Like Tree39Likes
Old 09-26-2009, 09:22 AM   #10276
jonest's Avatar
Originally Posted by RossoTorro View Post
Looked on 3racing website, their diff looks alot like this.
Only they use 2.4mm ball and probably a crap thrustwasher like on the M03 diff.
Tested the M03 diff from them and it was the best diff i have ever used for 2 batterypacks, that's how long the thrustbearing lasted. Got a new thrustbearing sent from 3racing, refitted it and tested again. Same story, 2 batterypacks and the car sounded like it had vario-matic transmission. Then i tested with a thrustbearing from TA05MS, and it was no more problem with thrustbearing. Now the diff carrier melted.
So, my advise is not to get any gear parts from 3racing.
But in my eager to get a non TA03 diff to test i have gone and ordered the 3racing one.
Will post back as soon as i know how it's like.... My guess is it's as bad as the M03 one.
I've been using the TA03 on my M03 for quite a while now, not much issue so far and I'm looking forward to the new M05 ball diff from Tamiya.
cheers
jonest is offline   Reply With Quote
Old 09-26-2009, 09:26 AM   #10277
dannyboy15's Avatar
Send a message via MSN to dannyboy15
Red face
Originally Posted by k_bojar View Post
a lot of guys run the gears dry...the diff doesn't need much either
i put grease on the gears in my mini the first time i built it back in '99 - and the couple of rebuilds since then, i've run the gears dry
thanks ty
dannyboy15 is offline   Reply With Quote
Old 09-26-2009, 09:40 AM   #10278
Pro10noob's Avatar
Same here,run the gears dry and use aw grease for the bevel gear(diff) to get some friction in the diff
cheers Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 09-26-2009, 01:02 PM   #10279
caltek1's Avatar
Trader Rating: 33 (100%+)
I use Nulon silicone lubricant on my gears and have never had a problem. Spray on and let dry. Job done. I also use this to lubricate the two MO5 chassis halves as per instructions.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 09-26-2009, 02:36 PM   #10280
gashuffer's Avatar
Trader Rating: 48 (100%+)
What's a good affordable"" esc to put into my mini? I plan on running a 2 cell with the stock 540 motor.
gashuffer is offline   Reply With Quote
Old 09-26-2009, 02:40 PM   #10281
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
the tekin Fx Pro are fairly cheap - especially used...they are lipo friendly and programmable
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 09-26-2009, 03:04 PM   #10282
dannyboy15's Avatar
it depends what you call afforadble i call my novak gt7 afforadble but thats cus it cost me 10
Old 09-26-2009, 03:47 PM   #10283
gashuffer's Avatar
Thanks for the replies. I have a Tekin FX-R but I wanted to try something different in the under 100 range. Also what's the best torque range for servo's? Which brand? Sorry for all the questions but I like to know what other people are using.
Old 09-27-2009, 12:22 AM   #10284
Originally Posted by mulgar View Post
Sorry to raise a newbie question, I've been out of R/C for many years and trying to get back into R/C by getting into mini racing. I'm just about sorted on my car (M-03R) but a little confused on what wheels/tyres to get. I've been searching around for a while but couldn't find any clear answers.
I'm planning on running at my local track which is an indoor road track (Windsor, NSW, Australia).
Any advice would be appreciated (especially from anyone on this thread who runs there).
Thanks in advance.
Most rubber works Ok at Windsor. The only exception to this would be Tamiya 60D's, they just tear up too easily at Windsor, only good for 2-3 weeks of racing. Most minis at Windsor run the smaller diameter slick or treaded tyres.
I run Ride tyres on the front (soft 3020, medium, 3030 depends on grip level) with hard inserts, I run Pit Shimizu treaded D25 or Ride 3020 with soft 5mm insert on the rear. I have run Spice & Cross as well, but find the Ride tyres to be consistent (they are belted and wear well) Another great tyre is the treaded HPI X-Pattern run all round. A little hard to find stock though.
As far as rims go, I prefer the HPI Mini Dish Wheels (#3640) they are as tough as nails and don't break/chip/shatter edges when you try and rearrange the track walls. Others prefer the Swift rims, they are tough as well.
Look on RcTech for the following local threads,
M03/M05's - Aussie Mini Racing Thread
Windsor Indoor Hobby Centre
The Windsor regulars hang out at all these threads...
Look forward to seeing you at Windsor soon.
Cheers,
Carl
cate3 is offline   Reply With Quote
Old 09-27-2009, 04:30 AM   #10285
dave197's Avatar
i know they arnt legal but has anyone tried the 3Racing M05 Fast Gear Set?
dave197 is offline   Reply With Quote
Old 09-27-2009, 05:39 AM   #10286
mcdogboy's Avatar
Got a set on the way to chuck in the m04 to give it some more legs, will know then how different they look from a teching perspective.
mcdogboy is offline   Reply With Quote
Old 09-27-2009, 10:28 AM   #10287
monkeyracing's Avatar
I don't know about the durability of the 3Racing gears, but here's what I do know. They're designed for more top speed, so racing on a relatively short track would probably not be advantageous. What I heard last week regarding teching is that if someone is running a bigger pinion than allowed, then they're probably using those gears.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 09-27-2009, 02:54 PM   #10288
caltek1's Avatar
Jim,
With the 3Racing speed gear set, you only need to change the spur gear. The secondary gear they have is the same as the Tamiya item. The problem is that a 20 tooth pinion can be fitted to the motor, but placed in the 16 pinion hole on the chassis. The gears are a different white colour to the Tamiya item. So Teching should be easy.
Personally for us here in Aust, I think you will know if someone is using them, as they will be faster than normal, especially with using the Hobbywing systems.
Yes I have a set, not fitted to my car, but will build a car for the TITC in Bangkok next year, which has open gearing, using Tamiya sport tuned motors. My major worry is that the motor will not last due to the heat from gears and the ambient temperature in Bangkok. These will be hand out motors.
Have a great day.
Calvin.
Old 09-27-2009, 10:40 PM   #10289
I ran the RP Take Off tires tonight (RP-30), using sweep inserts. Running on grippy carpet. These things are gumballs! If you can find some, give them a shot.
Jim
Stab it and steer.
Old 09-28-2009, 02:23 AM   #10290
tony gray's Avatar
For all those people who have sent in Minifans pics to us at rc-mini and have been waiting for an eternity to see them..
Well we've finally re-done the Minifans section. And it's all-new and hi-tech!
Check it out now.
tony gray is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
sosidge
