Like Tree200Likes
Old 09-02-2009, 09:00 PM   #10051
RossoTorro's Avatar
Default EzRun RULES!
At our track we all run EzRun 13t, i have bought 10 systems and tested them all. Tested them in M01, M02, M03 and M04.
There are NO power difference on any of them, even using 18A, 25A or 35A ESC. They all preform exactly alike. Racing is close and Mini class is fun.
On Ebay the system sells for 79 USD incl shipping. (From Hong Kong, but who cares )
I dunno why this cannot be standard?
It equals racing, less wrenching, hard to tamper with (ie. if one person is faster then rest then he's cheating!), low price, lasts forever and it all comes down to how well you drive and setup your car!
We also use Xpress/Yeah Racing foams and race on carpet.
All use same equipment and are having a great time!
We went same way as OZ when they first put news about this on their site way way back! Thanks guys!
PS. Waiting for my M05Pro to get here any day now....
RossoTorro is offline   Reply With Quote
Old 09-03-2009, 01:51 AM   #10052
Originally Posted by caltek1 View Post
rnd_tang,
Tamiya PNo 54180 MO5 Titanium Screw Set which has hex heads.
Tech Racing PNo MR5020 Tech Racing Hex Screw Set Tamiya M05
Regards,
Calvin.
Cool thanks for that.
The Tamiya is abit over priced IMO, can you tell me approximately how much the Tech Racing set is? I can't find it anywhere.
rnd_tang is offline   Reply With Quote
Old 09-03-2009, 02:12 AM   #10053
caltek1's Avatar
Trader Rating: 36 (100%+)
rnd_tang,
Try the attached link:
http://stores.shop.ebay.com.au/Jason...?_sop=10&_sc=1
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 09-03-2009, 04:10 AM   #10054
edwintklee's Avatar
Trader Rating: 23 (96%+)
my m05, steering its very funny, somethimes too much, some time too little...
steering its too unpredictable..
I am a Red Star, Blue Star, Fans......
edwintklee is offline   Reply With Quote
Old 09-03-2009, 04:58 AM   #10055
Cheers, just bought it
Old 09-03-2009, 12:37 PM   #10056
dmcguire's Avatar
Trader Rating: 22 (100%+)
Check to make sure the screws that hold the two pieces of lower suspension arms together aren't too tight. I ran into issues on my M03 where they were too tight and it felt tweaked. Run them slightly loose (so that there is a little movement on the mounts) and give that a go.
dmcguire is offline   Reply With Quote
Old 09-03-2009, 01:05 PM   #10057
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
I ran into the same issue. Try (2) .1 axle shims top and bottom on each side of the bell crank to get rid of the vetical play and see if that helps.
madjack is offline   Reply With Quote
Old 09-03-2009, 01:32 PM   #10058
Regional Moderator
Darkseid's Avatar
I haven't used any shims at all on my M05 steering and have found it to be excellent. Heck my TB03 and TA05 IFS both have more play in the steering than the M05
TLR 22...Tamiya F104...
Old 09-03-2009, 03:27 PM   #10059
madjack's Avatar
Mine started out tight as well, but developed slop after several battery packs. Thought I had a bad servo saver or servo, just turned out to be the play in the steering.
Old 09-04-2009, 01:35 AM   #10060
caltek1's Avatar
Default MO5 STEERING SLOP
I have found that after numerous battery packs through my MO5 Pro that I had some major slop which was affecting the steering. I re-shimmed the steering linkage with 0.5mm on, the right side,(viewed from the front) and 0.3mm on the left side. I also adjusted the front for a little bit of toe out, (good technical term) and now the car tracks straight again, no problems. I think that this will need to be monitored in the future.
I hope Core is correct about a alloy steering rack being released by Tamiya, this might alleviate some of the slop, if not all. I do know that the 3Racing alloy steering rack is already available and Tech Racing have a carbon fibre part with three ackerman positions being released on 9 Sep.
madjack,
I originally thought my servo was at fault for my car not tracking straight, but it was the slop in the steering assembly.
Regards,
Calvin.
Old 09-04-2009, 06:48 AM   #10061
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Fred from Tamiya USA was the one who told me about the upcoming parts, so I think it's a 100% for sure.
I noticed on carpet I had no tracking issues (although I did shim it when I built it) but on asphalt I needed to re-shim and take more play out. Otherwise the car wandered pretty easily. But once shimmed the car tracks dead straight.
Oh, BTW Madjack...I figured out my speed problems...I will make a more prepared challenge next year!
madjack,
Regards,
Calvin.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 09-04-2009, 07:00 AM   #10062
monkeyracing's Avatar
I'd like to know what this is...RC Reinforced Freewheel Axle Set
Typical Tamiya...no preview pictures.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 09-04-2009, 07:02 AM   #10063
It's just reinforced (stronger metal) rear axles...nothing special. I can't imagine they will be much of a must have, but I did see some bent rear axles at the NATS last weekend. So they do bend.
Old 09-04-2009, 07:04 AM   #10064
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Jim
I posted those pics a bit earlier.. not sure what's so special about them.. Only if they reduced the slop from the axles.. I often need .5mm of shims to keep them from sliding around..
Tamiya mini cooper
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 09-04-2009, 07:10 AM   #10065
caltek1's Avatar
I have found that with my MO3's and the MO5 is no different that the standard rear axles are easy to bend, when you have an altercation with someone or a pipe.
I found the easiest fix was to fit the front axle to the rear hubs. This is much stronger than the rear axle and does not bend easily. Most racers replace the front axle with universals anyway. This is also cheaper.
Works for me.
Later,
Calvin.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
