Like Tree81Likes
Old 09-25-2009, 07:33 PM   #10261
Three's Avatar
Why not get both?
Electric good..........
Three is offline   Reply With Quote
Old 09-25-2009, 07:53 PM   #10262
gashuffer's Avatar
Trader Rating: 48 (100%+)
Originally Posted by Three View Post
Why not get both?
This is not the answer I was looking for
gashuffer is offline   Reply With Quote
Old 09-25-2009, 08:28 PM   #10263
I do have both and right now, my personal peference is for the M03. The steering wipers, Tamiya's terminology for the steering linkages, are very easy to bend on an M05. Once bent, there is no easy solution. I race the M03s and run the M05 for fun.
Before there are 97 guys saying they've had their M05 for X many months without bending theirs, I do my racing now at a carpet track where the barriers are velcroed down and are relatively unforgiving. I also tried to order 2 sets of wipers from Tower last week and they only had one in stock. That's on the workbench now to replace the ones that were bent in the last attempt at racing the M05.
Once the rumored steering upgrades come out, that may change my mind especially for carpet.
Granpa is offline   Reply With Quote
Old 09-25-2009, 09:07 PM   #10264
Three's Avatar
The M03 is the standard, you can't go wrong with it. Everyone makes parts for it and the are readily available. The M05 is still new, and some parts (and kits) are hard to get.
Go to www.rc-mini.net for setup and tuning your Mini. The M03 article tells what is needed to build a competitive car.
Old 09-26-2009, 05:37 AM   #10265
mulgar's Avatar
Sorry to raise a newbie question, I've been out of R/C for many years and trying to get back into R/C by getting into mini racing. I'm just about sorted on my car (M-03R) but a little confused on what wheels/tyres to get. I've been searching around for a while but couldn't find any clear answers.
I'm planning on running at my local track which is an indoor road track (Windsor, NSW, Australia).
Any advice would be appreciated (especially from anyone on this thread who runs there).
Thanks in advance.
mulgar is offline   Reply With Quote
Old 09-26-2009, 05:50 AM   #10266
Timbulb's Avatar
Talk to the people at your track. They'll give you the best advice on what will work best there.
Timbulb is offline   Reply With Quote
Old 09-26-2009, 06:15 AM   #10267
G-mini's Avatar
Originally Posted by monkeyracing View Post
If you can get them, the Kimbrough large servo savers are fantastic and last loads longer then the Tamiya high torque models.
I've found that it's best to shave a little off the corners and drill two new holes for the ballstuds. Build one of these and you're good for a long time.
Pic attached.
Jim
cheers i've already got the alloy one i need a new servo and wondered what ones you boys are useing?
Ginge
DnV Racing
Sponser,Reality Racing/CML
G-mini is offline   Reply With Quote
Old 09-26-2009, 06:44 AM   #10268
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Ginge
i use a JR DS821 DIGITAL Sport servo...doesn't have metal gears (like I usually like), but seems quick enough for the mini and doesn't have overkill torque
Plus its one of the cheaper digital servos I found that was a name-brand servo
also, if you use the Tamiya servo savers (like I like in the mini), Tamiya gives you the parts to use JR servos - unlike hitech servos
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 09-26-2009, 07:20 AM   #10269
CARD's Avatar
Originally Posted by gtfour93 View Post
I like them so much that I even use them on my ABC Genetic.
Interesting... On your ABC, do you change to the ball end top Tamiya's?! or stick to ABC's?!
Commander At Riot Desert
Complete Adult's Repairing Depot
Can Anyone Refuse Doggie-style
CARD is offline   Reply With Quote
Old 09-26-2009, 07:47 AM   #10270
gashuffer's Avatar
Ok. Question. With the m-03 whats the differences between the M,L ?
Old 09-26-2009, 07:50 AM   #10271
Super Steve's Avatar
Send a message via AIM to Super Steve
I brlieve its the wheel bases.
There are 3 different wheelbases with minis.
Short medium and long
Super Steve is offline   Reply With Quote
Old 09-26-2009, 07:51 AM   #10272
gtfour93's Avatar
Trader Rating: 22 (100%+)
I used all the TAMIYA parts since the ABC upper & lower ball ends are different sizes. They were bigger on top & smaller on the bottom, compare to TAMIYA's one size. Also, there was no way to use the TAMIYA upper ball end on the Genetic chassis because it's a screw-in type, so I had some spare TA02 threaded ball ends that were used for a better solution.
gtfour93 is offline   Reply With Quote
Old 09-26-2009, 07:52 AM   #10273
gtfour93's Avatar
M = Medium wheel base
L = Long wheel base
Old 09-26-2009, 08:22 AM   #10274
dannyboy15's Avatar
Send a message via MSN to dannyboy15
Questions?? lubricant
what lubricant do you use in your mo3 gear box+diff ?
dannyboy15 is offline   Reply With Quote
Old 09-26-2009, 09:11 AM   #10275
k_bojar's Avatar
a lot of guys run the gears dry...the diff doesn't need much either
i put grease on the gears in my mini the first time i built it back in '99 - and the couple of rebuilds since then, i've run the gears dry
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
fritzthecat
