm
1050 - 5x10mm
Old 11-24-2009, 04:52 AM   #10810
Timbulb's Avatar
That huge parts tree is $9 at my LHS.
Timbulb is offline   Reply With Quote
Old 11-24-2009, 05:45 AM   #10811
the parts for M chassis cost nothing
i had to order a new chassis parts tree for my new M05 and it cost me $7
the screw for the steering system is too short and it destroyed the chassis
sidecarphil1 is offline   Reply With Quote
Old 11-24-2009, 03:45 PM   #10812
jcr
For springs, do you guys use the short (53333) or the tuned springs (53440)? If you use 53440 then which springs to use since they're slight stiff and is progressive compared to 53333.
Old 11-24-2009, 05:30 PM   #10813
NT
NT's Avatar
Trader Rating: 21 (100%+)
May I suggest you take a trip to www.rc-mini.net
You'll be amazed at the answers you can find there......
NT is offline   Reply With Quote
Old 11-24-2009, 05:44 PM   #10814
jcr
well it looks like they suggest both type of springs sets....
Old 11-24-2009, 10:25 PM   #10815
caltek1's Avatar
Trader Rating: 36 (100%+)
jcr,
The 53333 spring set allows you to run shorter shock lengths. The other sets to look at are the short TRF springs which come in:
white-extra hard
blue-hard
yellow-medium
red-soft.
Most seem to use the short TRF blue, yellow and red. The springs from the 53333 set are the same length. The 53440 set are normal length, I have never used them on a mini.
The shocks can be shortened by adding or subtracting internal spacers, which change the length and the amount of droop. The shock piston will also affect the shock. I use only a 3mm spacer on each shock when using full length TRF shocks.
Comes back to how you like your car to handle for your driving style.
Having a selection of the above springs just gives more sutle tuning options or can cause massive grief.
BTW,
If you read the content at rc-mini-net you will see that spring rates do not radically change the car's handling. You just need to find a setup that works and then practice on being consistant.
Later,
Calvin.
caltek1 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
