Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 09-10-2003, 06:35 AM   #91
dirk's Avatar
Originally posted by psycho
Dirk, that should point forward edge of the rear wheels in toward each other and add rear grip at the expense of tire wear and drag. If you are having trouble keeping the backend in the back, toe in would be one thing to try.
actually, the back end has this weird "axle-hop" on really tight turns. If turning right then the left rear tire goes "RATATATATA!" this happened ever since I lowered it. Maybe it needs more rear camber?
dirk is offline   Reply With Quote
Old 09-10-2003, 06:59 AM   #92
fowlerJr68's Avatar
The reason it hops is because the rear insert is to soft. The edge of the tires are folding. I found that out after I won the Canadian Finals in mini. I was brushing speed around the corners yet i still came first overall. Where do u guys race? Do any of you run at the Tamiya track in California? Because I was wondering what tires hook up there.
thanx
STeve
fowlerJr68 is offline   Reply With Quote
Old 09-10-2003, 08:53 AM   #93
Difuser's Avatar
Also could be a light body rub
I thought Lindsay won again Steve?
For tires run A's if you are coming down some go to the S but best corner speed is from the A's just mess with insert to keep your speed up through the corner
Tamiya USA
TRF
Difuser is offline   Reply With Quote
Old 09-10-2003, 08:57 AM   #94
fowlerJr68's Avatar
Hey did, just, but he can't go because of college. So, i get 2 go
thanx for the advice on tires
STeve
Old 09-10-2003, 09:09 AM   #95
Difuser's Avatar
Come over and say hello when you come down. T Wright knows who I am.
Any idea where you guys are staying this year?
For insert I prefer to run the 50d black shaped insert in the rear to keep the tire with air gap/grip but it still rolls freely. For fronts run a 24mm insert with a mini foan insert inside of it. It fills the carcass up good and lets it roll through the turns.
Did you guys run a 1-way during the finals up there?
Tamiya USA
TRF
Old 09-10-2003, 09:13 AM   #96
fowlerJr68's Avatar
Ya we're staying at the Court Yard in Laguna Hills. It'll be awsome, it's my secon year of racing and this is the biggest race i've been at. Although i will be attending cleveland aswell in november.
STeve
Old 09-10-2003, 09:17 AM   #97
fowlerJr68's Avatar
I know that Tom Lindsay did run a one way but i didn't. Should i run a one-way there? Also the foam for the rear u talk about, is it the firm foam or the kit foam?
thanx
STeve
Old 09-10-2003, 09:27 AM   #98
Difuser's Avatar
They(Courtyard) were mondo expensive this year so we won't be there.
On the 1-way try it Tom loves it but I have not been a big fan in the past.
Either foam you can tailor your tires a bit depending on which foam you use.
I assume you are running the 03/03L this year as the 04 has had it's nuts cut off with the rule changes.
Tell Tom I'll take the beer he kept trying to get me to have last year. Say hello to Mike for me also he is coming also I saw he won F1
Tamiya USA
TRF
Old 09-10-2003, 09:29 AM   #99
Difuser's Avatar
Also same with the 24mm insert vary to conditions
Tamiya USA
TRF
Old 09-10-2003, 09:30 AM   #100
fowlerJr68's Avatar
ok thanx...i have so many tires that are unmounted so we'll c when we get 2 the track.
STeve
Old 09-10-2003, 09:47 AM   #101
Oneways on a mini? What diff would that be? And for what car? How does it handle. Sorry, but first time I heard of this. Any of you guys have comments on using either the short plastic cva shocks or the pink alloy one? I ended up using the alloy even thought I had both. the mini cva is just too short for the sport tuned spring.Seems like the spring is too compressed and feels that the shocks are too stiff.
sipaboy is offline   Reply With Quote
Old 09-10-2003, 10:07 AM   #102
Difuser's Avatar
Sipa the 1-way is from the old TA02-03 series. It frees the car into the turn as thee is no drag from the drivetrain along with the pull of a locked/spool front end.
For shocks I use the alum as they dampen better along with more precision on a bumpy track in can be a little to tall and restrict wheel travel. as for spring length I run no ride height spacers on the long shock body so ride height is about 3.5mm not sure how well it works with the Mini CVA's though
Tamiya USA
TRF
Old 09-10-2003, 10:13 AM   #103
tomdav's Avatar
Default Legal
Is this a legal upgrade?
Tom
Camas WA
www.davesrctracks.net
tomdav is offline   Reply With Quote
Old 09-10-2003, 10:16 AM   #104
fowlerJr68's Avatar
yup.
Old 09-10-2003, 10:17 AM   #105
tomdav's Avatar
Default is this the part.
Part 53200.
Tom
Camas WA
Forum Jump
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 8 01-01-2007 05:05 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 1 11-08-2005 09:47 PM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
