Like Tree51Likes
Old 10-04-2009, 01:33 AM   #10351
monkeyracing's Avatar
The 3Racing dampers will work just fine. Good bang for the buck.
It would also be advisable to invest in a good set of springs. The Tamiya 53333 (short touring car springs) are probably your best bet, and they're cheap, too.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 10-04-2009, 03:46 AM   #10352
dannyboy15's Avatar
Send a message via MSN to dannyboy15
Originally Posted by s22jgs View Post
guys im after some advice....just got my M-05 and the friction shocks are like pogo sticks.
I have read about getting the TRF shocks.... is it worth paying for the Tamiya set, or is the Hobbysave JazRider set, or the 3 racing set just as good?
Im totally new to the world of tamiya.
im new as well but in mine i had cva super mini shocks and they were good but iv been given some ally ones now
dannyboy15 is offline   Reply With Quote
Old 10-04-2009, 03:56 AM   #10353
Low_E's Avatar
Send a message via MSN to Low_E
go for the Tamiya-shocks if you can afford. They are simply VERY good and it keeps your car "Tamiya" which is a must in our country (Belgium) if you want to compeed in the National Tamiya-cup.
Also it will be easier to find Shock-setup-advice for the TRF-shocks ... allthough there is not much you can do on the shocks of a mini. Just get them right and you will probably never have to change them.
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 10-04-2009, 04:23 AM   #10354
Rozzt_iwa's Avatar
Send a message via MSN to Rozzt_iwa
what weight shock oil are ppl using i cant remember whats in mine
B5M (17.5),cactus (17.5),sc10 short corse truck (10.5), sakura s zero VTA(21.5),mini-z
www.nbhc.com.au
supporting local hobby shops
http://www.iwawrestling.com.au
Rozzt_iwa is offline   Reply With Quote
Old 10-04-2009, 04:29 AM   #10355
cannon's Avatar
Trader Rating: 35 (100%+)
40wt is a good starting point
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 10-04-2009, 04:31 AM   #10356
Rozzt_iwa's Avatar
is the front and rear?
www.nbhc.com.au
Old 10-04-2009, 04:31 AM   #10357
Pro10noob's Avatar
I use Tamiya 400 or 500 oil and white springs at the front and red(low grip) or yellow(medium to high grip) on the rear.
Works like a charm.
cheers Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 10-04-2009, 04:35 AM   #10358
cannon's Avatar
Both
Old 10-04-2009, 04:46 AM   #10359
caltek1's Avatar
Trader Rating: 33 (100%+)
The shock oil you use can be dependant on the number of holes in the piston. The pistons you have fitted in the shock will either make the shock either reactive or less reactive. The other factor is the type of shock you are using. The super mini CVA's will have a different reaction to the TRF shock. The TRF shock will have better damping action due to better build quality and less internal resistance.
However as Greg has said if using TRF then 40 Wt all round is a good starting point, with either two or three hole piston.
Just my two cents worth.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 10-04-2009, 05:00 AM   #10360
Rozzt_iwa's Avatar
what springs
currently blue front yellow rear
www.nbhc.com.au
Old 10-04-2009, 05:09 AM   #10361
cannon's Avatar
what springs
Just use what works at your track.
Blue and yellow are fine
Old 10-04-2009, 05:10 AM   #10362
caltek1's Avatar
Rozzt_iwa,
I currently run similar to your spring setup, however you can go to the attached link and they will say it does not matter. It all comes back to your track, car setup, tyres and your driving technique.
Thanks TonyG for the rc mini site.
http://www.rc-mini.net/joomla/index....d=44&Itemid=60
Regards,
Calvin.
Old 10-04-2009, 09:20 AM   #10363
PaPeRo's Avatar
The TRF dampers are not that expensive if you know where to get them. I've seen them for $40 which is not that much more than the NEW V2 3 Racing units. The TRF are better because they have titanium coated shafts so are very smooth. If you're serious and plan to race at the track then get the TRF. OTOH if you only bash then you don't need the TRF but it's nice to have. BTW if you get the 3Racing dampers make sure you fill the dampers with oil. Mine came with only some oil in it and was not useable out of the box.
PaPeRo is offline   Reply With Quote
Old 10-04-2009, 10:46 AM   #10364
gashuffer's Avatar
Trader Rating: 48 (100%+)
What about the Tamiya TRF M chassis dampners. They are a little shorter than the on-road shocks?
T-Sal
gashuffer is offline   Reply With Quote
Old 10-04-2009, 11:04 AM   #10365
PaPeRo's Avatar
Yes they're 2mm shorter so they don't need internal spacers to limit shock travel like the TRF TC shocks.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
