Like Tree23Likes
Old 09-23-2009, 04:20 AM   #10216
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by robus View Post
Its been a while since I posted here.
I've run m03s with Cooper body since the beginning.
I finally went to mid length, thanks to Fiat body.
It looks much better than Swift in my opinion.
Here it is. I based it on Ferrari's edition 6g5.
Rob
where did you get the body? or did you just get the M03M kit??
I'm kinda torn between the Fiat or the Abarth body
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 09-23-2009, 04:27 AM   #10217
caltek1's Avatar
Trader Rating: 33 (100%+)
For those interested the new Tamiya alloy motor mount fits like a glove and adds an additional 16 gms weight to the MO5 without the additional DF 03 heatsinks. I believe these will add an additional 5gms in total, so all up 21 gms. For those using the 3Racing alloy motor mount it weighs in at 10gms.
I hope to post pictures tomorrow night.
Regards,
Calvin
caltek1 is offline   Reply With Quote
Old 09-23-2009, 04:32 AM   #10218
k_bojar's Avatar
Originally Posted by caltek1 View Post
For those interested the new Tamiya alloy motor mount fits like a glove and adds an additional 16 gms weight to the MO5 without the additional DF3 heatsinks. I believe these will add an additional 5gms in total, so all up 20 gms. For those using the 3Racing alloy motor mount it weighs in at 10gms.
Regards,
Calvin
the extra front weight should help a little
have you tried the DF3 heatsinks on it yet? how do the mount to the plate? i'm waiting for my plate to get here, but can't visualize how they will fit on the chassis
Old 09-23-2009, 04:37 AM   #10219
cannon's Avatar
Trader Rating: 35 (100%+)
They screw onto the arm coming off the back of the motor plate at 90 degrees. They sit over the chassis behind the steering rack and below the steering rod from the servo.
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 09-23-2009, 11:40 AM   #10220
Super Steve's Avatar
Send a message via AIM to Super Steve
Hello,
I skipped through the last 10 pages and couldnt really find out about the difference between m05 and m05pro.
I would appriciate any help.
Super Steve is offline   Reply With Quote
Old 09-23-2009, 01:19 PM   #10221
cannon's Avatar
Originally Posted by Super Steve View Post
Hello,
Look at Tamiyas website to see the differences
Old 09-23-2009, 01:50 PM   #10222
caltek1's Avatar
Super Steve,
The MO5 Pro has some added bling parts which can be replaced on a MO5 kit by changing the rear hubs and adding a high torque servo saver. Do the bling bits make up for the body and extras you get with the standard kit, I suppose that is your choice. A pair of 1.5 degree rear hubs and alloy servo saver can be purchased seperately, so the car looks the same. Other bling bits are blue ball studs.
I think the MO5 is better value for money.
MO5 Ball Diff(New Style)
I received this E-mail response from Champ this morning regarding the new Tamiya MO5 Ball diff PNo 54194.
" Unfortunately Tamiya Japan has not announced 54194 yet,so I'm not sure when it will become available and its pricing ".
Regards,
Calvin.
Old 09-23-2009, 02:32 PM   #10223
Super Steve,
Regards,
Calvin.
I was under the impression these items are unique to the M05 Pro as well...
CVA Oil Damper Super Mini
Short Springs for TRF Dampers (Soft/Medium/Hard)
1150 Ball Bearings
850 Ball Bearings
Different wheels
Tristar Racing is offline   Reply With Quote
Old 09-23-2009, 10:36 PM   #10224
Dan
Dan's Avatar
Trader Rating: 43 (100%+)
1150 Ball Bearings
850 Ball Bearings
Different wheels
The ball bearings are a must too but thats about it. The rear aluminum hub carrier is not critical. The CVA oil dampers will help a lot, but since they are molded of the clear plastic type, they are fragile. Mostly everyone upgrades to the M-chassis black oil shocks or aluminum threaded dampers.
The original M05 is still a better deal if you don't need all the bling.
Dan is offline   Reply With Quote
Old 09-24-2009, 01:06 AM   #10225
caltek1's Avatar
Tristar Racing,
You are correct, however I do support Dan's statements. The clear super cva shocks do not come out of the box, I would rather not have them as they are brittle. I run TRF shocks on my mini's. The bearings easily replaced with better bearings and the rims well I use Tamiya rims rarely due to being easily cracked. I am not saying that about the Swift rims as they are easily Tamiya's best.
I have included some pictures of two of my mIni's. These are both MO5's. I have also included a shot of the whalan track where we have a lead up event to our Nationals this weekend and some shots of the new Tamiya motor mount with heat sinks fitted.
Regards,
Calvin.
Tamiya mini cooper-dsc01907.jpg   Tamiya mini cooper-dsc01912.jpg   Tamiya mini cooper-dsc01915.jpg   Tamiya mini cooper-dsc01917.jpg   Tamiya mini cooper-dsc01919.jpg
Old 09-24-2009, 03:31 AM   #10226
robus's Avatar
Body is for m05 but is available separately. Part# 51363. I don't think Abarth is available yet. Car is m03s and stayed that way for last 2 years.
Rob
robus is offline   Reply With Quote
Old 09-24-2009, 04:13 AM   #10227
k_bojar's Avatar
Regards,
Calvin.
Hey Calvin - what's the advantages of using a ball cup over the stock end on the steering?? For the one you have, did you have to modify the ball cup in any way or is it the stock length for the grey tamiya ones?
have you run the car with the heatsink setup? if so, does it make a difference?
Old 09-24-2009, 04:19 AM   #10228
hi im looking at starting racing soon would mini be good or am i better off running a tourer? i like the look of the minis and i guess they are cheaper?
unlucky7 is offline   Reply With Quote
Old 09-24-2009, 04:26 AM   #10229
k_bojar's Avatar
the best way to answer that is to look at what the local track has for a following.
if they have a good and solid following of mini drivers, then by all means get the mini - especially since you're digging the looks of it
if the track has no mini class, then you're better off getting a TC - the mini's are cool and people have tried to run them with the 'bigger' TCs, but they just can't honestly compete against a 4wd TC
see what the local track has and go from there nothing is worse then buying a chassis because you like it and then find out you have nowhere to race it (since you said you wanna get into racing)
-kaybo
Old 09-24-2009, 05:13 AM   #10230
Hi everyone,
I just finished building my first mini (M05 Pro).
I've just got a few questions so here goes.
The slop in on the back wheels. How do I get rid of that? It's so bad that the bearings are even sliding out of their sockets.
I also got the TA03 ball diff but when I give it full power and lock full left, the wheels will slow down and eventually stop spinning and when I release the steering it will start spinning again.
I've managed to strip one of the screw holes, what's the best way you guys found to fix this? I just pulled it apart again and put some CA in there. Havent put it back together yet but do you guys think this would suffice?
Thanks!
rnd_tang is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
