Like Tree169Likes
Old 11-11-2009, 06:21 PM   #10726
Trader Rating: 30 (100%+)
Originally Posted by portyansky View Post
gonna be building the m-05 tomorrow. I was just wondering what to do with the diff. In my m-03 i had a bal diff (sold it). So I was wondering if I should pack it with heavy diff oil (300k) or just build it as is.
I run the gear diff that the kit comes with.... It works Very well. Instead of using a fluid, try using a THICK silicone lube instead....
I have been very happy with my M05. It took a weekend to get the right tire combo and shock setup, but it runs very well.
Former fast guy just trying to keep up......
Jamie Hanson is offline   Reply With Quote
Old 11-11-2009, 06:39 PM   #10727
gashuffer's Avatar
Trader Rating: 48 (100%+)
Run it dry.
T-Sal
gashuffer is offline   Reply With Quote
Old 11-11-2009, 06:43 PM   #10728
subaru73's Avatar
Trader Rating: 41 (100%+)
Default m05 diff
build it per instructions and use tamiya anti wear grease.
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 11-11-2009, 07:02 PM   #10729
portyansky's Avatar
Trader Rating: 54 (100%+)
Well, i have one that i built for my m03 that hasnt been used. I guess i will experiment with it stock and one with thick diff fluid (100k or 300k). I will report back. But if anyone has tried this, please chime in to save me some time/frustration.
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 11-11-2009, 07:59 PM   #10730
subaru73's Avatar
i personally have not tried that route but i will suspect that the fluid will leak out and not work very well.to make it work the best you should use a heavy type of grease for the best results.
Old 11-11-2009, 08:10 PM   #10731
ioyasm's Avatar
To be honest I dont really see the advantage to this except you wont have any brakes.
you dont have brakes but you can power out of the corners a lot quicker ,what some have done is put synthetic glue in the diff to lock it up some to. I seen on rc mart for the mo5 is that through 3 racing ??????? there is a locking spool availabe for the diff to if that will help
ioyasm is offline   Reply With Quote
Old 11-11-2009, 09:01 PM   #10732
F N CUDA's Avatar
Try shimming the gear diff with extra shims on each side, thru a tip from another racer I used plastic body saver discs cut down to fit over the outdrives.
Then I used the AW grease.
Don't over tighten/strip the screws holding the diff gear halves together.
It'll be very tight but still be a diff and not a spool.
I like mine a lot!
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 11-12-2009, 04:07 AM   #10733
hi, new m-chassis bodies by Miwa Hobby. woo woo.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 11-14-2009, 11:08 AM   #10734
Shangrila's Avatar
Building the M05 this week , and been getting everything ready.
1. Any change in your opinion on SS suspension hinge pins?. I have spares ones from my old kits that would fit.
2. confirming that I read right to put AW grease into the TA03 diff? (this is the same thick grey stuff that comes with the Tamiya UJs pack)
3. the pillow ball for the steering rod attaching to the knuckle: I have the tamiya front alu knuckle set (wish the pro had come with these instead of the rears!), what is the impact if I have the ball high on 5mm spacer, or low directly on the knuckle. I believe this affects bumpsteer?
4. I need pistons! which is size for the TRF mini cylinders? There are several sizes (1.2, 1.3, and non stated) available ?
Can't wait to get on track Friday night! Indoor carpet.
Shangrila is offline   Reply With Quote
Old 11-14-2009, 01:45 PM   #10735
stulec52's Avatar
Trader Rating: 26 (100%+)
Send a message via ICQ to stulec52 Send a message via AIM to stulec52
That Zakspeed Capri looks awesome !
although I don't know if anything on the front row would fit on a front wheel drive car.
www.pmhobbycraft.ca/store/
www.tamiyaclub.com/
stulec52 is offline   Reply With Quote
Old 11-14-2009, 02:21 PM   #10736
I GOT THE M05 WORKING FOR ME
only .05 slower with it after 3 hours setting up
and i had the M03 for 3 years !!!!
i will post my set up on here tommorrow after my first race
i am the fastest in our club now
sidecarphil1 is offline   Reply With Quote
Old 11-14-2009, 03:24 PM   #10737
stulec52's Avatar
Default M03 setup
Is there a good M03 carpet setup out there?
Needs to have Tamiya tires.
I just would like to try back to back with my 03 and 05 to actually see on the clock which one is faster.
I suspect my 05, but given that it still likes to tip when really pushed perhaps my 03 is the safer bet, but at least if I know the lap times for each then the descision is an informed one !
thanks
Stu
www.tamiyaclub.com/
Old 11-14-2009, 05:10 PM   #10738
hanzo3's Avatar
Trader Rating: 55 (100%+)
What is the general consensus M03 setup for the Aliso Tamiya track?
hanzo3 is offline   Reply With Quote
Old 11-14-2009, 11:27 PM   #10739
thanks
Stu
M03
blue rear springs with 400 oil in the shocks and 5mm spacer under the piston
red front springs with 400 oil in the shocks and 5mm spacer under the piston
about 1.5 degrees front toe out
M grip tyres all round and superglue on the side of the tyres
ball diff fitted
M05
blue rear springs with 500 oil in the shocks and 6mm spacer under the piston
red front springs with 600 oil in the shocks and 6mm spacer under the piston
5mm wheel hubs and 1mm spacer on them on the rear
about 1 degree toe out front
kit D tyres with superglue on the sides and on the first piece of outer tread on the front tyres ,
the car WONT grip roll now and i am only 0.05 seconds slower with my M05 than i was with my M03
use the gear diff in the M05 , the ball diff causes it to veer to the left on power and pull sraight when cruzing ,
Good luck with it and let me know how you get on
Old 11-14-2009, 11:53 PM   #10740
gtfour93's Avatar
Trader Rating: 22 (100%+)
I like the Toyota Celica LB Turbo Gr.5. I just picked up an M-05 Pro myself, and will start the build soon. I've been using my M-01, but it's time for a change. M-Chassis are so much fun!
www.activrc.com
gtfour93 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
AM03GT
