Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 11-18-2009, 09:15 PM
  #10771
mugler's Avatar
Originally Posted by Ray k
Yes ,Jamie runs M-05L 239mm and I run M-03L 239mm.
The setup and tires are totally different for both!
The M-05 runs on soft spring and damping. Also softer tire inserts
The M-03 runs on firmer springs and damping. Also firmer tire inserts.
Thanks for the info.
What body are you using with your 239mm chassis" i guess Tamiya offers only the modern mini cooper right?
mugler is offline
Old 11-18-2009, 09:28 PM
  #10772
gtfour93's Avatar
Trader Rating: 22 (100%+)
Default M-05 Datsun 280ZX
gtfour93 is offline
Old 11-18-2009, 09:55 PM
  #10773
Rozzt_iwa's Avatar
any 1 notice its says its 1/12 scale not 1/10
Originally Posted by gtfour93
Rozzt_iwa is offline
Old 11-18-2009, 10:41 PM
  #10774
R/C Tech Elite Member
monkeyracing's Avatar
I really wish there were more mid and long wheelbase bodies available. Yeesh.
Jim
monkeyracing is offline
Old 11-19-2009, 03:54 AM
  #10775
k_bojar's Avatar
Trader Rating: 30 (100%+)
yes, because 'technically' the m-chassis ARE 12th scale and not 10th scale
k_bojar is offline
Old 11-19-2009, 08:09 AM
  #10776
Ray k's Avatar
Trader Rating: 47 (98%+)
Yes, BMW modern coopers
BMW long cooper 50971 , long cooper S 51335 , Long cooper S Lt. Weight 84064
Ray k is offline
Old 11-19-2009, 10:59 AM
  #10777
Rozzt_iwa's Avatar
why would tamiya change it know all the rest of the M-05 boxs have 1/10 on them.
Old 11-19-2009, 03:03 PM
  #10778
oldnwise's Avatar
Are you sure?
Current Mini Cooper S wheel base is 2470mm compared to 239mm for Tamiya LWB equivalent. Around 1/10.
BMC Mini from the 60's had a wheel base of 2040mm compared to 210mm for the Tamiya SWB equivalent. Also 1/10.
I think you'll find it is the Datsun 280 ZX which is 1/12 scale. Wheel bases I could find on the web for the different models ranged from 2320mm to 2520mm which is closer to 1/12 scale when compared to the 210mm SWB M05 it will be mounted on.
More details are on the Tamiya America web site where it is still referred to as 1/12 scale . Kit p/n is 92213.
http://www.tamiyausa.com/product/ite...oduct-id=92213
oldnwise is offline
Old 11-19-2009, 03:13 PM
  #10779
Does the 3Racing foam bumper for the M05 fit on the M03M?
Arjen is offline
Old 11-19-2009, 04:45 PM
  #10780
Bumper will not fit. Different screw locations.
Jim
Old 11-19-2009, 04:49 PM
  #10781
mugler's Avatar
Great, Thanks.
mugler is offline
Old 11-20-2009, 03:14 AM
  #10782
Jim
Thanks for the information. I couldn't find any 3racing bumper for the M03m and the Square one is expensive and not in stock at all shops.
Arjen
Arjen is offline
Old 11-20-2009, 04:26 AM
  #10783
k_bojar's Avatar
Originally Posted by oldnwise
Are you sure?
yes I am sure
its more because of the size of the chassis not the dimensions sit a 12th scale pan car and a M03/M05 next to each other- the wheelbases will be very close
and as far as I knew - that kit wasn't a pure tamiya offering in the beginning, I thought it was some other company's body and Tamiya was 'sub-contracting' (so to speak) the M05 chassis for it
k_bojar is offline
Old 11-20-2009, 04:34 AM
  #10784
k_bojar's Avatar
i believe its JUST on this particular kit - because of the 'special' body that's offered with it
k_bojar is offline
Old 11-20-2009, 06:04 AM
  #10785
The scale thing is more of a "guideline" than anything else. If you sit a Tamiya VW Beetle (M-04L) next to a Colt New Beetle (M-03S) the difference is huge. The old Tamiya Beetle, which at full size is a smaller car, dwarfs the Colt New Beetle.
Another example of "scale-ish." In our TT-01 class (1:10) there is a 49 Mercury and a Lotus Elise that are about the same size. HUGE difference between these cars in the real world.
Jim
