Like Tree103Likes
Old 10-08-2009, 07:40 AM   #10396
Core Creations's Avatar
Trader Rating: 93 (100%+)
Send a message via AIM to Core Creations
I use a tiny bit to keep the comm clean....I put a drop or 2 on...run the motor at 3 volts, then spray out and relube the bushings. For racing it tends to dirty up the comm, which is a silver can killer.
As far as Tribo...that's really really hard to get...I am 99% sure they don't make it any more. I like Zubaks..
Originally Posted by Jam-ehz View Post
What's the consensus these days on using comm drops with their silver cans?
With the advent of Brushless, talk about them is all but gone, but we still use black and silver cans up here for our TCS races.
I still have a little bit of Zubak Speed juice, I think it does help a bit in the RPM department, but who knows..
Is Tribo still around?
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 10-08-2009, 09:51 AM   #10397
CARD's Avatar
Suggestion on how to make the M-05 runs well:
Lock/seal up your M-03 somewhere, just leave yourself and M-05 together... Sure "you guys" will work it out...
I finally get my ABC Genetic dial in after I put aside my M-04....
Commander At Riot Desert
Complete Adult's Repairing Depot
Can Anyone Refuse Doggie-style
CARD is offline   Reply With Quote
Old 10-08-2009, 10:16 AM   #10398
gashuffer's Avatar
Trader Rating: 48 (100%+)
I want to change my fixed camber links to threaded turnbuckles . I can't find any online that are small enough. What size do you use? Duratrax makes a 3x18 but thats to long. Also can somebody post some links. I give up on the hunt.
T-Sal
gashuffer is offline   Reply With Quote
Old 10-08-2009, 10:47 AM   #10399
I found the discussions about the handling problems to the M05 interesting.
could someone explain the difference betwen the m03 and the m05 in these situasjons.
1. pulling of the line.
m03:
m05:
2. brakes for turn. while turning perhaps
m03:
m05:
3. acellerates out of the turn. how do you spell it again :P
m03:
m05:
annything else?
MatsNorway is offline   Reply With Quote
Old 10-08-2009, 11:00 AM   #10400
Originally Posted by caltek1 View Post
Tristar Racing
Regards,
Calvin
Calvin,
I am not sure I can get the Nulon product you described, but this appears to be a similar product:
Liquid Wrench
11oz. Heavy Duty Silicone Spray Lubricant
(I would include a link, but I do not have enough posts yet to do so, just drop the description in google)
So basically, whereever the manual calls for grease, just use the spray instead? (Except for the in the gear diff, of course) Dog bones (drive shaft), gears, etc?
Thanks again for the help, I think Im starting assembly tonight.
Tristar Racing is offline   Reply With Quote
Old 10-08-2009, 01:11 PM   #10401
caltek1's Avatar
Trader Rating: 35 (100%+)
Tristar Racing,
I use the silicone lubricant on the gears and the chassis. I do not use the kit supplied dogbones, I purchase the mini universals which are a way better option. I use Tamiya anti-wear grease on the ends, liberal amount and the same for the rear axles.
If I fit a gear diff I apply a small amount of anti-wear grease to the internal gears. If using a gear diff I normally turn it into a spool by gluing it up with super glue.
On a TAO-3 ball diff I use the Tamiya anti-wear grease on the balls and diff plates and black grease on the thrust washer.
Regards,
Calvin.
caltek1 is online now   Reply With Quote
Old 10-08-2009, 03:22 PM   #10402
Tristar Racing,
Regards,
Calvin.
I have really be trying to understand this, but I still cannot, why do people lock up the gear diff? If it is locked up, wont that keep the inner and outer drive wheels rotating at the same speed when cornering, causing a hopping-like condition? How is this beneficial?
Old 10-08-2009, 04:53 PM   #10403
Flyingpig's Avatar
Default Spool
Based on my understanding of differentials in general, not necessarily RC specific, is the spool does indeed eliminate all differential action. The advantage is that both wheels rotate equally, putting the power down evenly. Nice straight, powerful acceleration. But, it sacrifices corning.
I believe they are commonly used in drag racing and drifting.
Someone with more RC experience might have a better answer specific to the hobby.
Flyingpig is offline   Reply With Quote
Old 10-08-2009, 05:04 PM   #10404
mcdogboy's Avatar
With minis you'll be spinning the drive wheels on power anyway, gear diff, ball diff, or spool.
mcdogboy is offline   Reply With Quote
Old 10-08-2009, 05:20 PM   #10405
lil Dalton Rc's Avatar
which mini should i buy unlimited money unlimited time to build just want a good one for the money any sugestions ...own a hobby shop nedd the best bang for my buck have a brushless sys thts 1/10 scale will it fit?
Dalton Rc is in my Front yard...Seriously
AKA Brindle
lil Dalton Rc is offline   Reply With Quote
Old 10-08-2009, 05:43 PM   #10406
mcdogboy's Avatar
yeah, pretty much any brushless will fit, too much and you'll melt it though.
Old 10-08-2009, 09:34 PM   #10407
PaPeRo's Avatar
Best Mini are ABC Genetic and Atomic VM II.
PaPeRo is offline   Reply With Quote
Old 10-08-2009, 09:35 PM   #10408
To those that use the silicone spray on their gears and other items, I picked up a can of CRC heavy duty silicone munti-use lubricant. Has anyone tried the stuff? Sorry for revisiting the subject, but I would be bummed if I messed up gears and other parts by using it.
Old 10-08-2009, 10:55 PM   #10409
monkeyracing's Avatar
Nope, the CRC silicone spray is great stuff. I use it in the gearbox, but not in the diff. Keeps everything smooth and quiet. Just use a little shot and you're good to go.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 10-09-2009, 02:29 AM   #10410
tony gray's Avatar
Due for release 22nd October...
tony gray is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
