Like Tree198Likes
Old 10-27-2009, 07:02 AM   #10591
monkeyracing's Avatar
That's a nicely done M-05. Very cool. I have a few questions about some of the parts though: What is the metal part attached to the chassis near the pinion end of the motor? And, what is the carbon piece on top of the chassis, just forward from the servo?
Thanks!
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 10-27-2009, 07:41 AM   #10592
eevul's Avatar
What kind of speed controllers are people using for their M05? I am building mine and I am looking for a brushed ESC with lipo cutoff for under $50.
eevul is offline   Reply With Quote
Old 10-27-2009, 10:05 AM   #10593
gashuffer's Avatar
Trader Rating: 48 (100%+)
The M05 kits come with one.
T-Sal
gashuffer is offline   Reply With Quote
Old 10-27-2009, 11:35 AM   #10594
i now own 2 M05s
sidecarphil1 is offline   Reply With Quote
Old 10-27-2009, 11:53 AM   #10595
eevul's Avatar
Maybe I should of stated that I am running an M05 pro which does not come with the speed controller. If I had the one with the speed controller, I wouldn't be asking
Old 10-27-2009, 04:14 PM   #10596
gtfour93's Avatar
Trader Rating: 22 (100%+)
The TEU-101BK has a LiPo cut off?
gtfour93 is offline   Reply With Quote
Old 10-27-2009, 04:27 PM   #10597
The only M-05 that currently ships with a lipo cutoff capable ESC is the FIAT 500 Abarth. It has the TEU-104BK. All other M-05s and M chassis are supplied with the TEU-101BK, which does not have a cutoff.
Jim
Stab it and steer.
Old 10-27-2009, 06:23 PM   #10598
gashuffer's Avatar
You never know.
T-Sal
Old 10-27-2009, 09:16 PM   #10599
Quick question regarding the Tamiya Aluminum Damper set. The directions call for a silicon o-ring on the inside of the shock body, and a regular 3mm o-ring on the shock shaft. The kit comes with both clear and black o-rings, which is which? If I were to guess, Id say the silicone ones are clear, but usually when I guess Im wrong.
Also, I have the M05 Pro kit, should I just use the shock oil that came with it? Thanks, sorry for all the questions but Im just getting back into minis after a long hiatus. (My other car is a M01)
Tristar Racing is offline   Reply With Quote
Old 10-27-2009, 10:25 PM   #10600
gtfour93's Avatar
Also, I have the M05 Pro kit, should I just use the shock oil that came with it?(My other car is a M01)
Your guess is correct about the o-rings. I've heard from other people that the kit dampers are fragile. Go with the aluminum dampers if you decide to replace them, item #54000.
Old 10-28-2009, 07:18 AM   #10601
Yea, I was referring to the aluminum dampers with my question. I heard so many people say bad things about the clear plastic ones on the m05 pro, I decided to upgrade right away before I even built the kit. I just wish they were more clear about which o-ring was which in the aluminum damper assembly directions.
Old 10-28-2009, 08:47 AM   #10602
gtfour93's Avatar
Do you still have it? I sent you a PM, if you have a spare part. It's the upper arm lock, attached on the top of the gear case. It's similar to MN008 on this link.
http://farm3.static.flickr.com/2224/...7ecb9ce3_o.jpg
Old 10-29-2009, 07:45 PM   #10603
racerb's Avatar
Default newbie racer
Hey all, this weekend is my first time racing a mini ( I just bought and built a M03L) so there is so much info on this thread it has taken awhile to get everything all together... anywa I was hoping I could just get a sum-up of what I can try doing to the car on raceday if certain things go wrong....
if the car traction rolls what are some things I can do to make it a bit more stable?
if anytime I go around a corner the back end swings around?
if I have no steering?
if I keep going through gear sets or something along those lines?
not sure what other issues will arrive come race day and I am sure there will be some but maybe just hoping to get some info on things I can try... you don't have to post set-ups or anything as I think I have built it pretty much the same as everyone else (I hope)
Oh and by the way we are racing on carpet, stock tires,stock motor etc... I would ask the other guy's at the track but this is the first time that we will all be racing these cars, so we are all kinda on the same page
thanks for the help
racerb is offline   Reply With Quote
Old 10-30-2009, 02:01 AM   #10604
cannon's Avatar
Trader Rating: 35 (100%+)
A quick build report on the 3 Racing Spool for the M05
managed to get my hands on one of these.
Its construction is very close to that of a Tamiya 416 spool. In fact it actually uses exactly the same plastic cups
Assembly is simple and fit in the M05 is very good with a little movement from side to side but nothing to worry about. Only problem I had was one of the locating pins was a margin too long and it would distort the bearing that trapped it. A simple rub of the end of the pin on wet and dry paper solved that.
Next step is a test run with all gears in place
Weight 16.5g with bearings
Coimparison spool ... Square spool with bearings 25.5 g
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 10-31-2009, 06:32 PM   #10605
Whilst checking the operation of my M05, I have noticed that there is a lot of vibration when the steering is at (or near to) full lock and under power. For the first ~50% of the steering travel from neutral everything is normal, but any more steering travel than that and the vibrations start and get worse with more steering. I am using Tamiya rebuildable universals, and standard M05 outdrives (with an o-ring). There doesn't appear to be any binding in the steering throughout the full suspension travel. I have tried removing the o-ring from the outdrives, and shimming any sideways play from the UJ's in the uprights, but the vibration still occurs. I then tried my M03, which also has Tamiya UJ's, and that does the same thing, only the steering gets nearer to full lock before the vibration starts.
Is this normal, does anyone else get this with their mini?
I'm thinking maybe this is a case of the UJ's reaching the limit of their 'normal' travel and then binding when more steering is applied? I don't think I've ever tested the steering whilst also under power on the pit stand before, normally just checking steering or power independently, so I've never noticed it. The only other cause could be that I'm running a fixed axle/spool in both the M05 & M03, and that is somehow causing the vibrations. I will have to try a gear/ball diff in one of the cars to see if the vibration goes away.
Toon is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
