Old 09-30-2009, 06:58 PM   #10321
pull-start's Avatar
Trader Rating: 27 (100%+)
Originally Posted by tony gray View Post
Since the M05 was first announced, we at rc-mini reckoned that the whole thought process behind the car was mainly just to allow the fitment of lower profile bodyshells.
And...coming soon..
That is a MUST HAVE !!!
pull-start is offline   Reply With Quote
Old 09-30-2009, 08:46 PM   #10322
niznai's Avatar
Originally Posted by mcdogboy View Post
Tamiya body?
Odd if so, wouldn't have thought tamiya would make a RWD car on a FWD chassis.
Maybe it will be RWD?
Odd to see the Datsuns conspicuously missing from tamiya's lineup of cars, by the way (the 510 would probably sell like hot cakes). And odd to see this one released on the mini platform too. Perhaps they want to use their older molds used for the plastic models?
Is there any RWD configuration for the M05 platform at the moment?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 09-30-2009, 10:09 PM   #10323
cannon's Avatar
Trader Rating: 35 (100%+)
Interesting the picture says 12th scale !!!!
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 09-30-2009, 10:40 PM   #10324
mcdogboy's Avatar
I was wondering how a 280zx was gonna fit an m05 at 1:10 scale.
Odd.
mcdogboy is offline   Reply With Quote
Old 09-30-2009, 11:52 PM   #10325
Moxy's Avatar
1:12th scale on a short wheelbase..
it's still pretty sexy, but the rear body posts will stick out like sore thumbs on that body, unless they a) supply shorter posts or b) expect you to cut yours down to fit.
I like that "driver included", i hope he drives better than I do.. or pump him full of lead (weights) and sit him mid-ships like a McLaren F1 config..
Moxy
Moxy is offline   Reply With Quote
Old 10-01-2009, 01:22 AM   #10326
caltek1's Avatar
Trader Rating: 33 (100%+)
What's the four capacitors used for?
gashuffer,
To make my car look fast. Just kidding.
"This 4 Super Capacitor board allows your Esc to run cooler and more efficiently."
I have this fitted to both of my mini's. I think it looks trick.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 10-01-2009, 01:49 AM   #10327
sosidge's Avatar
And...coming soon..
Is that for real or a prank?
Because it seems like a very un-Tamiya release. Wrong wheel drive. And that body is a poor representation.
Old 10-01-2009, 02:49 AM   #10328
tony gray's Avatar
Decide for yourself.
HERE is where it came from.
tony gray is offline   Reply With Quote
Old 10-01-2009, 03:07 AM   #10329
PaPeRo's Avatar
Originally Posted by caltek1 View Post
With the 3Racing speed gear set, you only need to change the spur gear. The secondary gear they have is the same as the Tamiya item. The problem is that a 20 tooth pinion can be fitted to the motor, but placed in the 16 pinion hole on the chassis. The gears are a different white colour to the Tamiya item. So Teching should be easy.
Personally for us here in Aust, I think you will know if someone is using them, as they will be faster than normal, especially with using the Hobbywing systems.
Yes I have a set, not fitted to my car, but will build a car for the TITC in Bangkok next year, which has open gearing, using Tamiya sport tuned motors. My major worry is that the motor will not last due to the heat from gears and the ambient temperature in Bangkok. These will be hand out motors.
Have a great day.
Calvin.
Tobee Craft makes a nice alloy 36T spur for the M chassis cars which I have and will be fitting in my M04.
Here's a couple of pics of my work-in-progress M04.
PaPeRo is offline   Reply With Quote
Old 10-01-2009, 06:23 AM   #10330
PaPeRo's Avatar
Originally Posted by RossoTorro View Post
Looked on 3racing website, their diff looks alot like this.
Only they use 2.4mm ball and probably a crap thrustwasher like on the M03 diff.
Tested the M03 diff from them and it was the best diff i have ever used for 2 batterypacks, that's how long the thrustbearing lasted. Got a new thrustbearing sent from 3racing, refitted it and tested again. Same story, 2 batterypacks and the car sounded like it had vario-matic transmission. Then i tested with a thrustbearing from TA05MS, and it was no more problem with thrustbearing. Now the diff carrier melted.
So, my advise is not to get any gear parts from 3racing.
But in my eager to get a non TA03 diff to test i have gone and ordered the 3racing one.
Will post back as soon as i know how it's like.... My guess is it's as bad as the M03 one.
3Racing has two different ball diffs for the M chassis cars, an aluminum one and a heavy duty one.
http://www.3racing.hk/products.php?products_key=4032
Old 10-01-2009, 11:37 AM   #10331
edwintklee's Avatar
Trader Rating: 23 (96%+)
"If I was to advise a beginner to intermediate driver, I’d say buy the M03, it’s better value for money and is just as fast as an M05. For the faster more experienced drivers, perhaps you need an M03 AND an M05 so you can make up your own mind."
great comment from www.RC-mini.net
exactly what i feel....thanks for confirming this..
as both my cars have traction rolls issue...
any comment on xevo?
http://www.rcmart.com/catalog/rc-tl0...th=595_744_707
which personally feel that it has no m chasis characteristic in it, only build for speed as it can fit a 26t pinion....
I am a Red Star, Blue Star, Fans......
edwintklee is offline   Reply With Quote
Old 10-01-2009, 12:04 PM   #10332
Default M03 vs. M05
I'll preface this post by saying that I'm in no way trying to start an arguement or counter what other folks with WAY more experience than I do have found. This is just MY experience
I found that the M05 does not traction roll nearly as easily as my well set up M03 did. With good sticky tires (like RP 30's) and a ham fist I can get my M05 to traction roll...but it takes some effort!
I don't think my M05 is really much (or any) faster than my M03 but it took considerably less effort to get it to be this fast. I'm running the kit setup (admittedly with TRF shocks) with 42g of extra weight and RP 36 tires along with a tight TA03 ball diff and the car is fantastic...fast out of the corners, no traction roll and very easy to drive.
Just my $CAD 0.02!
Cheers,
Mike
Mike
Hyper_Mike is offline   Reply With Quote
Old 10-01-2009, 12:15 PM   #10333
NT
NT's Avatar
Trader Rating: 21 (100%+)
Tamiya body?
It's gotta be for the $$$$
Surely there are some excellentboptions of a small, old school fwd car that tamira could have gone with. But this will sell nicely against the 240Z invasion from hpi and co.
Still ugly-think I'll be passing on this offering!
NT is offline   Reply With Quote
Old 10-01-2009, 12:15 PM   #10334
niznai's Avatar
Are you racing indorrs Hyper Mike? Carpet?
Team Greasy Weasel
Old 10-01-2009, 12:26 PM   #10335
dannyboy15's Avatar
Send a message via MSN to dannyboy15
Originally Posted by monkeyracing View Post
You can lock up the gear diff by adding shims, or filling it with glue. If you just want to tighten it up, throw some Tamiya Anti-Wear grease in there.
You can tighten up the ball diff by, well, tightening it up.
Jim
i assume it is a gear diff if more people join the club then il probs get a ball diff but thanks for the answer
dannyboy15 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Gerbelli
SEO by vBSEO 3.5.0
